• KSV
  • cloudcore故障
#问题背景描述如下
我有个虚拟机83,不用了,计划回收
虚拟机83 作为edge node 之前加入到了KS中了,名称是edgenode-83
我正常先把edgenode-83 从KS中删除,执行如下命令:
kubectl drain edgenode-83 –delete-emptydir-data –force –ignore-daemonsets
kubectl delete nodes edgenode-83
然后,cloudcore重启,则会 cloudcore出现故障了,cloudcore无法正常运行, cloudcore的端口30000, 30004
其他edge node 不能连接了, 报错time out
cloud具体报错log在最下面
-- 我的手机号(微信) 18521096651 , 如果有老师遇到过, 有解决的经验, 及时与我沟通,谢谢哈
虚拟机,Centos7.9,8C/16G
[root@master11 ~]# cat /etc/redhat-release
CentOS Linux release 7.9.2009 (Core)
[root@master11 ~]# docker version
Client:
Version: 20.10.8
API version: 1.41
Go version: go1.16.6
Git commit: 3967b7d
Experimental: true
Version: 20.10.8
Git commit: 75249d8
Version: v1.4.9
Version: 1.0.1
GitCommit: v1.0.1-0-g4144b638
Version: 0.19.0
GitCommit: de40ad0
[root@master11 ~]# crictl version
-bash: crictl: 未找到命令
[root@master11 ~]#
[root@master11 ~]# nerdctl version
-bash: nerdctl: 未找到命令
版本是v3.3.2。
离线安装。
kk安装的
[root@master11 ~]# kubectl version
Client Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.5”, GitCommit:“aea7bbadd2fc0cd689de94a54e5b7b758869d691”, GitTreeState:“clean”, BuildDate:“2021-09-15T21:10:45Z”, GoVersion:“go1.16.8”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.5”, GitCommit:“aea7bbadd2fc0cd689de94a54e5b7b758869d691”, GitTreeState:“clean”, BuildDate:“2021-09-15T21:04:16Z”, GoVersion:“go1.16.8”, Compiler:“gc”, Platform:“linux/amd64”}
容器日志
W0828 10:56:18.756174 1 validation.go:154] TLSTunnelPrivateKeyFile does not exist in /etc/kubeedge/certs/server.key, will load from secret
W0828 10:56:18.756282 1 validation.go:157] TLSTunnelCertFile does not exist in /etc/kubeedge/certs/server.crt, will load from secret
W0828 10:56:18.756325 1 validation.go:160] TLSTunnelCAFile does not exist in /etc/kubeedge/ca/rootCA.crt, will load from secret
I0828 10:56:18.756405 1 server.go:77] Version: v1.9.2
W0828 10:56:18.756456 1 client_config.go:615] Neither –kubeconfig nor –master was specified. Using the inClusterConfig. This might not work.
I0828 10:56:19.793428 1 module.go:52] Module cloudhub registered successfully
I0828 10:56:19.966632 1 module.go:52] Module edgecontroller registered successfully
I0828 10:56:19.966854 1 module.go:52] Module devicecontroller registered successfully
I0828 10:56:19.966903 1 module.go:52] Module synccontroller registered successfully
I0828 10:56:19.966995 1 module.go:52] Module cloudStream registered successfully
W0828 10:56:19.967010 1 module.go:55] Module router is disabled, do not register
W0828 10:56:19.967021 1 module.go:55] Module dynamiccontroller is disabled, do not register
I0828 10:56:19.967128 1 core.go:46] starting module devicecontroller
I0828 10:56:19.967206 1 core.go:46] starting module synccontroller
I0828 10:56:19.967429 1 core.go:46] starting module cloudStream
I0828 10:56:19.967446 1 downstream.go:878] Start downstream devicecontroller
I0828 10:56:19.967517 1 core.go:46] starting module cloudhub
I0828 10:56:19.967592 1 core.go:46] starting module edgecontroller
I0828 10:56:19.968870 1 upstream.go:125] start upstream controller
I0828 10:56:19.968936 1 downstream.go:339] start downstream controller
I0828 10:56:20.356643 1 server.go:257] Ca and CaKey don’t exist in local directory, and will read from the secret
I0828 10:56:21.566482 1 server.go:302] CloudCoreCert and key don’t exist in local directory, and will read from the secret
I0828 10:56:21.858993 1 tunnelserver.go:146] Succeed in loading TunnelCA from CloudHub
I0828 10:56:21.859713 1 tunnelserver.go:159] Succeed in loading TunnelCert and Key from CloudHub
I0828 10:56:21.860210 1 streamserver.go:305] Prepare to start stream server …
I0828 10:56:21.971950 1 upstream.go:64] Start upstream devicecontroller
I0828 10:56:22.056405 1 signcerts.go:100] Succeed to creating token
I0828 10:56:22.057072 1 server.go:44] start unix domain socket server
I0828 10:56:22.057589 1 uds.go:71] listening on: //var/lib/kubeedge/kubeedge.sock
I0828 10:56:22.359701 1 tunnelserver.go:179] Prepare to start tunnel server …
I0828 10:56:22.360381 1 server.go:64] Starting cloudhub websocket server
I0828 10:56:22.570056 1 tunnelserver.go:119] get a new tunnel agent hostname edgenode-131, internalIP 10.0.8.131
I0828 10:56:23.229356 1 tunnelserver.go:119] get a new tunnel agent hostname edgenode-83, internalIP 10.0.8.83
E0828 10:56:23.235188 1 tunnelserver.go:191] Failed while getting a Node to retry updating node KubeletEndpoint Port, node: edgenode-83, error: nodes “edgenode-83” not found
E0828 10:56:23.239467 1 tunnelserver.go:191] Failed while getting a Node to retry updating node KubeletEndpoint Port, node: edgenode-83, error: nodes “edgenode-83” not found
E0828 10:56:23.239504 1 tunnelserver.go:203] Update KubeletEndpoint Port of Node ‘edgenode-83’ error: timed out waiting for the condition.
补充:
复现以上问题有以下几种case,
case1:
删除edge node ,然后cloudcore 重启,则cloudcore会故障,
cloudcore 不能正常运行, cloudcore 30000,30004 端口不通, 所有edgecore 连接cloudcore 超时,
然后所有52台 edgecore 都会故障,KS上查看 所有边缘节点 52台 全部污点了
case2:
删除edge node ,过一段时间(比如1H后,2天后),cloudcore会故障,现象和case1 一样
