kubectl logs -n kubesphere-system $(kubectl get pod -n kubesphere-system -l app=ks-install -o jsonpath=‘{.items[0].metadata.name}’) -f
2020-08-05T21:29:15+08:00 INFO : shell-operator latest
2020-08-05T21:29:15+08:00 INFO : HTTP SERVER Listening on 0.0.0.0:9115
2020-08-05T21:29:15+08:00 INFO : Use temporary dir: /tmp/shell-operator
2020-08-05T21:29:15+08:00 INFO : Initialize hooks manager …
2020-08-05T21:29:15+08:00 INFO : Search and load hooks …
2020-08-05T21:29:15+08:00 INFO : Load hook config from ‘/hooks/kubesphere/installRunner.py’
2020-08-05T21:29:16+08:00 INFO : Load hook config from ‘/hooks/kubesphere/schedule.py’
2020-08-05T21:29:16+08:00 INFO : Initializing schedule manager …
2020-08-05T21:29:16+08:00 INFO : KUBE Init Kubernetes client
2020-08-05T21:29:16+08:00 INFO : KUBE-INIT Kubernetes client is configured successfully
2020-08-05T21:29:16+08:00 INFO : MAIN: run main loop
2020-08-05T21:29:16+08:00 INFO : MAIN: add onStartup tasks
2020-08-05T21:29:16+08:00 INFO : Running schedule manager …
2020-08-05T21:29:16+08:00 INFO : QUEUE add all HookRun@OnStartup
2020-08-05T21:29:16+08:00 INFO : MSTOR Create new metric shell_operator_live_ticks
2020-08-05T21:29:16+08:00 INFO : MSTOR Create new metric shell_operator_tasks_queue_length
2020-08-05T21:29:16+08:00 INFO : GVR for kind ‘ClusterConfiguration’ is installer.kubesphere.io/v1alpha1, Resource=clusterconfigurations
2020-08-05T21:29:16+08:00 INFO : EVENT Kube event ‘554df39d-071f-4a66-91f2-34674905c1e8’
2020-08-05T21:29:16+08:00 INFO : QUEUE add TASK_HOOK_RUN@KUBE_EVENTS kubesphere/installRunner.py
2020-08-05T21:29:19+08:00 INFO : TASK_RUN HookRun@KUBE_EVENTS kubesphere/installRunner.py
2020-08-05T21:29:19+08:00 INFO : Running hook ‘kubesphere/installRunner.py’ binding ‘KUBE_EVENTS’ …
the implicit localhost does not match ‘all’
TASK [download : include_tasks] ************************************************
skipping: [localhost]
TASK [download : Download items] ***********************************************
TASK [download : Sync container] ***********************************************
TASK [kubesphere-defaults : Configure defaults] ********************************
ok: [localhost] => {
“msg”: “Check roles/kubesphere-defaults/defaults/main.yml”
TASK [preinstall : check k8s version] ******************************************
changed: [localhost]
TASK [preinstall : init k8s version] *******************************************
ok: [localhost]
TASK [preinstall : Stop if kubernetes version is nonsupport] *******************
“changed”: false,
“msg”: “All assertions passed”
TASK [preinstall : check storage class] ****************************************
TASK [preinstall : Stop if StorageClass was not found] *************************
TASK [preinstall : check default storage class] ********************************
TASK [preinstall : Stop if defaultStorageClass was not found] ******************
“changed”: false,
TASK [preinstall : Kubesphere | Checking kubesphere component] *****************
TASK [preinstall : Kubesphere | Get kubesphere component version] **************
skipping: [localhost] => (item=ks-openldap)
skipping: [localhost] => (item=ks-redis)
skipping: [localhost] => (item=ks-minio)
skipping: [localhost] => (item=ks-openpitrix)
skipping: [localhost] => (item=elasticsearch-logging)
skipping: [localhost] => (item=elasticsearch-logging-curator)
skipping: [localhost] => (item=istio)
skipping: [localhost] => (item=istio-init)
skipping: [localhost] => (item=jaeger-operator)
skipping: [localhost] => (item=ks-jenkins)
skipping: [localhost] => (item=ks-sonarqube)
skipping: [localhost] => (item=logging-fluentbit-operator)
skipping: [localhost] => (item=uc)
skipping: [localhost] => (item=metrics-server)
localhost : ok=8 changed=4 unreachable=0 failed=0 skipped=6 rescued=0 ignored=0
TASK [metrics-server : Metrics-Server | Checking old installation files] *******
TASK [metrics-server : Metrics-Server | deleting old metrics-server] ***********
TASK [metrics-server : Metrics-Server | deleting old metrics-server files] *****
TASK [metrics-server : Metrics-Server | Getting metrics-server installation files] ***
skipping: [localhost] => (item={‘name’: ‘values’, ‘file’: ‘values.yaml’, ‘type’: ‘config’})
TASK [metrics-server : Metrics-Server | Check Metrics-Server] ******************
