物理机,Centos7 ,48C/64G
v1.23.10
Docker version 20.10.8, build 3967b7d
jaeger相关组件报错,提示未发现es节点, 我们用的是opensearch而不是es
上图中三个容器的报错日志分别为
jaeger-query
2023/08/29 06:06:57 maxprocs: Leaving GOMAXPROCS=48: CPU quota undefined
{"level":"info","ts":1693289217.7449164,"caller":"flags/service.go:117","msg":"Mounting metrics handler on admin server","route":"/metrics"}
{"level":"info","ts":1693289217.7450898,"caller":"flags/service.go:123","msg":"Mounting expvar handler on admin server","route":"/debug/vars"}
{"level":"info","ts":1693289217.7454255,"caller":"flags/admin.go:104","msg":"Mounting health check on admin server","route":"/"}
{"level":"info","ts":1693289217.745627,"caller":"flags/admin.go:115","msg":"Starting admin HTTP server","http-addr":":16687"}
{"level":"info","ts":1693289217.7456648,"caller":"flags/admin.go:96","msg":"Admin server started","http.host-port":"[::]:16687","health-status":"unavailable"}
{"level":"fatal","ts":1693289222.8173027,"caller":"./main.go:101","msg":"Failed to init storage factory","error":"failed to create primary Elasticsearch client: health check timeout: no Elasticsearch node available","stacktrace":"main.main.func1\n\t./main.go:101\ngithub.com/spf13/cobra.(*Command).execute\n\tgithub.com/spf13/cobra@v1.2.1/command.go:856\ngithub.com/spf13/cobra.(*Command).ExecuteC\n\tgithub.com/spf13/cobra@v1.2.1/command.go:974\ngithub.com/spf13/cobra.(*Command).Execute\n\tgithub.com/spf13/cobra@v1.2.1/command.go:902\nmain.main\n\t./main.go:161\nruntime.main\n\truntime/proc.go:255"}
jaeger-collector
2023/08/29 06:09:47 maxprocs: Updating GOMAXPROCS=1: using minimum allowed GOMAXPROCS
{"level":"info","ts":1693289387.568935,"caller":"flags/service.go:117","msg":"Mounting metrics handler on admin server","route":"/metrics"}
{"level":"info","ts":1693289387.5690646,"caller":"flags/service.go:123","msg":"Mounting expvar handler on admin server","route":"/debug/vars"}
{"level":"info","ts":1693289387.5693471,"caller":"flags/admin.go:104","msg":"Mounting health check on admin server","route":"/"}
{"level":"info","ts":1693289387.5694728,"caller":"flags/admin.go:115","msg":"Starting admin HTTP server","http-addr":":14269"}
{"level":"info","ts":1693289387.5695019,"caller":"flags/admin.go:96","msg":"Admin server started","http.host-port":"[::]:14269","health-status":"unavailable"}
{"level":"fatal","ts":1693289393.30059,"caller":"./main.go:80","msg":"Failed to init storage factory","error":"failed to create primary Elasticsearch client: health check timeout: no Elasticsearch node available","stacktrace":"main.main.func1\n\t./main.go:80\ngithub.com/spf13/cobra.(*Command).execute\n\tgithub.com/spf13/cobra@v1.2.1/command.go:856\ngithub.com/spf13/cobra.(*Command).ExecuteC\n\tgithub.com/spf13/cobra@v1.2.1/command.go:974\ngithub.com/spf13/cobra.(*Command).Execute\n\tgithub.com/spf13/cobra@v1.2.1/command.go:902\nmain.main\n\t./main.go:147\nruntime.main\n\truntime/proc.go:255"}
jaeger-collector-headless
ks-install yaml中,我们启用了openearch,没用es
请问这个问题的该从哪方面进行排查呀
