• DevOps
  • 默认devops模版部署到dev环境报错,提示Not Found,请大佬解答。
Starting Kubernetes deployment
Loading configuration: /home/jenkins/agent/workspace/BWw8Oj_devops-java-sample_master/deploy/dev/devops-sample-svc.yaml
ERROR: ERROR: java.lang.RuntimeException: io.kubernetes.client.openapi.ApiException: Not Found
hudson.remoting.ProxyException: java.lang.RuntimeException: io.kubernetes.client.openapi.ApiException: Not Found
	at com.microsoft.jenkins.kubernetes.wrapper.ResourceManager.handleApiException(ResourceManager.java:193)
	at com.microsoft.jenkins.kubernetes.wrapper.V1beta1ResourceManager$ExtensionsDeploymentUpdater.createResource(V1beta1ResourceManager.java:344)
	at com.microsoft.jenkins.kubernetes.wrapper.V1beta1ResourceManager$ExtensionsDeploymentUpdater.createResource(V1beta1ResourceManager.java:307)
	at com.microsoft.jenkins.kubernetes.wrapper.ResourceManager$ResourceUpdater.createOrApply(ResourceManager.java:100)
	at com.microsoft.jenkins.kubernetes.wrapper.KubernetesClientWrapper.handleResource(KubernetesClientWrapper.java:289)
	at com.microsoft.jenkins.kubernetes.wrapper.KubernetesClientWrapper.apply(KubernetesClientWrapper.java:256)
	at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.doCall(DeploymentCommand.java:172)
	at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.call(DeploymentCommand.java:124)
	at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.call(DeploymentCommand.java:106)
	at hudson.remoting.UserRequest.perform(UserRequest.java:212)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:369)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at hudson.remoting.Engine$1.lambda$newThread$0(Engine.java:93)
	at java.lang.Thread.run(Thread.java:748)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to JNLP4-connect connection from 10.233.96.95/10.233.96.95:46150
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
		at hudson.remoting.Channel.call(Channel.java:957)
		at hudson.FilePath.act(FilePath.java:1160)
		at com.microsoft.jenkins.kubernetes.command.DeploymentCommand.execute(DeploymentCommand.java:68)
		at com.microsoft.jenkins.kubernetes.command.DeploymentCommand.execute(DeploymentCommand.java:45)
		at com.microsoft.jenkins.azurecommons.command.CommandService.runCommand(CommandService.java:88)
		at com.microsoft.jenkins.azurecommons.command.CommandService.execute(CommandService.java:96)
		at com.microsoft.jenkins.azurecommons.command.CommandService.executeCommands(CommandService.java:75)
		at com.microsoft.jenkins.azurecommons.command.BaseCommandContext.executeCommands(BaseCommandContext.java:77)
		at com.microsoft.jenkins.kubernetes.KubernetesDeploy.perform(KubernetesDeploy.java:42)
		at com.microsoft.jenkins.azurecommons.command.SimpleBuildStepExecution.run(SimpleBuildStepExecution.java:54)
		at com.microsoft.jenkins.azurecommons.command.SimpleBuildStepExecution.run(SimpleBuildStepExecution.java:35)
		at org.jenkinsci.plugins.workflow.steps.SynchronousNonBlockingStepExecution.lambda$start$0(SynchronousNonBlockingStepExecution.java:47)
		at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
		... 1 more
Caused by: hudson.remoting.ProxyException: io.kubernetes.client.openapi.ApiException: Not Found
	at io.kubernetes.client.openapi.ApiClient.handleResponse(ApiClient.java:979)
	at io.kubernetes.client.openapi.ApiClient.execute(ApiClient.java:895)
	at io.kubernetes.client.openapi.apis.ExtensionsV1beta1Api.createNamespacedDeploymentWithHttpInfo(ExtensionsV1beta1Api.java:355)
	at io.kubernetes.client.openapi.apis.ExtensionsV1beta1Api.createNamespacedDeployment(ExtensionsV1beta1Api.java:329)
	at com.microsoft.jenkins.kubernetes.wrapper.V1beta1ResourceManager$ExtensionsDeploymentUpdater.createResource(V1beta1ResourceManager.java:341)
	... 16 more
Created V1Service: class V1Service {
    kind: Service
    metadata: class V1ObjectMeta {
        annotations: null
        clusterName: null
        creationTimestamp: 2020-05-29T06:04:58.000Z
        deletionGracePeriodSeconds: null
        deletionTimestamp: null
        finalizers: null
        generateName: null
        generation: null
        initializers: null
        labels: {app=kubesphere, component=ks-sample-dev}
        managedFields: null
        namespace: kubesphere-sample-dev
        ownerReferences: null
        resourceVersion: 323711
        selfLink: /api/v1/namespaces/kubesphere-sample-dev/services/ks-sample-dev
        uid: d0651646-f296-4447-9cbe-f2e23febbf79
    spec: class V1ServiceSpec {
        clusterIP: 10.233.14.216
        externalIPs: null
        externalName: null
        externalTrafficPolicy: Cluster
        healthCheckNodePort: null
        loadBalancerIP: null
        loadBalancerSourceRanges: null
        ports: [class V1ServicePort {
            nodePort: 30861
            port: 8080
            protocol: TCP
            targetPort: 8080
        publishNotReadyAddresses: null
        selector: {app=kubesphere, component=ks-sample-dev, tier=backend}
        sessionAffinity: None
        sessionAffinityConfig: null
        type: NodePort
    status: class V1ServiceStatus {
        loadBalancer: class V1LoadBalancerStatus {
            ingress: null
Loading configuration: /home/jenkins/agent/workspace/BWw8Oj_devops-java-sample_master/deploy/dev/devops-sample.yaml
Api call failed with code 404, detailed message: {
  "kind": "Status",
  "apiVersion": "v1",
  "metadata": {
  "status": "Failure",
  "message": "the server could not find the requested resource",
  "reason": "NotFound",
  "details": {
  "code": 404
Kubernetes deployment ended with HasError
1,使用什么方式安装的,ks-only, allinone?
2,贴一下 部署凭证的 server 值
3,使用 yaml 直接 kubectl 创建试试
  • zoey 回复了此帖
    shaowenchen 问题解决了,devops-sample.yaml 文件中 apiVersion: apps/v1 我这个选项不对。我本地的模版没及时更新。。
