ansible 出错任务[common : Kubesphere | Deploy openldap] 日志
TASK [common : Kubesphere | Deploy openldap] ***********************************
fatal: [localhost]: FAILED! => {"changed": true, "cmd": "/usr/local/bin/helm upgrade --install ks-openldap /etc/kubesphere/openldap-ha -f /etc/kubesphere/custom-values-openldap.yaml --set fullnameOverride=openldap --namespace kubesphere-system\n", "delta": "0:00:01.815684", "end": "2020-07-17 02:21:35.984843", "msg": "non-zero return code", "rc": 1, "start": "2020-07-17 02:21:34.169159", "stderr": "Error: render error in \"openldap-ha/templates/statefulset.yaml\": template: openldap-ha/templates/statefulset.yaml:25:9: executing \"openldap-ha/templates/statefulset.yaml\" at <(.Values.ldap.replication) and eq .Values.ldap.replication \"true\">: can't give argument to non-function .Values.ldap.replication", "stderr_lines": ["Error: render error in \"openldap-ha/templates/statefulset.yaml\": template: openldap-ha/templates/statefulset.yaml:25:9: executing \"openldap-ha/templates/statefulset.yaml\" at <(.Values.ldap.replication) and eq .Values.ldap.replication \"true\">: can't give argument to non-function .Values.ldap.replication"], "stdout": "Release \"ks-openldap\" does not exist. Installing it now.", "stdout_lines": ["Release \"ks-openldap\" does not exist. Installing it now."]}
我搜索到,有朋友和我一样的问题,但是没有解决方案
https://kubesphere.com.cn/forum/d/1681-ldap
