os : ubuntu 18.0.6
启动命令如下
./kk create cluster -f config-sample.yaml
config-sample.yaml
kind: Cluster
hosts:
- {name: node1, address: 10.10.0.14, internalAddress: 10.10.0.14, user: root, password: XXXX}
- {name: node2, address: 10.10.0.166, internalAddress: 10.10.0.166, user: root, password: XXX}
# - {name: node3, address: 10.10.0.11, internalAddress: 10.10.0.11, user: root, password: XXXX}
roleGroups:
- node1
master:
- node1
worker:
- node[1:2]
controlPlaneEndpoint:
domain: lb.kubesphere.local
address: ""
port: "6443"
kubernetes:
version: v1.18.6
imageRepo: kubesphere
clusterName: cluster.local
network:
plugin: calico
kubePodsCIDR: 10.233.64.0/18
registry:
registryMirrors: []
insecureRegistries: []
storage:
defaultStorageClass: localVolume
localVolume:
storageClassName: local
kind: ClusterConfiguration
namespace: kubesphere-system
version: v3.0.0
local_registry: ""
persistence:
storageClass: ""
authentication:
jwtSecret: ""
monitoring: true
endpointIps: localhost
port: 2379
tlsEnable: true
common:
es:
elasticsearchMasterVolumeSize: 4Gi
elkPrefix: logstash
logMaxAge: 7
mysqlVolumeSize: 20Gi
minioVolumeSize: 20Gi
etcdVolumeSize: 20Gi
openldapVolumeSize: 2Gi
redisVolumSize: 2Gi
console:
enableMultiLogin: false # enable/disable multi login
port: 30880
alerting:
enabled: false
auditing:
enabled: false
devops:
enabled: false
jenkinsMemoryLim: 2Gi
jenkinsMemoryReq: 1500Mi
jenkinsVolumeSize: 8Gi
jenkinsJavaOpts_Xms: 512m
jenkinsJavaOpts_Xmx: 512m
jenkinsJavaOpts_MaxRAM: 2g
events:
enabled: false
ruler:
enabled: true
replicas: 2
logging:
enabled: false
logsidecarReplicas: 2
metrics_server:
enabled: true
monitoring:
prometheusMemoryRequest: 400Mi
prometheusVolumeSize: 20Gi
multicluster:
clusterRole: host # host | member | none
networkpolicy:
enabled: false
notification:
enabled: false
openpitrix:
enabled: false
servicemesh:
enabled: false
kubectl get po -A
NAMESPACE NAME READY STATUS RESTARTS AGE
kube-federation-system kubefed-admission-webhook-66bbdff47d-tdlvb 1/1 Running 0 4h5m
kube-federation-system kubefed-controller-manager-54b459dfc4-qmlsj 1/1 Running 0 4h5m
kube-system calico-kube-controllers-578894d4cd-6lfvg 1/1 Running 0 4h10m
kube-system calico-node-48mw7 0/1 Running 0 4h10m
kube-system calico-node-tjf4v 0/1 Running 0 4h10m
kube-system coredns-6dd6674597-llfs7 1/1 Running 0 4h10m
kube-system coredns-6dd6674597-s59qz 1/1 Running 0 4h10m
kube-system kube-apiserver-node1 1/1 Running 0 4h10m
kube-system kube-controller-manager-node1 1/1 Running 0 4h10m
kube-system kube-proxy-2xs2s 1/1 Running 0 4h10m
kube-system kube-proxy-rm8bt 1/1 Running 0 4h10m
kube-system kube-scheduler-node1 1/1 Running 0 4h10m
kube-system metrics-server-f47758d8f-9hcrx 1/1 Running 0 4h7m
kube-system nodelocaldns-75vf4 1/1 Running 0 4h10m
kube-system nodelocaldns-9cpjl 1/1 Running 0 4h10m
kube-system openebs-localpv-provisioner-84446d4bd7-8l6k5 1/1 Running 0 4h8m
kube-system openebs-ndm-6v5dr 1/1 Running 0 4h8m
kube-system openebs-ndm-jgchw 1/1 Running 0 4h8m
kube-system openebs-ndm-operator-6456dc9db-qsnbs 1/1 Running 1 4h8m
kube-system snapshot-controller-0 1/1 Running 0 4h6m
kubesphere-controls-system default-http-backend-857d7b6856-qg4j7 1/1 Running 0 4h5m
kubesphere-controls-system kubectl-admin-58f985d8f6-j2vhm 1/1 Running 0 165m