TASK [metrics-server : Metrics-Server | Installing metrics-server] *************
TASK [metrics-server : Metrics-Server | Installing metrics-server retry] *******
TASK [metrics-server : Metrics-Server | Waitting for v1beta1.metrics.k8s.io ready] ***
TASK [metrics-server : Metrics-Server | import metrics-server status] **********
localhost : ok=1 changed=0 unreachable=0 failed=0 skipped=13 rescued=0 ignored=0
TASK [common : Kubesphere | Check kube-node-lease namespace] *******************
TASK [common : KubeSphere | Get system namespaces] *****************************
ok: [localhost]
TASK [common : set_fact] *******************************************************
ok: [localhost]
TASK [common : debug] **********************************************************
“msg”: [
“kubesphere-system”,
“kubesphere-controls-system”,
“kubesphere-monitoring-system”,
“kube-node-lease”
TASK [common : KubeSphere | Create kubesphere namespace] ***********************
changed: [localhost] => (item=kubesphere-system)
changed: [localhost] => (item=kubesphere-controls-system)
changed: [localhost] => (item=kubesphere-monitoring-system)
changed: [localhost] => (item=kube-node-lease)
TASK [common : KubeSphere | Labeling system-workspace] *************************
changed: [localhost] => (item=default)
changed: [localhost] => (item=kube-public)
changed: [localhost] => (item=kube-system)
TASK [common : KubeSphere | Create ImagePullSecrets] ***************************
TASK [common : KubeSphere | Getting kubernetes master num] *********************
TASK [common : KubeSphere | Setting master num] ********************************
ok: [localhost]
TASK [common : Kubesphere | Getting common component installation files] *******
changed: [localhost] => (item=common)
changed: [localhost] => (item=ks-crds)
TASK [common : KubeSphere | Create KubeSphere crds] ****************************
TASK [common : KubeSphere | check k8s version] *********************************
changed: [localhost] => (item=snapshot-controller)
TASK [common : Kubesphere | Creating snapshot controller values] ***************
changed: [localhost] => (item={‘name’: ‘custom-values-snapshot-controller’, ‘file’: ‘custom-values-snapshot-controller.yaml’})
TASK [common : Kubesphere | Deploy snapshot controller] ************************
TASK [common : Kubesphere | Checking openpitrix common component] **************
TASK [common : include_tasks] **************************************************
skipping: [localhost] => (item={‘op’: ‘openpitrix-db’, ‘ks’: ‘mysql-pvc’})
skipping: [localhost] => (item={‘op’: ‘openpitrix-etcd’, ‘ks’: ‘etcd-pvc’})
TASK [common : Getting PersistentVolumeName (mysql)] ***************************
TASK [common : Getting PersistentVolumeSize (mysql)] ***************************
TASK [common : Setting PersistentVolumeName (mysql)] ***************************
TASK [common : Setting PersistentVolumeSize (mysql)] ***************************
TASK [common : Getting PersistentVolumeName (etcd)] ****************************
TASK [common : Getting PersistentVolumeSize (etcd)] ****************************
TASK [common : Setting PersistentVolumeName (etcd)] ****************************
TASK [common : Setting PersistentVolumeSize (etcd)] ****************************
TASK [common : Kubesphere | Check mysql PersistentVolumeClaim] *****************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pvc -n kubesphere-system mysql-pvc -o jsonpath=‘{.status.capacity.storage}’\n”, “delta”: “0:00:00.065978”, “end”: “2020-08-05 21:30:01.890432″, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:01.824454″, “stderr”: "Error from server (NotFound): persistentvolumeclaims \“mysql-pvc\” not found", “stderr_lines”: ["Error from server (NotFound): persistentvolumeclaims \“mysql-pvc\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Setting mysql db pv size] **************************
TASK [common : Kubesphere | Check redis PersistentVolumeClaim] *****************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pvc -n kubesphere-system redis-pvc -o jsonpath=‘{.status.capacity.storage}’\n”, “delta”: “0:00:00.073217”, “end”: “2020-08-05 21:30:02.198001”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:02.124784”, “stderr”: "Error from server (NotFound): persistentvolumeclaims \“redis-pvc\” not found", “stderr_lines”: ["Error from server (NotFound): persistentvolumeclaims \“redis-pvc\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Setting redis db pv size] **************************
