• 微服务Bug
  • 启用ServiceMesh后,自定义envoyfilter无效(直接在未安装kubesphere的K8S集群上验证是OK的)
例如:虚拟机 Ubuntu20.04,4C/8G
Client Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.12”, GitCommit:“b058e1760c79f46a834ba59bd7a3486ecf28237d”, GitTreeState:“clean”, BuildDate:“2022-07-13T14:59:18Z”, GoVersion:“go1.16.15”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.12”, GitCommit:“b058e1760c79f46a834ba59bd7a3486ecf28237d”, GitTreeState:“clean”, BuildDate:“2022-07-13T14:53:39Z”, GoVersion:“go1.16.15”, Compiler:“gc”, Platform:“linux/amd64”}
Client:
 Version:           20.10.8
 API version:       1.41
 Go version:        go1.16.6
 Git commit:        3967b7d
 Built:             Fri Jul 30 19:50:40 2021
 OS/Arch:           linux/amd64
 Context:           default
 Experimental:      true
  Version:          20.10.8
  API version:      1.41 (minimum version 1.12)
  Git commit:       75249d8
  Built:            Fri Jul 30 19:55:09 2021
  Experimental:     false
  Version:          v1.4.9
  GitCommit:        e25210fe30a0a703442421b0f60afac609f950a3
  Version:          1.0.1
  GitCommit:        v1.0.1-0-g4144b638
  Version:          0.19.0
  GitCommit:        de40ad0
例如:v2.2.1/v3.3.2。离线安装还是在线安装。使用kk安装。
启用ServiceMesh后,创建示例应用bookinfo,然后自定义envoyfilter,可以生效
然后创建自定义应用productpage,应用名称为ppp,然后自定义envoyfilter,不生效
同时测试两个服务,示例应用bookinfo的envoyfilter有效,自定义应用ppp的envoyfilter无效