kubesphere-monitoring-system alertmanager-main-0 2/2 Running 0 3h47m
kubesphere-monitoring-system kube-state-metrics-95c974544-bznv8 3/3 Running 0 4h4m
kubesphere-monitoring-system node-exporter-26fcw 2/2 Running 0 4h4m
kubesphere-monitoring-system node-exporter-dwzrq 2/2 Running 0 4h4m
kubesphere-monitoring-system notification-manager-deployment-7c8df68d94-ftdfm 1/1 Running 0 3h48m
kubesphere-monitoring-system notification-manager-operator-7b78b76c96-rr4b8 2/2 Running 0 4h4m
kubesphere-monitoring-system prometheus-k8s-0 3/3 Running 1 3h47m
kubesphere-monitoring-system prometheus-operator-84d58bf775-tgpz2 2/2 Running 0 4h4m
kubesphere-system ks-apiserver-5b88998cd5-s66jj 1/1 Running 1 3h47m
kubesphere-system ks-console-b4df86d6f-gznfg 1/1 Running 0 4h5m
kubesphere-system ks-controller-manager-595677fd9c-5g56r 1/1 Running 0 3h47m
kubesphere-system ks-installer-74757f9779-x2zmf 1/1 Running 0 4h8m
kubesphere-system openldap-0 1/1 Running 0 4h6m
kubesphere-system redis-644bc597b9-782sl 1/1 Running 0 4h6m
kubesphere-system tower-5f64d8bbd8-bxtjm 1/1 Running 0 4h5m
$ kubectl describe pod calico-node-48mw7 -n kube-system
Namespace: kube-system
Priority: 2000001000
Priority Class Name: system-node-critical
Node: node2/10.10.0.166
Start Time: Wed, 26 Aug 2020 05:58:47 +0000
Labels: controller-revision-hash=fc89bc6dd
k8s-app=calico-node
pod-template-generation=1
Annotations: <none>
Status: Running
IP: 10.10.0.166
IPs:
IP: 10.10.0.166
Controlled By: DaemonSet/calico-node
Init Containers:
upgrade-ipam:
Container ID: docker://714b95ec298c4fab9490d5b10f770e7a6ec8eeea3c3e0a0a5041695b3c17310a
Image: calico/cni:v3.15.1
Image ID: docker-pullable://calico/cni@sha256:b86711626e68a5298542efc52e2bd3c64e212a635359b3a017ee0a8cd47b0c1e
Port: <none>
Host Port: <none>
Command:
/opt/cni/bin/calico-ipam
-upgrade
State: Terminated
Reason: Completed
Exit Code: 0
Started: Wed, 26 Aug 2020 05:58:50 +0000
Finished: Wed, 26 Aug 2020 05:58:50 +0000
Ready: True
Restart Count: 0
Environment:
KUBERNETES_NODE_NAME: (v1:spec.nodeName)
CALICO_NETWORKING_BACKEND: <set to the key 'calico_backend' of config map 'calico-config'> Optional: false
Mounts:
/host/opt/cni/bin from cni-bin-dir (rw)
/var/lib/cni/networks from host-local-net-dir (rw)
/var/run/secrets/kubernetes.io/serviceaccount from calico-node-token-j29zs (ro)
install-cni:
Container ID: docker://0af3f84231f675932e46c80a57237c413e65fd427e881d18e21796784debbf23
Port: <none>
Host Port: <none>
Command:
/install-cni.sh
State: Terminated
Reason: Completed
Exit Code: 0
Started: Wed, 26 Aug 2020 05:58:51 +0000
Finished: Wed, 26 Aug 2020 05:58:52 +0000
Ready: True
Restart Count: 0
Environment:
CNI_CONF_NAME: 10-calico.conflist
CNI_NETWORK_CONFIG: <set to the key 'cni_network_config' of config map 'calico-config'> Optional: false
CNI_MTU: <set to the key 'veth_mtu' of config map 'calico-config'> Optional: false
SLEEP: false
Mounts:
/host/etc/cni/net.d from cni-net-dir (rw)
flexvol-driver:
Container ID: docker://0d18f4c02e1b2e9de9eb6ff1b59955ac6ec99d624c40f49bc4829e20441a054f
Image: calico/pod2daemon-flexvol:v3.15.1
Image ID: docker-pullable://calico/pod2daemon-flexvol@sha256:c2c6bbe3e10d24a01d6f3fd5b446cce6cf3e37f943960263bf6e5c458ecdeb52
