Centos7.9
将 kubectl version
命令执行结果贴在下方
Client Version: version.Info{Major:“1”, Minor:“23”, GitVersion:“v1.23.6”, GitCommit:“ad3338546da947756e8a88aa6822e9c11e7eac22”, GitTreeState:“clean”, BuildDate:“2022-04-14T08:49:13Z”, GoVersion:“go1.17.9”, Compiler:“gc”, Platform:“linux/amd64”}
The connection to the server lb.kubesphere.local:6443 was refused - did you specify the right host or port?
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
[root@k8s-m3 ~]# docker version
Version: 20.10.24
API version: 1.41
Go version: go1.19.7
Git commit: 297e128
Built: Tue Apr 4 18:22:57 2023
Experimental: true
Version: 20.10.24
Git commit: 5d6db84
Built: Tue Apr 4 18:21:02 2023
Version: 1.6.21
GitCommit: 3dce8eb055cbb6872793272b4f20ed16117344f8
Version: 1.1.7
GitCommit: v1.1.7-0-g860f061
Version: 0.19.0
GitCommit: de40ad0
使用kk安装./kk create config –with-kubernetes v1.23.6
{name: k8s-m1, address: 192.168.1.31, internalAddress: 192.168.1.31, user: root, password: “root123”}
{name: k8s-m2, address: 192.168.1.32, internalAddress: 192.168.1.32, user: root, password: “root123”}
{name: k8s-m3, address: 192.168.1.33, internalAddress: 192.168.1.33, user: root, password: “root123”}
其中一台服务器重装系统之后,执行命令:./kk add nodes -f config-sample.yaml
执行之后,本来还正常的另外两台服务器报错,整个k8s全挂了。