TASK [common : Kubesphere | Check minio PersistentVolumeClaim] *****************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pvc -n kubesphere-system minio -o jsonpath=‘{.status.capacity.storage}’\n”, “delta”: “0:00:00.065503”, “end”: “2020-08-05 21:30:02.501511″, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:02.436008”, “stderr”: "Error from server (NotFound): persistentvolumeclaims \“minio\” not found", “stderr_lines”: ["Error from server (NotFound): persistentvolumeclaims \“minio\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Setting minio pv size] *****************************
TASK [common : Kubesphere | Check openldap PersistentVolumeClaim] **************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pvc -n kubesphere-system openldap-pvc-openldap-0 -o jsonpath=‘{.status.capacity.storage}’\n”, “delta”: “0:00:00.074701″, “end”: “2020-08-05 21:30:02.811497″, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:02.736796”, “stderr”: "Error from server (NotFound): persistentvolumeclaims \“openldap-pvc-openldap-0\” not found", “stderr_lines”: ["Error from server (NotFound): persistentvolumeclaims \“openldap-pvc-openldap-0\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Setting openldap pv size] **************************
TASK [common : Kubesphere | Check etcd db PersistentVolumeClaim] ***************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pvc -n kubesphere-system etcd-pvc -o jsonpath=‘{.status.capacity.storage}’\n”, “delta”: “0:00:00.068677”, “end”: “2020-08-05 21:30:03.112174”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:03.043497”, “stderr”: "Error from server (NotFound): persistentvolumeclaims \“etcd-pvc\” not found", “stderr_lines”: ["Error from server (NotFound): persistentvolumeclaims \“etcd-pvc\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Setting etcd pv size] ******************************
TASK [common : Kubesphere | Check redis ha PersistentVolumeClaim] **************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pvc -n kubesphere-system data-redis-ha-server-0 -o jsonpath=‘{.status.capacity.storage}’\n”, “delta”: “0:00:00.066000″, “end”: “2020-08-05 21:30:03.413118”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:03.347118″, “stderr”: "Error from server (NotFound): persistentvolumeclaims \“data-redis-ha-server-0\” not found", “stderr_lines”: ["Error from server (NotFound): persistentvolumeclaims \“data-redis-ha-server-0\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Setting redis ha pv size] **************************
TASK [common : Kubesphere | Check es-master PersistentVolumeClaim] *************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pvc -n kubesphere-logging-system data-elasticsearch-logging-discovery-0 -o jsonpath=‘{.status.capacity.storage}’\n”, “delta”: “0:00:00.074715″, “end”: “2020-08-05 21:30:03.735729”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:03.661014”, “stderr”: "Error from server (NotFound): namespaces \“kubesphere-logging-system\” not found", “stderr_lines”: ["Error from server (NotFound): namespaces \“kubesphere-logging-system\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Setting es master pv size] *************************
TASK [common : Kubesphere | Check es data PersistentVolumeClaim] ***************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pvc -n kubesphere-logging-system data-elasticsearch-logging-data-0 -o jsonpath=‘{.status.capacity.storage}’\n”, “delta”: “0:00:00.067035”, “end”: “2020-08-05 21:30:04.038636″, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:03.971601”, “stderr”: "Error from server (NotFound): namespaces \“kubesphere-logging-system\” not found", “stderr_lines”: ["Error from server (NotFound): namespaces \“kubesphere-logging-system\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Setting es data pv size] ***************************
TASK [common : Kubesphere | Creating common component manifests] ***************
changed: [localhost] => (item={‘path’: ‘etcd’, ‘file’: ‘etcd.yaml’})
