虚拟机,Ubuntu22.04
k8s 1.25.9
RuntimeVersion: 1.6.12-0ubuntu1~22.04.1
v3.3.2。离线安装,已有K8s上安装。
启动devops后ks-controller-manager无限重启,镜像ks-controller-manager:v3.3.2、openpitrix-jobs:v3.3.2
下方服务都起不来
ks-apiserver-f4c55c467-7ddhz 1/1 Running 0 17h
ks-console-78b55f66f7-prl8j 1/1 Running 0 17h
ks-controller-manager-6784c884bd-xx7dz 0/1 CrashLoopBackOff 7 (3m ago) 13m
ks-installer-7d54ddf867-l2z42 1/1 Running 0 17h
minio-6fcb7856c9-dtjx8 1/1 Running 0 17h
openldap-0 0/1 Pending 0 96m
openpitrix-import-job-6c8k4 0/1 Completed 0 72m
ks-controller-manager-6784c884bd-xx7dz 1/1 Running 8 (5m15s ago) 16m
ks-controller-manager-6784c884bd-xx7dz 0/1 Error 8 (5m16s ago) 16m
ks-controller-manager-6784c884bd-xx7dz 0/1 CrashLoopBackOff 8 (11s ago) 16m
kubectl logs -n kubesphere-system ks-controller-manager-6784c884bd-xx7dz
W0606 09:27:16.365286 1 client_config.go:615] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
I0606 09:27:16.372683 1 server.go:202] setting up manager
I0606 09:27:16.456257 1 deleg.go:130] controller-runtime/metrics "msg"="metrics server is starting to listen" "addr"=":8080"
F0606 09:27:16.540036 1 server.go:224] unable to register controllers to the manager: failed to connect to ldap service, please check ldap status, err the pool: LDAP Result Code 200 "Network Error": dial tcp: lookup openldap.kubesphere-system.svc on 10.96.0.10:53: no such host
Events:
Type Reason Age From Message
Normal Scheduled 26m default-scheduler Successfully assigned kubesphere-system/ks-controller-manager-6784c884bd-xx7dz to master
Normal Pulled 25m (x5 over 26m) kubelet Container image "kubesphere/ks-controller-manager:v3.3.2" already present on machine
Normal Created 25m (x5 over 26m) kubelet Created container ks-controller-manager
Normal Started 25m (x5 over 26m) kubelet Started container ks-controller-manager
Warning BackOff 106s (x117 over 26m) kubelet Back-off restarting failed container
