2020-04-26 04:20:12.00529 -ERROR- err: rpc error: code = Unavailable desc = all SubConns are in TransientFailure, latest connection error: connection error: desc = “transport: Error while dialing dial tcp 172.31.8.76:9121: i/o timeout”, errMsg: create resources failed: rpc error: code = Unavailable desc = all SubConns are in TransientFailure, latest connection error: connection error: desc = “transport: Error while dialing dial tcp 172.31.8.76:9121: i/o timeout” (handler.go:328)
2020-04-26 04:20:12.00532 -INFO- Handled request [CreateRuntimeCredential] [&{UserId:system OwnerPath::system AccessPath:}] exec_time is [350.244µs] (grpc_server.go:188)
2020-04-26 04:20:12.00533 -DEBUG- Response is error: InvalidArgument, create resources failed: rpc error: code = Unavailable desc = all SubConns are in TransientFailure, latest connection error: connection error: desc = “transport: Error while dialing dial tcp 172.31.8.76:9121: i/o timeout” (grpc_server.go:191)
2020-04-26 04:26:34.93596 -INFO- Request received [DescribeCategories] [&{UserId:system OwnerPath::system AccessPath:}] [{“sort_key”:“create_time”,“reverse”:true,“limit”:200}] (grpc_server.go:180)
2020-04-26 04:26:34.93789 -DEBUG- dbr.select spend 1.83ms: map[sql:SELECT category_id, name, description, locale, owner_path, owner, icon, create_time, update_time FROM category WHERE ((owner_path
LIKE ‘%’) OR (owner
= ‘system’)) ORDER BY create_time DESC LIMIT 200 OFFSET 0] (event.go:48)
2020-04-26 04:26:34.93818 -DEBUG- dbr.select spend 0.26ms: map[sql:SELECT COUNT() FROM category WHERE ((owner_path
LIKE ‘%’) OR (owner
= ‘system’))] (event.go:48)
2020-04-26 04:26:34.93821 -INFO- Handled request [DescribeCategories] [&{UserId:system OwnerPath::system AccessPath:}] exec_time is [2.217294ms] (grpc_server.go:188)
2020-04-26 04:26:34.98428 -INFO- Request received [DescribeApps] [&{UserId:system OwnerPath::system AccessPath:}] [{“sort_key”:“create_time”,“reverse”:true,“limit”:12,“repo_id”:[“\u0000”],“status”:[“active”]}] (grpc_server.go:180)
2020-04-26 04:26:34.98484 -DEBUG- dbr.select spend 0.43ms: map[sql:SELECT app_id, active, name, repo_id, description, status, home, icon, screenshots, maintainers, keywords, sources, readme, owner, owner_path, chart_name, tos, abstraction, isv, create_time, status_time, update_time FROM app WHERE ((repo_id
IN (‘\0’)) AND (status
IN (‘active’))) AND (active
= 0) AND ((owner_path
LIKE ‘%’) OR (owner
= ‘system’)) ORDER BY create_time DESC LIMIT 12 OFFSET 0] (event.go:48)
2020-04-26 04:26:34.98515 -DEBUG- dbr.select spend 0.28ms: map[sql:SELECT COUNT() FROM app WHERE ((repo_id
LIKE ‘%’) OR (owner
2020-04-26 04:26:37.87277 -ERROR- err: rpc error: code = Unavailable desc = all SubConns are in TransientFailure, latest connection error: connection error: desc = “transport: Error while dialing dial tcp 172.31.5.83:9118: i/o timeout”, errMsg: internal error: rpc error: code = Unavailable desc = all SubConns are in TransientFailure, latest connection error: connection error: desc = “transport: Error while dialing dial tcp 172.31.5.83:9118: i/o timeout” (resource_control.go:436)
2020-04-26 04:26:37.87281 -INFO- Handled request [DescribeApps] [&{UserId:system OwnerPath::system AccessPath:}] exec_time is [2.88850349s] (grpc_server.go:188)
2020-04-26 04:26:37.87282 -DEBUG- Response is error: Internal, internal error: rpc error: code = Unavailable desc = all SubConns are in TransientFailure, latest connection error: connection error: desc = “transport: Error while dialing dial tcp 172.31.5.83:9118: i/o timeout” (grpc_server.go:191)
openpitrix应用商店无法使用,pod日志中有大量连接svc timeout的错误
是bug啊,一直发布失败,就多点了几次
9 个月 后
huanggze 我也遇到同样问题了,打开应用商店,经常超时转圈,偶尔能显示应用模板列表。
huanggze 我查了下,链接超时的ip是铁通DNS的,不是k8s集群内部ip段。 kubesphere用的3.0