changed: [localhost] => (item={‘name’: ‘mysql’, ‘file’: ‘mysql.yaml’})
changed: [localhost] => (item={‘path’: ‘redis’, ‘file’: ‘redis.yaml’})
TASK [common : Kubesphere | Creating mysql sercet] *****************************
TASK [common : Kubesphere | Deploying etcd and mysql] **************************
skipping: [localhost] => (item=etcd.yaml)
skipping: [localhost] => (item=mysql.yaml)
TASK [common : Kubesphere | Getting minio installation files] ******************
skipping: [localhost] => (item=minio-ha)
TASK [common : Kubesphere | Creating manifests] ********************************
skipping: [localhost] => (item={‘name’: ‘custom-values-minio’, ‘file’: ‘custom-values-minio.yaml’})
TASK [common : Kubesphere | Check minio] ***************************************
TASK [common : Kubesphere | Deploy minio] **************************************
TASK [common : fail] ***********************************************************
TASK [common : Kubesphere | create minio config directory] *********************
skipping: [localhost] => (item={‘path’: ‘/root/.config/rclone’, ‘file’: ‘rclone.conf’})
skipping: [localhost] => (item=helm)
skipping: [localhost] => (item=vmbased)
TASK [common : Kubesphere | import minio status] *******************************
TASK [common : Kubesphere | Check ha-redis] ************************************
TASK [common : Kubesphere | Getting redis installation files] ******************
skipping: [localhost] => (item=redis-ha)
skipping: [localhost] => (item={‘name’: ‘custom-values-redis’, ‘file’: ‘custom-values-redis.yaml’})
TASK [common : Kubesphere | Check old redis status] ****************************
TASK [common : Kubesphere | Delete and backup old redis svc] *******************
TASK [common : Kubesphere | Deploying redis] ***********************************
TASK [common : Kubesphere | Getting redis PodIp] *******************************
TASK [common : Kubesphere | Creating redis migration script] *******************
skipping: [localhost] => (item={‘path’: ‘/etc/kubesphere’, ‘file’: ‘redisMigrate.py’})
TASK [common : Kubesphere | Check redis-ha status] *****************************
TASK [common : ks-logging | Migrating redis data] ******************************
TASK [common : Kubesphere | Disable old redis] *********************************
skipping: [localhost] => (item=redis.yaml)
TASK [common : Kubesphere | import redis status] *******************************
TASK [common : Kubesphere | Getting openldap installation files] ***************
skipping: [localhost] => (item=openldap-ha)
skipping: [localhost] => (item={‘name’: ‘custom-values-openldap’, ‘file’: ‘custom-values-openldap.yaml’})
TASK [common : Kubesphere | Check old openldap status] *************************
TASK [common : KubeSphere | Shutdown ks-account] *******************************
TASK [common : Kubesphere | Delete and backup old openldap svc] ****************
TASK [common : Kubesphere | Check openldap] ************************************
TASK [common : Kubesphere | Deploy openldap] ***********************************
TASK [common : Kubesphere | Load old openldap data] ****************************
TASK [common : Kubesphere | Check openldap-ha status] **************************
TASK [common : Kubesphere | Get openldap-ha pod list] **************************
TASK [common : Kubesphere | Get old openldap data] *****************************
TASK [common : Kubesphere | Migrating openldap data] ***************************
TASK [common : Kubesphere | Disable old openldap] ******************************
TASK [common : Kubesphere | Restart openldap] **********************************
TASK [common : KubeSphere | Restarting ks-account] *****************************
TASK [common : Kubesphere | import openldap status] ****************************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: "/usr/local/bin/helm list -n kubesphere-system | grep \“ks-redis\”\n", “delta”: “0:00:00.048660″, “end”: “2020-08-05 21:30:07.077062″, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:07.028402”, “stderr”: "", “stderr_lines”: [], “stdout”: "", “stdout_lines”: []}
…ignoring
changed: [localhost] => (item=redis-ha)
changed: [localhost] => (item={‘name’: ‘custom-values-redis’, ‘file’: ‘custom-values-redis.yaml’})
changed: [localhost] => (item=openldap-ha)
