将 kubectl version
命令执行结果贴在下方
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
---> Package openssl-libs.x86_64 1:1.0.2k-26.el7_9 will be an update
--> Finished Dependency Resolution
Error: Package: 1:openssl-devel-1.0.2k-16.el7.x86_64 (@anaconda)
Requires: openssl-libs(x86-64) = 1:1.0.2k-16.el7
Removing: 1:openssl-libs-1.0.2k-16.el7.x86_64 (@anaconda)
Updated By: 1:openssl-libs-1.0.2k-26.el7_9.x86_64 (base-local)
openssl-libs(x86-64) = 1:1.0.2k-26.el7_9
You could try using –skip-broken to work around the problem
You could try running: rpm -Va –nofiles –nodigest
06:23:51 EDT message: [node1]
install repository package failed: Failed to exec command: sudo -E /bin/bash -c “yum install -y openssl socat conntrack ipset ebtables chrony ipvsadm”
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
Package ebtables-2.0.10-16.el7.x86_64 already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package chrony.x86_64 0:3.2-2.el7 will be updated
---> Package chrony.x86_64 0:3.4-1.el7 will be an update
---> Package conntrack-tools.x86_64 0:1.4.4-7.el7 will be installed
--> Processing Dependency: libnetfilter_cttimeout.so.1(LIBNETFILTER_CTTIMEOUT_1.1)(64bit) for package: conntrack-tools-1.4.4-7.el7.x86_64
--> Processing Dependency: libnetfilter_cttimeout.so.1(LIBNETFILTER_CTTIMEOUT_1.0)(64bit) for package: conntrack-tools-1.4.4-7.el7.x86_64
--> Processing Dependency: libnetfilter_cthelper.so.0(LIBNETFILTER_CTHELPER_1.0)(64bit) for package: conntrack-tools-1.4.4-7.el7.x86_64
--> Processing Dependency: libnetfilter_queue.so.1()(64bit) for package: conntrack-tools-1.4.4-7.el7.x86_64
--> Processing Dependency: libnetfilter_cttimeout.so.1()(64bit) for package: conntrack-tools-1.4.4-7.el7.x86_64
--> Processing Dependency: libnetfilter_cthelper.so.0()(64bit) for package: conntrack-tools-1.4.4-7.el7.x86_64
---> Package ipset.x86_64 0:6.38-2.el7 will be updated
---> Package ipset.x86_64 0:7.1-1.el7 will be an update
--> Processing Dependency: ipset-libs(x86-64) = 7.1-1.el7 for package: ipset-7.1-1.el7.x86_64
--> Processing Dependency: libipset.so.13(LIBIPSET_4.8)(64bit) for package: ipset-7.1-1.el7.x86_64
--> Processing Dependency: libipset.so.13(LIBIPSET_2.0)(64bit) for package: ipset-7.1-1.el7.x86_64
--> Processing Dependency: libipset.so.13()(64bit) for package: ipset-7.1-1.el7.x86_64
---> Package ipvsadm.x86_64 0:1.27-7.el7 will be updated
---> Package ipvsadm.x86_64 0:1.27-8.el7 will be an update
---> Package openssl.x86_64 1:1.0.2k-16.el7 will be updated
---> Package openssl.x86_64 1:1.0.2k-26.el7_9 will be an update
--> Processing Dependency: openssl-libs(x86-64) = 1:1.0.2k-26.el7_9 for package: 1:openssl-1.0.2k-26.el7_9.x86_64
---> Package socat.x86_64 0:1.7.3.2-2.el7 will be installed
---> Package ipset-libs.x86_64 0:6.38-2.el7 will be updated
---> Package ipset-libs.x86_64 0:7.1-1.el7 will be an update
---> Package libnetfilter_cthelper.x86_64 0:1.0.0-11.el7 will be installed
---> Package libnetfilter_cttimeout.x86_64 0:1.0.0-7.el7 will be installed
---> Package libnetfilter_queue.x86_64 0:1.0.2-2.el7_2 will be installed
---> Package openssl-libs.x86_64 1:1.0.2k-16.el7 will be updated
--> Processing Dependency: openssl-libs(x86-64) = 1:1.0.2k-16.el7 for package: 1:openssl-devel-1.0.2k-16.el7.x86_64
You could try running: rpm -Va –nofiles –nodigest: Process exited with status 1
06:23:52 EDT stdout: [node2]