Port: <none>
Host Port: <none>
State: Terminated
Reason: Completed
Exit Code: 0
Started: Wed, 26 Aug 2020 05:58:52 +0000
Ready: True
Restart Count: 0
Environment: <none>
Mounts:
/host/driver from flexvol-driver-host (rw)
Containers:
calico-node:
Container ID: docker://02f07a11f2490c56904ded628b857255c40167da556a9af8f7e9a897f4bde764
Image: calico/node:v3.15.1
Image ID: docker-pullable://calico/node@sha256:b386769a293d180cb6ee208c8594030128a0810b286a93ae897a231ef247afa8
Port: <none>
Host Port: <none>
State: Running
Started: Wed, 26 Aug 2020 05:58:53 +0000
Ready: False
Restart Count: 0
Requests:
cpu: 250m
Liveness: exec [/bin/calico-node -felix-live -bird-live] delay=10s timeout=1s period=10s #success=1 #failure=6
Readiness: exec [/bin/calico-node -felix-ready -bird-ready] delay=0s timeout=1s period=10s #success=1 #failure=3
Environment:
DATASTORE_TYPE: kubernetes
WAIT_FOR_DATASTORE: true
NODENAME: (v1:spec.nodeName)
CLUSTER_TYPE: k8s,bgp
IP: autodetect
CALICO_IPV4POOL_IPIP: Always
CALICO_IPV4POOL_VXLAN: Never
FELIX_IPINIPMTU: <set to the key 'veth_mtu' of config map 'calico-config'> Optional: false
FELIX_VXLANMTU: <set to the key 'veth_mtu' of config map 'calico-config'> Optional: false
FELIX_WIREGUARDMTU: <set to the key 'veth_mtu' of config map 'calico-config'> Optional: false
CALICO_IPV4POOL_CIDR: 10.233.64.0/18
CALICO_IPV4POOL_BLOCK_SIZE: 24
CALICO_DISABLE_FILE_LOGGING: true
FELIX_DEFAULTENDPOINTTOHOSTACTION: ACCEPT
FELIX_IPV6SUPPORT: false
FELIX_LOGSEVERITYSCREEN: info
FELIX_HEALTHENABLED: true
Mounts:
/lib/modules from lib-modules (ro)
/run/xtables.lock from xtables-lock (rw)
/var/lib/calico from var-lib-calico (rw)
/var/run/calico from var-run-calico (rw)
/var/run/nodeagent from policysync (rw)
Conditions:
Type Status
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
lib-modules:
Type: HostPath (bare host directory volume)
Path: /lib/modules
HostPathType:
var-run-calico:
Path: /var/run/calico
HostPathType:
var-lib-calico:
Path: /var/lib/calico
HostPathType:
xtables-lock:
Path: /run/xtables.lock
HostPathType: FileOrCreate
cni-bin-dir:
Path: /opt/cni/bin
HostPathType:
cni-net-dir:
Path: /etc/cni/net.d
HostPathType:
host-local-net-dir:
Path: /var/lib/cni/networks
HostPathType:
policysync:
Path: /var/run/nodeagent
HostPathType: DirectoryOrCreate
flexvol-driver-host:
Path: /usr/libexec/kubernetes/kubelet-plugins/volume/exec/nodeagent~uds
calico-node-token-j29zs:
SecretName: calico-node-token-j29zs
Optional: false
QoS Class: Burstable
Node-Selectors: kubernetes.io/os=linux
Tolerations: :NoSchedule
:NoExecute
CriticalAddonsOnly
node.kubernetes.io/disk-pressure:NoSchedule
node.kubernetes.io/memory-pressure:NoSchedule
node.kubernetes.io/network-unavailable:NoSchedule
node.kubernetes.io/not-ready:NoExecute
node.kubernetes.io/pid-pressure:NoSchedule
node.kubernetes.io/unreachable:NoExecute
node.kubernetes.io/unschedulable:NoSchedule
Events:
Type Reason Age From Message
Warning Unhealthy 3m47s (x1462 over 4h7m) kubelet, node2 (combined from similar events): Readiness probe failed: 2020-08-26 10:03:57.161 [INFO][16418] confd/health.go 180: Number of node(s) with BGP peering established = 0
calico/node is not ready: BIRD is not ready: BGP not established with 172.21.0.1