changed: [localhost] => (item={‘name’: ‘custom-values-openldap’, ‘file’: ‘custom-values-openldap.yaml’})
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: "/usr/local/bin/helm list -n kubesphere-system | grep \“ks-openldap\”\n", “delta”: “0:00:00.050780”, “end”: “2020-08-05 21:30:24.132156”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:24.081376”, “stderr”: "", “stderr_lines”: [], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [common : Kubesphere | Deploying common component] ************************
TASK [common : Kubesphere | import mysql status] *******************************
TASK [common : Kubesphere | Getting elasticsearch and curator installation files] ***
TASK [common : Kubesphere | Creating custom manifests] *************************
skipping: [localhost] => (item={‘name’: ‘custom-values-elasticsearch’, ‘file’: ‘custom-values-elasticsearch.yaml’})
skipping: [localhost] => (item={‘name’: ‘custom-values-elasticsearch-curator’, ‘file’: ‘custom-values-elasticsearch-curator.yaml’})
TASK [common : Kubesphere | Check elasticsearch data StatefulSet] **************
TASK [common : Kubesphere | Check elasticsearch storageclass] ******************
TASK [common : Kubesphere | Comment elasticsearch storageclass parameter] ******
TASK [common : Kubesphere | Deploy elasticsearch-logging] **********************
TASK [common : Kubesphere | Get PersistentVolume Name] *************************
TASK [common : Kubesphere | Patch PersistentVolume (persistentVolumeReclaimPolicy)] ***
TASK [common : Kubesphere | Delete elasticsearch] ******************************
TASK [common : Kubesphere | Waiting for seconds] *******************************
TASK [common : Kubesphere | Deploy elasticsearch-logging-curator] **************
TASK [common : Kubesphere | import es status] **********************************
skipping: [localhost] => (item={‘path’: ‘fluentbit’, ‘file’: ‘custom-fluentbit-fluentBit.yaml’})
skipping: [localhost] => (item={‘path’: ‘init’, ‘file’: ‘custom-fluentbit-operator-deployment.yaml’})
skipping: [localhost] => (item={‘path’: ‘migrator’, ‘file’: ‘custom-migrator-job.yaml’})
TASK [common : Kubesphere | Checking fluentbit-version] ************************
TASK [common : Kubesphere | Backup old fluentbit crd] **************************
TASK [common : Kubesphere | Deleting old fluentbit operator] *******************
skipping: [localhost] => (item={‘type’: ‘deploy’, ‘name’: ‘logging-fluentbit-operator’})
skipping: [localhost] => (item={‘type’: ‘fluentbits.logging.kubesphere.io’, ‘name’: ‘fluent-bit’})
skipping: [localhost] => (item={‘type’: ‘ds’, ‘name’: ‘fluent-bit’})
skipping: [localhost] => (item={‘type’: ‘crd’, ‘name’: ‘fluentbits.logging.kubesphere.io’})
TASK [common : Kubesphere | Prepare fluentbit operator setup] ******************
TASK [common : Kubesphere | Migrate fluentbit operator old config] *************
TASK [common : Kubesphere | Deploy new fluentbit operator] *********************
TASK [common : Kubesphere | import fluentbit status] ***************************
TASK [common : Setting persistentVolumeReclaimPolicy (mysql)] ******************
TASK [common : Setting persistentVolumeReclaimPolicy (etcd)] *******************
localhost : ok=39 changed=34 unreachable=0 failed=0 skipped=115 rescued=0 ignored=10
TASK [ks-core/prepare : KubeSphere | Create KubeSphere dir] ********************
ok: [localhost]
TASK [ks-core/prepare : KubeSphere | Getting installation init files] **********
changed: [localhost] => (item=ks-init)
TASK [ks-core/prepare : Kubesphere | Checking account init] ********************
TASK [ks-core/prepare : Kubesphere | Init account] *****************************
TASK [ks-core/prepare : KubeSphere | Init KubeSphere] **************************
changed: [localhost] => (item=iam-accounts.yaml)
changed: [localhost] => (item=webhook-secret.yaml)
changed: [localhost] => (item=users.iam.kubesphere.io.yaml)
TASK [ks-core/prepare : KubeSphere | Getting controls-system file] *************
changed: [localhost] => (item={‘name’: ‘kubesphere-controls-system’, ‘file’: ‘kubesphere-controls-system.yaml’})
TASK [ks-core/prepare : KubeSphere | Installing controls-system] ***************
TASK [ks-core/prepare : KubeSphere | Generate kubeconfig-admin] ****************
