虚拟机,Centos7.9,8C/32G
将 kubectl version
命令执行结果贴在下方
Client Version: version.Info{Major:"1", Minor:"23", GitVersion:"v1.23.10", GitCommit:"7e54d50d3012cf3389e43b096ba35300f36e0817", GitTreeState:"clean", BuildDate:"2022-08-17T18:32:54Z", GoVersion:"go1.17.13", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"23", GitVersion:"v1.23.10", GitCommit:"7e54d50d3012cf3389e43b096ba35300f36e0817", GitTreeState:"clean", BuildDate:"2022-08-17T18:26:59Z", GoVersion:"go1.17.13", Compiler:"gc", Platform:"linux/amd64"}
Client:
Version: 20.10.8
API version: 1.41
Go version: go1.16.6
Git commit: 3967b7d
Experimental: true
Version: 20.10.8
Git commit: 75249d8
Version: v1.4.9
Version: 1.0.1
GitCommit: v1.0.1-0-g4144b638
Version: 0.19.0
GitCommit: de40ad0
3.3.2。离线安装。kk安装。
脚本如下:
pipeline {
agent {
node {
label 'python'
environment {
KUBECONFIG_CREDENTIAL_ID = 'kubeconfig'
REGISTRY = 'registry.cn-hangzhou.aliyuncs.com'
DOCKERHUB_NAMESPACE = 'ishare'
APP_NAME = 'demo'
stages {
stage('clone code') {
agent none
steps {
container('python') {
git(url: 'https://codeup.aliyun.com/5f3bffa4df9df74e36afded2/docker_test.git', credentialsId: 'code', branch: 'master', changelog: true, poll: false)
stage('build & push') {
agent none
steps {
withCredentials([usernamePassword(credentialsId : 'ali-docker-hub' ,passwordVariable : 'DOCKER_PASSWORD' ,usernameVariable : 'DOCKER_USERNAME' ,)]) {
sh 'echo "$DOCKER_PASSWORD" | docker login $REGISTRY -u "$DOCKER_USERNAME" --password-stdin'
sh 'docker build -t $REGISTRY/$DOCKERHUB_NAMESPACE/$APP_NAME:$BUILD_NUMBER .'
sh '''docker push $REGISTRY/$DOCKERHUB_NAMESPACE/$APP_NAME:$BUILD_NUMBER
docker rmi $REGISTRY/$DOCKERHUB_NAMESPACE/$APP_NAME:$BUILD_NUMBER'''
stage('run') {
agent none
steps {
withCredentials([kubeconfigContent(credentialsId : 'kubeconfig' ,variable : 'KUBECONFIG_CONFIG' ,)]) {
sh '''mkdir -p ~/.kube/
echo "$KUBECONFIG_CONFIG" > ~/.kube/config
envsubst < deploy/dev.yaml | kubectl apply -f -'''
parameters {
string(name: 'BRANCH_NAME', defaultValue: 'master', description: '')