** Found 79 pre-existing rpmdb problem(s), ‘yum check’ output follows:
antlr-tool-2.7.7-30.el7.noarch has missing requires of java >= (‘1’, ‘1.7.0’, None)
apache-commons-cli-1.2-13.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
apache-commons-codec-1.8-7.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
apache-commons-collections-3.2.1-22.el7_2.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
apache-commons-daemon-1.0.13-7.el7.x86_64 has missing requires of java >= (‘0’, ‘1.5’, None)
apache-commons-dbcp-1.4-17.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
1:apache-commons-io-2.4-12.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
apache-commons-lang-2.6-15.el7.noarch has missing requires of java >= (‘0’, ‘1.3’, None)
apache-commons-logging-1.1.2-7.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
apache-commons-pool-1.6-9.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
args4j-2.0.16-13.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
cal10n-0.7.7-4.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
codemodel-2.6-9.el7.noarch has missing requires of java
easymock2-2.5.2-12.el7.noarch has missing requires of java
1:ecj-4.5.2-3.el7.x86_64 has missing requires of java >= (‘1’, ‘1.6.0’, None)
geronimo-jms-1.1.1-19.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
geronimo-jta-1.1.1-17.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
glassfish-dtd-parser-1.2-0.8.20120120svn.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
glassfish-fastinfoset-1.2.12-9.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
glassfish-jaxb-2.2.5-6.el7.noarch has missing requires of java
glassfish-jaxb-api-2.2.7-4.el7.noarch has missing requires of java >= (‘1’, ‘1.6.0’, None)
guava-13.0-6.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
hamcrest-1.3-6.el7.noarch has missing requires of java >= (‘1’, ‘1.6.0’, None)
1:hsqldb-1.8.1.3-14.el7.noarch has missing requires of java
httpcomponents-client-4.2.5-5.el7_0.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
httpcomponents-core-4.2.4-6.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
icedtea-web-1.7.1-1.el7.x86_64 has missing requires of java-1.8.0-openjdk
1:isorelax-0-0.15.release20050331.el7.noarch has missing requires of java
istack-commons-2.17-4.el7.noarch has missing requires of java
jackson-1.9.4-7.el7.noarch has missing requires of java
1:jakarta-commons-httpclient-3.1-16.el7_0.noarch has missing requires of java
javamail-1.4.6-8.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
javassist-3.16.1-10.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
jboss-annotations-1.1-api-1.0.1-0.6.20120212git76e1a2.el7.noarch has missing requires of java
jing-20091111-14.el7.noarch has missing requires of java-headless >= (‘0’, ‘1.5.0’, None)
jline-1.0-8.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
jna-3.5.2-8.el7.x86_64 has missing requires of java
joda-convert-1.3-5.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
joda-time-2.2-3.tzdata2013c.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
jsr-311-1.1.1-6.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
jss-4.4.4-3.el7.x86_64 has missing requires of java-headless
jss-4.4.4-3.el7.x86_64 has missing requires of ldapjdk
junit-4.11-8.el7.noarch has missing requires of java >= (‘1’, ‘1.6.0’, None)
1:libreoffice-core-5.3.6.1-19.el7.x86_64 has missing requires of java-headless >= (‘1’, ‘1.6’, None)
1:libreoffice-ure-5.3.6.1-19.el7.x86_64 has missing requires of libjvm.so()(64bit)