TASK [ks-core/init-token : KubeSphere | Create KubeSphere dir] *****************
ok: [localhost]
TASK [ks-core/init-token : KubeSphere | Getting installation init files] *******
changed: [localhost] => (item=jwt-script)
TASK [ks-core/init-token : KubeSphere | Creating KubeSphere Secret] ************
ok: [localhost]
TASK [ks-core/init-token : KubeSphere | Enable Token Script] *******************
TASK [ks-core/init-token : KubeSphere | Getting KS Token] **********************
TASK [ks-core/init-token : Kubesphere | Checking kubesphere secrets] ***********
TASK [ks-core/init-token : Kubesphere | Delete kubesphere secret] **************
TASK [ks-core/init-token : KubeSphere | Create components token] ***************
TASK [ks-core/ks-core : KubeSphere | Getting kubernetes version] ***************
TASK [ks-core/ks-core : KubeSphere | Setting kubernetes version] ***************
ok: [localhost]
TASK [ks-core/ks-core : KubeSphere | Getting kubernetes master num] ************
TASK [ks-core/ks-core : KubeSphere | Setting master num] ***********************
ok: [localhost]
TASK [ks-core/ks-core : ks-console | Checking ks-console svc] ******************
TASK [ks-core/ks-core : ks-console | Getting ks-console svc port] **************
TASK [ks-core/ks-core : ks-console | Setting console_port] *********************
TASK [ks-core/ks-core : KubeSphere | Getting Ingress installation files] *******
changed: [localhost] => (item=ingress)
changed: [localhost] => (item=ks-apiserver)
changed: [localhost] => (item=ks-console)
changed: [localhost] => (item=ks-controller-manager)
TASK [ks-core/ks-core : KubeSphere | Creating manifests] ***********************
changed: [localhost] => (item={‘path’: ‘ingress’, ‘file’: ‘ingress-controller.yaml’, ‘type’: ‘config’})
changed: [localhost] => (item={‘path’: ‘ks-apiserver’, ‘file’: ‘ks-apiserver.yml’, ‘type’: ‘deploy’})
changed: [localhost] => (item={‘path’: ‘ks-controller-manager’, ‘file’: ‘ks-controller-manager.yaml’, ‘type’: ‘deploy’})
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘ks-console-config.yml’, ‘type’: ‘config’})
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘ks-console-deployment.yml’, ‘type’: ‘deploy’})
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘ks-console-svc.yml’, ‘type’: ‘svc’})
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘ks-docs-deployment.yaml’, ‘type’: ‘deploy’})
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘sample-bookinfo-configmap.yaml’, ‘type’: ‘config’})
TASK [ks-core/ks-core : KubeSphere | Delete Ingress-controller configmap] ******
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl delete cm -n kubesphere-system ks-router-config\n”, “delta”: “0:00:02.762756”, “end”: “2020-08-05 21:30:50.122026″, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-08-05 21:30:47.359270”, “stderr”: "Error from server (NotFound): configmaps \“ks-router-config\” not found", “stderr_lines”: ["Error from server (NotFound): configmaps \“ks-router-config\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
TASK [ks-core/ks-core : KubeSphere | Creating Ingress-controller configmap] ****
TASK [ks-core/ks-core : KubeSphere | Creating ks-core] *************************
changed: [localhost] => (item={‘path’: ‘ks-apiserver’, ‘file’: ‘ks-apiserver.yml’})
changed: [localhost] => (item={‘path’: ‘ks-controller-manager’, ‘file’: ‘ks-controller-manager.yaml’})
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘ks-console-config.yml’})
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘sample-bookinfo-configmap.yaml’})
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘ks-console-deployment.yml’})
TASK [ks-core/ks-core : KubeSphere | Check ks-console svc] *********************
TASK [ks-core/ks-core : KubeSphere | Creating ks-console svc] ******************
changed: [localhost] => (item={‘path’: ‘ks-console’, ‘file’: ‘ks-console-svc.yml’})
TASK [ks-core/ks-core : KubeSphere | Patch ks-console svc] *********************
TASK [ks-core/ks-core : KubeSphere | import ks-core status] ********************
localhost : ok=28 changed=22 unreachable=0 failed=0 skipped=10 rescued=0 ignored=1
Start installing monitoring
Start installing multicluster
task multicluster status is successful
total: 2 completed:1
task monitoring status is successful
total: 2 completed:2
