虚拟机,Centos7.9,8C/8G
kubectl version
Client Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.5”, GitCommit:“aea7bbadd2fc0cd689de94a54e5b7b758869d691”, GitTreeState:“clean”, BuildDate:“2021-09-15T21:10:45Z”, GoVersion:“go1.16.8”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.5”, GitCommit:“aea7bbadd2fc0cd689de94a54e5b7b758869d691”, GitTreeState:“clean”, BuildDate:“2021-09-15T21:04:16Z”, GoVersion:“go1.16.8”, Compiler:“gc”, Platform:“linux/amd64”}
容器运行时日志
查看notification-manager容器日志,发现都是下列信息。
level=info ts=2023-08-17T15:37:22.588436607+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:37:32.395501756+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:38:01.16277257+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:38:11.192380359+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:43:29.245290998+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:43:39.664292142+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:43:39.801686382+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:43:49.698581957+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:43:50.619082731+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
level=info ts=2023-08-17T15:43:59.723409565+08:00 caller=config.go:601 msg=“resource change” op=add name=default-wechat-config
kubesphere版本:v3.2.1
问题现象:
通过IP:30880 界面配置企微报警通知,修改里面内容后,点击确定无反应。