libvirt-java-0.4.9-4.el7.noarch has missing requires of java >= (‘0’, ‘1.5.0’, None)
log4j-1.2.17-16.el7_4.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
1:msv-msv-2013.5.1-7.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
1:msv-xsdlib-2013.5.1-7.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
nuxwdog-client-java-1.0.3-8.el7.x86_64 has missing requires of java-headless >= (‘1’, ‘1.6.0’, None)
parfait-0.5.4-2.el7.noarch has missing requires of java >= (‘1’, ‘1.8’, None)
pki-base-java-10.5.9-6.el7.noarch has missing requires of java-1.8.0-openjdk-headless
pki-base-java-10.5.9-6.el7.noarch has missing requires of ldapjdk >= (‘0’, ‘4.19’, ‘5’)
pki-ca-10.5.9-6.el7.noarch has missing requires of java-1.8.0-openjdk-headless
pki-kra-10.5.9-6.el7.noarch has missing requires of java-1.8.0-openjdk-headless
pki-server-10.5.9-6.el7.noarch has missing requires of java-1.8.0-openjdk-headless
pki-tools-10.5.9-6.el7.x86_64 has missing requires of java-1.8.0-openjdk-headless
qdox-1.12.1-10.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
regexp-1.5-13.el7.noarch has missing requires of java
resteasy-base-atom-provider-3.0.6-4.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
resteasy-base-client-3.0.6-4.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
resteasy-base-jackson-provider-3.0.6-4.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
resteasy-base-jaxb-provider-3.0.6-4.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
resteasy-base-jaxrs-3.0.6-4.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
resteasy-base-jaxrs-api-3.0.6-4.el7.noarch has missing requires of java >= (‘1’, ‘1.6’, None)
scannotation-1.0.3-0.7.r12.el7.noarch has missing requires of java
si-units-0.6.5-1.el7.noarch has missing requires of java >= (‘1’, ‘1.8’, None)
slf4j-1.7.4-4.el7_4.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
stax-ex-1.7.1-6.el7.noarch has missing requires of java >= (‘0’, ‘1.5’, None)
tomcat-7.0.76-7.el7_5.noarch has missing requires of java >= (‘1’, ‘1.6.0’, None)
tomcatjss-7.2.1-7.1.el7.noarch has missing requires of java
txw2-20110809-8.el7.noarch has missing requires of java
unit-api-1.0-3.el7.noarch has missing requires of java >= (‘1’, ‘1.7’, None)
uom-lib-1.0.1-5.el7.noarch has missing requires of java >= (‘1’, ‘1.7’, None)
uom-se-1.0.4-3.el7.noarch has missing requires of java >= (‘1’, ‘1.8’, None)
uom-systems-0.7-1.el7.noarch has missing requires of java >= (‘1’, ‘1.8’, None)
xerces-j2-2.11.0-17.el7_0.noarch has missing requires of java
xml-commons-apis-1.4.01-16.el7.noarch has missing requires of java
xpp3-1.1.3.8-11.el7.noarch has missing requires of java
06:23:52 EDT message: [node2]
xpp3-1.1.3.8-11.el7.noarch has missing requires of java: Process exited with status 1
06:23:52 EDT failed: [node1]
06:23:52 EDT failed: [node2]
06:23:52 EDT rollback: [node2]
06:23:52 EDT rollback: [node1]
error: Pipeline[CreateClusterPipeline] execute failed: Module[RepositoryModule] exec failed:
failed: [node1] [InstallPackage] exec failed after 1 retries: install repository package failed: Failed to exec command: sudo -E /bin/bash -c “yum install -y openssl socat conntrack ipset ebtables chrony ipvsadm”
failed: [node2] [InstallPackage] exec failed after 1 retries: install repository package failed: Failed to exec command: sudo -E /bin/bash -c “yum install -y openssl socat conntrack ipset ebtables chrony ipvsadm”
这是缺少依赖吗?
