TASK [common : KubeSphere | Create ImagePullSecrets] ***************************
changed: [localhost] => (item=default)
changed: [localhost] => (item=kube-public)
E0908 10:20:51.794657 1 reflector.go:283] github.com/flant/shell-operator/pkg/kube_events_manager/kube_events_manager.go:354: Failed to watch *unstructured.Unstructured: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-system/configmaps?fieldSelector=metadata.name%3Dks-installer&resourceVersion=5483&timeoutSeconds=582&watch=true: dial tcp 10.233.0.1:443: connect: connection refused
failed: [localhost] (item=kube-system) => {“ansible_loop_var”: “item”, “changed”: true, “cmd”: "cat <<EOF | kubectl apply -f -\n apiVersion: v1\n kind: Secret\n metadata:\n name: qingcloud\n namespace: \“kube-system\”\n data:\n .dockerconfigjson: eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\n type: kubernetes.io/dockerconfigjson\nEOF\n", “delta”: “0:00:37.597335”, “end”: “2020-09-08 10:20:51.797072″, “item”: “kube-system”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-09-08 10:20:14.199737”, “stderr”: "error: error when creating \“STDIN\”: Post https://10.233.0.1:443/api/v1/namespaces/kube-system/secrets: unexpected EOF", “stderr_lines”: ["error: error when creating \“STDIN\”: Post https://10.233.0.1:443/api/v1/namespaces/kube-system/secrets: unexpected EOF"], “stdout”: "", “stdout_lines”: []}
failed: [localhost] (item=kubesphere-system) => {“ansible_loop_var”: “item”, “changed”: true, “cmd”: "cat <<EOF | kubectl apply -f -\n apiVersion: v1\n kind: Secret\n metadata:\n name: qingcloud\n namespace: \“kubesphere-system\”\n data:\n .dockerconfigjson: eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\n type: kubernetes.io/dockerconfigjson\nEOF\n", “delta”: “0:00:00.395957″, “end”: “2020-09-08 10:20:52.349092”, “item”: “kubesphere-system”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-09-08 10:20:51.953135”, “stderr”: “error: error when retrieving current configuration of:\nResource: \”/v1, Resource=secrets\“, GroupVersionKind: \”/v1, Kind=Secret\"\nName: \“qingcloud\”, Namespace: \“kubesphere-system\”\nObject: &{map[\“apiVersion\”:\“v1\” \“data\”:map[\“.dockerconfigjson\”:\“eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\”] \“kind\”:\“Secret\” \“metadata\”:map[\“annotations\”:map[\“kubectl.kubernetes.io/last-applied-configuration\”:\“\”] \“name\”:\“qingcloud\” \“namespace\”:\“kubesphere-system\”] \“type\”:\“kubernetes.io/dockerconfigjson\”]}\nfrom server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-system/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused", “stderr_lines”: [“error: error when retrieving current configuration of:”, “Resource: \”/v1, Resource=secrets\“, GroupVersionKind: \”/v1, Kind=Secret\"", "Name: \“qingcloud\”, Namespace: \“kubesphere-system\”", "Object: &{map[\“apiVersion\”:\“v1\” \“data\”:map[\“.dockerconfigjson\”:\“eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\”] \“kind\”:\“Secret\” \“metadata\”:map[\“annotations\”:map[\“kubectl.kubernetes.io/last-applied-configuration\”:\“\”] \“name\”:\“qingcloud\” \“namespace\”:\“kubesphere-system\”] \“type\”:\“kubernetes.io/dockerconfigjson\”]}", "from server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-system/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused"], “stdout”: "", “stdout_lines”: []}
E0908 10:20:52.796605 1 reflector.go:125] github.com/flant/shell-operator/pkg/kube_events_manager/kube_events_manager.go:354: Failed to list *unstructured.Unstructured: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-system/configmaps?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0: dial tcp 10.233.0.1:443: connect: connection refused
failed: [localhost] (item=kubesphere-controls-system) => {“ansible_loop_var”: “item”, “changed”: true, “cmd”: "cat <<EOF | kubectl apply -f -\n apiVersion: v1\n kind: Secret\n metadata:\n name: qingcloud\n namespace: \“kubesphere-controls-system\”\n data:\n .dockerconfigjson: eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\n type: kubernetes.io/dockerconfigjson\nEOF\n", “delta”: “0:00:00.377634”, “end”: “2020-09-08 10:20:52.869022”, “item”: “kubesphere-controls-system”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-09-08 10:20:52.491388″, “stderr”: “error: error when retrieving current configuration of:\nResource: \”/v1, Resource=secrets\“, GroupVersionKind: \”/v1, Kind=Secret\"\nName: \“qingcloud\”, Namespace: \“kubesphere-controls-system\”\nObject: &{map[\“apiVersion\”:\“v1\” \“data\”:map[\“.dockerconfigjson\”:\“eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\”] \“kind\”:\“Secret\” \“metadata\”:map[\“annotations\”:map[\“kubectl.kubernetes.io/last-applied-configuration\”:\“\”] \“name\”:\“qingcloud\” \“namespace\”:\“kubesphere-controls-system\”] \“type\”:\“kubernetes.io/dockerconfigjson\”]}\nfrom server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-controls-system/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused", “stderr_lines”: [“error: error when retrieving current configuration of:”, “Resource: \”/v1, Resource=secrets\“, GroupVersionKind: \”/v1, Kind=Secret\"", "Name: \“qingcloud\”, Namespace: \“kubesphere-controls-system\”", "Object: &{map[\“apiVersion\”:\“v1\” \“data\”:map[\“.dockerconfigjson\”:\“eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\”] \“kind\”:\“Secret\” \“metadata\”:map[\“annotations\”:map[\“kubectl.kubernetes.io/last-applied-configuration\”:\“\”] \“name\”:\“qingcloud\” \“namespace\”:\“kubesphere-controls-system\”] \“type\”:\“kubernetes.io/dockerconfigjson\”]}", "from server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-controls-system/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused"], “stdout”: "", “stdout_lines”: []}
