离线部署,elastcsearch-logging-curator-elastcsearch-curator和jaeger-es-index-cleaner容器一直正在拉取镜像,请问要如何解决?
    hkstudio jaegertracing/jaeger-es-index-cleaner:1.17.1这个镜像已存在,elastcsearch-logging-curator-elastcsearch-curator该job对应的镜像为kubesphere/elasticsearch-curator:v5.7.6, 这个镜像也存在,你是否通过上面的链接下载的呢?对照下md5值。
    # md5: 65e9a1158a682412faa1166c0cf06772
    curl -Ok https://kubesphere-installer.pek3b.qingstor.com/offline/v3.0.0/kubesphere-all-v3.0.0-offline-linux-amd64.tar.gz
    [root@ks-allinone kubesphere-images-v3.0.0]# docker load -i ks_logger_images.tar
    Loaded image: kubesphere/elasticsearch-curator:v5.7.6
    ace0eda3e3be: Loading layer [==================================================>]  5.843MB/5.843MB
    911954e2fe49: Loading layer [==================================================>]   5.54MB/5.54MB
    31b11ec6ff38: Loading layer [==================================================>]   2.56kB/2.56kB
    Feynman 可以直接提供离线镜像包吗,不用自己在本地拉取了,理论上可以复用kubekey离线包
    cd xx
    sh push-image.sh <local_registry>
    或者在打一个不包含kubekey和kubernetes镜像的包。
    我目前可以这样部署,还是有点繁琐,
    1、create_project_harbor.sh没有包含在离线包里
    2、要改create_project_harbor.sh,现在registry都是基于registry v2了吧
    3、kubesphere-all-v3.0.0-offline-linux-amd64.tar.gz这个包略大一些,不过也大不是很多
    基于k8s 离线部署kubesphere
    1、准备harbor镜像仓库,镜像仓库地址:http://192.168.93.9
    2、下载kubesphere离线镜像包并解压
    tar -zxvf kubesphere-all-v3.0.0-offline-linux-amd64.tar.gz
    3、推送镜像到harbor仓库
    下载脚本
    wget https://raw.githubusercontent.com/kubesphere/ks-installer/master/scripts/create_project_harbor.sh
    修改create_project_harbor.sh脚本,指定镜像仓库地址和登录信息:
    url="http://192.168.93.9"
    user="admin"
    passwd="Harbor12345"
    如果使用2.x版本harbor修改最后行为以下内容:
    ${url}/api/v2.0/projects
    创建项目
    sh create_project_harbor.sh
    推送镜像到私有镜像仓库
    cd kubesphere-all-v3.0.0-offline-linux-amd64/kubesphere-images-v3.0.0
    sh push-images.sh 192.168.93.9
    3、部署kubesphere容器平台
    helm repo add test https://charts.kubesphere.io/test
    helm pull test/ks-installer
    tar -zxvf ks-installer-0.2.1.tgz
    helm install kubesphere \
      --namespace=kubesphere-system \
      --create-namespace \
      --set image.repository=192.168.93.9/kubesphere/ks-installer \
      --set image.tag=v3.0.0 \
      --set persistence.storageClass=longhorn \
      --set .registry=192.168.93.9 \
      ./ks-installer
    csz711
    多谢提醒,后边我们补充下
    可以先自己尝试导入下flannel镜像
    只有一个:kubesphere/flannel:v0.12.0
    10 天 后
    离线包中没有jaegertracing/jaeger-es-index-cleaner的镜像,解决方法:先将镜像下载到本地,然后手动导入:
    1. docker pull jaegertracing/jaeger-es-index-cleaner:1.17
    2. docker save -o jaeger-es-index-cleaner.tar jaegertracing/jaeger-es-index-cleaner:1.17
    3. docker load -i jaeger-es-index-cleaner.tar
    请问下要是用本地镜像,配置文件里面镜像那边应该写什么?
    registry:
    registryMirrors: []
    insecureRegistries: []
    privateRegistry: dockerhub.kubekey.local
    privateRegistry这个参数后面是 privateRegistry: []这样写吗
    请问可以只使用本地镜像,不拉取镜像仓库的镜像吗
      lmc920213 只要在privateRegistry下写镜像仓库就行,镜像仓库双引号“”包含就行。不会去别的镜像仓库拉取。
        Forest-L 多谢指导,再请教个问题,我centos部署环境只有sudo权限,配置文件 用户名user那边应该怎么写
        user: root,这里是写 user: sudo 吗
          您好,我在本地部署kubeSphere3.0 使用自己的harbor报错。
          执行 ./push-images.sh sk.reiat.com
          镜像载入过程过去以后,push环节开始报类似于:an image does not exist locally with the tag: sk.reiat.com/csplugin/csi-neonsan-centos这种错误
          在config-sample.yaml中,已经写了privateRegistry: https://sk.reiat.com
          好像在2.0中有更改tag.sh来适配harbor的选项,3.0没有了,不知道该怎么做。
            lmc920213
            用哪个user就填哪个user,但要保证这个user具有sudo权限。
            mirror_eclia
            看信息是本地没有相关的镜像,可以docker images看下有木有错误信息中的镜像,是不是机器存储空间不够了,导致镜像数据丢失。
              Cauchy 您好,我看了本地没有镜像,但是编译过程却有docker load的过程显示。我尝试手动load镜像再进行tag,却发现载入后的镜像过一会用docker images查看时会自己消失。使用free -h 查看,可用空间59G,空闲16G,应该不是存储空间不够吧,还可能是什么问题呢?
                6 天 后
                Cauchy 可使用harbor或其他第三方镜像仓库。
                请问下这里该如何使用harbor作为第三方镜像仓库,该如何配置呢?
                这东西装到肾虚,就为学习一下,折腾了几个月,找不到一个讲清楚的,各种坑,拿到真实环境怎么用啊,伤不起啊…
