3台云服务器
例如:多节点。
例如,使用 docker/containerd,版本多少
例如:v3.3.0。在线安装。全套安装。
Caused: java.io.IOException: Unable to read /var/jenkins_home/jobs/test-cjrh9c6zq/jobs/test-cjrh-frontend-h5/config.xml
at hudson.XmlFile.read(XmlFile.java:165)
at com.cloudbees.hudson.plugins.folder.AbstractFolder.loadChildren(AbstractFolder.java:399)
at com.cloudbees.hudson.plugins.folder.AbstractFolder.onLoad(AbstractFolder.java:560)
at com.cloudbees.hudson.plugins.folder.Folder.onLoad(Folder.java:109)
at hudson.model.Items.load(Items.java:376)
at jenkins.model.Jenkins$13.run(Jenkins.java:3372)
at org.jvnet.hudson.reactor.TaskGraphBuilder$TaskImpl.run(TaskGraphBuilder.java:169)
at org.jvnet.hudson.reactor.Reactor.runTask(Reactor.java:296)
at jenkins.model.Jenkins$5.runTask(Jenkins.java:1151)
at org.jvnet.hudson.reactor.Reactor$2.run(Reactor.java:214)
at org.jvnet.hudson.reactor.Reactor$Node.run(Reactor.java:117)
at jenkins.security.ImpersonatingExecutorService$1.run(ImpersonatingExecutorService.java:68)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
2023-04-28 02:14:40.719+0000 [id=30] SEVERE jenkins.InitReactorRunner$1#onTaskFailed: Failed ConfigurationAsCode.init
java.lang.IllegalArgumentException: No hudson.slaves.Cloud implementation found for kubernetes
at io.jenkins.plugins.casc.impl.configurators.HeteroDescribableConfigurator.lambda$lookupDescriptor$11(HeteroDescribableConfigurator.java:211)
at io.vavr.control.Option.orElse(Option.java:321)
at io.jenkins.plugins.casc.impl.configurators.HeteroDescribableConfigurator.lookupDescriptor(HeteroDescribableConfigurator.java:210)
at io.jenkins.plugins.casc.impl.configurators.HeteroDescribableConfigurator.lambda$configure$3(HeteroDescribableConfigurator.java:84)
at io.vavr.Tuple2.apply(Tuple2.java:238)
at io.jenkins.plugins.casc.impl.configurators.HeteroDescribableConfigurator.configure(HeteroDescribableConfigurator.java:83)
at io.jenkins.plugins.casc.impl.configurators.HeteroDescribableConfigurator.check(HeteroDescribableConfigurator.java:92)
at io.jenkins.plugins.casc.impl.configurators.HeteroDescribableConfigurator.check(HeteroDescribableConfigurator.java:55)
at io.jenkins.plugins.casc.BaseConfigurator.configure(BaseConfigurator.java:343)
at io.jenkins.plugins.casc.BaseConfigurator.check(BaseConfigurator.java:286)
at io.jenkins.plugins.casc.ConfigurationAsCode.lambda$checkWith$8(ConfigurationAsCode.java:776)
at io.jenkins.plugins.casc.ConfigurationAsCode.invokeWith(ConfigurationAsCode.java:712)
at io.jenkins.plugins.casc.ConfigurationAsCode.checkWith(ConfigurationAsCode.java:776)
at io.jenkins.plugins.casc.ConfigurationAsCode.configureWith(ConfigurationAsCode.java:761)
at io.jenkins.plugins.casc.ConfigurationAsCode.configureWith(ConfigurationAsCode.java:637)
at io.jenkins.plugins.casc.ConfigurationAsCode.configure(ConfigurationAsCode.java:306)
at io.jenkins.plugins.casc.ConfigurationAsCode.init(ConfigurationAsCode.java:298)
Caused: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at hudson.init.TaskMethodFinder.invoke(TaskMethodFinder.java:104)
Caused: java.lang.Error
at hudson.init.TaskMethodFinder.invoke(TaskMethodFinder.java:110)
at hudson.init.TaskMethodFinder$TaskImpl.run(TaskMethodFinder.java:180)
2023-04-28 02:14:40.721+0000 [id=23] SEVERE hudson.util.BootFailure#publish: Failed to initialize Jenkins
Caused: org.jvnet.hudson.reactor.ReactorException
at org.jvnet.hudson.reactor.Reactor.execute(Reactor.java:282)
at jenkins.InitReactorRunner.run(InitReactorRunner.java:49)
at jenkins.model.Jenkins.executeReactor(Jenkins.java:1184)
at jenkins.model.Jenkins.<init>(Jenkins.java:976)
at hudson.model.Hudson.<init>(Hudson.java:85)
at hudson.model.Hudson.<init>(Hudson.java:81)
at hudson.WebAppMain$3.run(WebAppMain.java:298)
Caused: hudson.util.HudsonFailedToLoad
at hudson.WebAppMain$3.run(WebAppMain.java:315)
2023-04-28 02:14:40.892+0000 [id=23] INFO jenkins.model.Jenkins#cleanUp: Stopping Jenkins
2023-04-28 02:14:40.898+0000 [id=23] INFO jenkins.model.Jenkins$16#onAttained: Started termination
2023-04-28 02:14:40.911+0000 [id=23] INFO jenkins.model.Jenkins$16#onAttained: Completed termination
2023-04-28 02:14:40.911+0000 [id=23] INFO jenkins.model.Jenkins#_cleanUpDisconnectComputers: Starting node disconnection
2023-04-28 02:14:40.914+0000 [id=23] INFO jenkins.model.Jenkins#_cleanUpShutdownPluginManager: Stopping plugin manager
2023-04-28 02:14:40.935+0000 [id=23] INFO jenkins.model.Jenkins#_cleanUpPersistQueue: Persisting build queue
2023-04-28 02:14:41.480+0000 [id=23] INFO jenkins.model.Jenkins#_cleanUpAwaitDisconnects: Waiting for node disconnection completion
2023-04-28 02:14:41.480+0000 [id=23] INFO jenkins.model.Jenkins#cleanUp: Jenkins stopped
