hosts.ini文件内容:
`[all]
master ansible_connection=local ip=192.168.58.245
node1 ansible_host=192.168.58.105 ip=192.168.58.105 ansible_user=root ansible_ssh_pass=root_123
#node2 ansible_host=192.168.0.8 ip=192.168.0.8 ansible_ssh_pass=Qcloud@123
[local-registry]
master
[kube-master]
master
[kube-node]
node1
[etcd]
master
[k8s-cluster:children]
kube-node
kube-master`
报错部分信息:
`TASK [etcd : Gen_certs | run cert generation script] *******************************************************************************************************************
Tuesday 28 July 2020 14:51:12 +0800 (0:00:00.324) 0:01:49.606 **********
fatal: [master -> master]: FAILED! => {
“changed”: true,
“cmd”: [
“bash”,
“-x”,
“/usr/local/bin/etcd-scripts/make-ssl-etcd.sh”,
“-f”,
“/etc/ssl/etcd/openssl.conf”,
“-d”,
“/etc/ssl/etcd/ssl”
“delta”: “0:00:00.007509″,
“end”: “2020-07-28 14:51:12.977194″,
“rc”: 127,
“start”: “2020-07-28 14:51:12.969685″
STDERR:
- set -o errexit
- set -o pipefail
- (( 4 ))
- case “$1” in
- CONFIG=/etc/ssl/etcd/openssl.conf
- shift 2
- (( 2 ))
- case “$1″ in
- SSLDIR=/etc/ssl/etcd/ssl
- shift 2
- (( 0 ))
- ‘[’ -z /etc/ssl/etcd/openssl.conf ‘]’
- ‘[’ -z /etc/ssl/etcd/ssl ‘]’
++ mktemp -d /tmp/etcd_cacert.XXXXXX
- tmpdir=/tmp/etcd_cacert.HtJesG
- trap ‘rm -rf “${tmpdir}”’ EXIT
- cd /tmp/etcd_cacert.HtJesG
- mkdir -p /etc/ssl/etcd/ssl
- ‘[’ -e /etc/ssl/etcd/ssl/ca-key.pem ‘]’
- openssl genrsa -out ca-key.pem 2048
- rm -rf /tmp/etcd_cacert.HtJesG
MSG:
non-zero return code`
