• KSV
  • 多集群管理kubefed-controller-manager一直无法正常运行
系统环境:Centos 7.9系统。k8s 1.22版本,kubesphere3.3.1版本 ,基于kubernetes平台最小化安装kubesphere
开启多集群管理方式,发现kubefed-controller-manager的pod一直CrashLoopBackOff, kubectl logs 看日志发现报错报错如下
W0804 02:47:49.609868 1 client_config.go:615] Neither –kubeconfig nor –master was specified. Using the inClusterConfig. This might not work.
I0804 02:47:49.610058 1 controller-manager.go:428] starting metrics server path /metrics
I0804 02:47:49.660695 1 controller-manager.go:225] Cannot retrieve KubeFedConfig “kube-federation-system/kubefed”: kubefedconfigs.core.kubefed.io “kubefed” not found. Default options will be used.
I0804 02:47:49.660721 1 controller-manager.go:328] Creating KubeFedConfig “kube-federation-system/kubefed” with default values
F0804 02:47:49.676414 1 controller-manager.go:299] Error creating KubeFedConfig “kube-federation-system/kubefed”: Internal error occurred: failed calling webhook “kubefedconfigs.core.kubefed.io”: Post “https://kubefed-admission-webhook.kube-federation-system.svc:443/validate-kubefedconfig?timeout=10s”: x509: certificate signed by unknown authority (possibly because of “crypto/rsa: verification error” while trying to verify candidate authority certificate “kubefed-admission-webhook-ca”)
goroutine 1 [running]:
另外我执行kubectl -n kube-federation-system get kubefedconfigs.core.kubefed.io命令发现空的
为什么它下面什么都没有呢?