failed: [localhost] (item=kubesphere-monitoring-system) => {“ansible_loop_var”: “item”, “changed”: true, “cmd”: "cat <<EOF | kubectl apply -f -\n apiVersion: v1\n kind: Secret\n metadata:\n name: qingcloud\n namespace: \“kubesphere-monitoring-system\”\n data:\n .dockerconfigjson: eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\n type: kubernetes.io/dockerconfigjson\nEOF\n", “delta”: “0:00:00.348856″, “end”: “2020-09-08 10:20:53.362975”, “item”: “kubesphere-monitoring-system”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-09-08 10:20:53.014119”, “stderr”: “error: error when retrieving current configuration of:\nResource: \”/v1, Resource=secrets\“, GroupVersionKind: \”/v1, Kind=Secret\"\nName: \“qingcloud\”, Namespace: \“kubesphere-monitoring-system\”\nObject: &{map[\“apiVersion\”:\“v1\” \“data\”:map[\“.dockerconfigjson\”:\“eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\”] \“kind\”:\“Secret\” \“metadata\”:map[\“annotations\”:map[\“kubectl.kubernetes.io/last-applied-configuration\”:\“\”] \“name\”:\“qingcloud\” \“namespace\”:\“kubesphere-monitoring-system\”] \“type\”:\“kubernetes.io/dockerconfigjson\”]}\nfrom server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused", “stderr_lines”: [“error: error when retrieving current configuration of:”, “Resource: \”/v1, Resource=secrets\“, GroupVersionKind: \”/v1, Kind=Secret\"", "Name: \“qingcloud\”, Namespace: \“kubesphere-monitoring-system\”", "Object: &{map[\“apiVersion\”:\“v1\” \“data\”:map[\“.dockerconfigjson\”:\“eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\”] \“kind\”:\“Secret\” \“metadata\”:map[\“annotations\”:map[\“kubectl.kubernetes.io/last-applied-configuration\”:\“\”] \“name\”:\“qingcloud\” \“namespace\”:\“kubesphere-monitoring-system\”] \“type\”:\“kubernetes.io/dockerconfigjson\”]}", "from server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused"], “stdout”: "", “stdout_lines”: []}
E0908 10:20:53.797341 1 reflector.go:125] github.com/flant/shell-operator/pkg/kube_events_manager/kube_events_manager.go:354: Failed to list *unstructured.Unstructured: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-system/configmaps?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0: dial tcp 10.233.0.1:443: connect: connection refused
server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kube-node-lease/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused"], “stdout”: "", “stdout_lines”: []}
failed: [localhost] (item=kube-node-lease) => {“ansible_loop_var”: “item”, “changed”: true, “cmd”: "cat <<EOF | kubectl apply -f -\n apiVersion: v1\n kind: Secret\n metadata:\n name: qingcloud\n namespace: \“kube-node-lease\”\n data:\n .dockerconfigjson: eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\n type: kubernetes.io/dockerconfigjson\nEOF\n", “delta”: “0:00:00.349813″, “end”: “2020-09-08 10:20:53.857083″, “item”: “kube-node-lease”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-09-08 10:20:53.507270″, “stderr”: “error: error when retrieving current configuration of:\nResource: \”/v1, Resource=secrets\“, GroupVersionKind: \”/v1, Kind=Secret\"\nName: \“qingcloud\”, Namespace: \“kube-node-lease\”\nObject: &{map[\“apiVersion\”:\“v1\” \“data\”:map[\“.dockerconfigjson\”:\“eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\”] \“kind\”:\“Secret\” \“metadata\”:map[\“annotations\”:map[\“kubectl.kubernetes.io/last-applied-configuration\”:\“\”] \“name\”:\“qingcloud\” \“namespace\”:\“kube-node-lease\”] \“type\”:\“kubernetes.io/dockerconfigjson\”]}\nfrom server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kube-node-lease/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused", “stderr_lines”: [“error: error when retrieving current configuration of:”, “Resource: \”/v1, Resource=secrets\“, GroupVersionKind: \”/v1, Kind=Secret\"", "Name: \“qingcloud\”, Namespace: \“kube-node-lease\”", "Object: &{map[\“apiVersion\”:\“v1\” \“data\”:map[\“.dockerconfigjson\”:\“eyJhdXRocyI6eyJkb2NrZXJodWIucWluZ2Nsb3VkLmNvbSI6eyJhdXRoIjoiWjNWbGMzUTZaM1ZsYzNRPSJ9fX0=\”] \“kind\”:\“Secret\” \“metadata\”:map[\“annotations\”:map[\“kubectl.kubernetes.io/last-applied-configuration\”:\“\”] \“name\”:\“qingcloud\” \“namespace\”:\“kube-node-lease\”] \“type\”:\“kubernetes.io/dockerconfigjson\”]}", "from server for: \“STDIN\”: Get https://10.233.0.1:443/api/v1/namespaces/kube-node-lease/secrets/qingcloud: dial tcp 10.233.0.1:443: connect: connection refused"], “stdout”: "", “stdout_lines”: []}
localhost : ok=7 changed=3 unreachable=0 failed=1 skipped=3 rescued=0 ignored=0
E0908 10:20:54.798519 1 reflector.go:125] github.com/flant/shell-operator/pkg/kube_events_manager/kube_events_manager.go:354: Failed to list *unstructured.Unstructured: Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-system/configmaps?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0: dial tcp 10.233.0.1:443: connect: connection refused
