物理机,Centos7.5 48c 192g
将 kubectl version
命令执行结果贴在下方
Client Version: version.Info{Major:"1", Minor:"22", GitVersion:"v1.22.16", GitCommit:"b28e1f370a4a4c428ddbeababcaf0198f048fcac", GitTreeState:"clean", BuildDate:"2022-11-09T13:37:37Z", GoVersion:"go1.16.15", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"22", GitVersion:"v1.22.16", GitCommit:"b28e1f370a4a4c428ddbeababcaf0198f048fcac", GitTreeState:"clean", BuildDate:"2022-11-09T13:31:51Z", GoVersion:"go1.16.15", Compiler:"gc", Platform:"linux/amd64"}
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
Version: 24.0.6
API version: 1.41 (downgraded from 1.43)
Go version: go1.20.7
Git commit: ed223bc
Built: Mon Sep 4 12:35:25 2023
Version: 20.10.12
Go version: go1.16.12
Git commit: 459d0df
Built: Mon Dec 13 11:44:05 2021
Version: 1.6.24
GitCommit: 61f9fd88f79f081d64d6fa3bb1a0dc71ec870523
Version: 1.1.9
GitCommit: v1.1.9-0-gccaecfc
Version: 0.19.0
GitCommit: de40ad0
v3.4 在线安装,在已有K8s上安装
使用外部prometheus启用多集群功能时,controller-manager无法启动
localhost : ok=30 changed=17 unreachable=0 failed=0 skipped=17 rescued=0 ignored=0
Start installing monitoring
Start installing multicluster
Start installing openpitrix
Start installing network
Waiting for all tasks to be completed ...
task openpitrix status is successful (1/4)
task network status is successful (2/4)
task monitoring status is successful (3/4)
task multicluster status is failed (4/4)
Collecting installation results ...
Task 'multicluster' failed:
"counter": 65,
"created": "2023-10-09T04:15:14.794445",
"end_line": 67,
"event": "runner_on_failed",
"event_data": {
"duration": 610.730374,
"end": "2023-10-09T04:15:14.793746",
"event_loop": null,
"host": "localhost",
"ignore_errors": null,
"play": "localhost",
"play_pattern": "localhost",
"play_uuid": "8607507a-a2e3-08f1-1c75-000000000005",
"playbook": "/kubesphere/playbooks/multicluster.yaml",
"playbook_uuid": "85ee6988-8e4c-4ba7-bc9c-f4897219ea7f",
"remote_addr": "127.0.0.1",
"res": {
"_ansible_no_log": false,
"attempts": 10,
"changed": true,
"cmd": "/usr/local/bin/helm upgrade --install kubefed /kubesphere/kubesphere/kubefed/kubefed -f /kubesphere/kubesphere/kubefed/custom-values-kubefed.yaml --namespace kube-federation-system --wait --timeout 1800s\n",
"delta": "0:00:00.218527",
"end": "2023-10-09 12:15:14.683426",
"invocation": {
"module_args": {
"_raw_params": "/usr/local/bin/helm upgrade --install kubefed /kubesphere/kubesphere/kubefed/kubefed -f /kubesphere/kubesphere/kubefed/custom-values-kubefed.yaml --namespace kube-federation-system --wait --timeout 1800s\n",
"_uses_shell": true,
"argv": null,
"chdir": null,
"creates": null,
"executable": null,
"removes": null,
"stdin": null,
"stdin_add_newline": true,
"strip_empty_ends": true,
"warn": true
"rc": 1,
"start": "2023-10-09 12:15:14.464899",
"stderr": "Error: UPGRADE FAILED: another operation (install/upgrade/rollback) is in progress",
"stderr_lines": [
"stdout": "",
"stdout_lines": []
"resolved_action": "command",
"role": "ks-multicluster",
"start": "2023-10-09T04:05:04.063372",
"task": "Kubefed | Initing kube-federation-system",
"task_action": "command",
"task_args": "",
"task_path": "/kubesphere/installer/roles/ks-multicluster/tasks/main.yml:51",
"task_uuid": "8607507a-a2e3-08f1-1c75-00000000001f",
"uuid": "2fa0ffc7-7818-454f-812d-6ef727d6a7db"
"parent_uuid": "8607507a-a2e3-08f1-1c75-00000000001f",
"pid": 17201,
"runner_ident": "multicluster",
"start_line": 66,
"stdout": "fatal: [localhost]: FAILED! => {\"attempts\": 10, \"changed\": true, \"cmd\": \"/usr/local/bin/helm upgrade --install kubefed /kubesphere/kubesphere/kubefed/kubefed -f /kubesphere/kubesphere/kubefed/custom-values-kubefed.yaml --namespace kube-federation-system --wait --timeout 1800s\\n\", \"delta\": \"0:00:00.218527\", \"end\": \"2023-10-09 12:15:14.683426\", \"msg\": \"non-zero return code\", \"rc\": 1, \"start\": \"2023-10-09 12:15:14.464899\", \"stderr\": \"Error: UPGRADE FAILED: another operation (install/upgrade/rollback) is in progress\", \"stderr_lines\": [\"Error: UPGRADE FAILED: another operation (install/upgrade/rollback) is in progress\"], \"stdout\": \"\", \"stdout_lines\": []}",
W1009 12:37:11.672363 1 client_config.go:618] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
I1009 12:37:11.675361 1 server.go:197] setting up manager
I1009 12:37:11.773161 1 listener.go:44] "controller-runtime/metrics: Metrics server is starting to listen" addr=":8080"
W1009 12:37:11.858115 1 controllers.go:162] ks-controller-manager starts without ldap provided, it will not sync user into ldap
I1009 12:37:11.870354 1 reconciler.go:149] "controllers/Helm: Watching resource" group="gateway.kubesphere.io" version="v1alpha1" kind="Nginx"
I1009 12:37:11.870397 1 helm_controller.go:76] configured watch gvk gateway.kubesphere.io/v1alpha1, Kind=Nginx chartPath /var/helm-charts/ingress-nginx maxConcurrentReconciles 64 reconcilePeriod 1m0s
I1009 12:37:11.870509 1 reconciler.go:149] "controllers/Helm: Watching resource" group="gateway.kubesphere.io" version="v1alpha1" kind="Gateway"
I1009 12:37:11.870520 1 helm_controller.go:76] configured watch gvk gateway.kubesphere.io/v1alpha1, Kind=Gateway chartPath /var/helm-charts/gateway maxConcurrentReconciles 64 reconcilePeriod 1m0s
I1009 12:37:11.871852 1 loginrecord_controller.go:94] Setting up event handlers
I1009 12:37:11.872144 1 certificatesigningrequest_controller.go:93] Setting up event handlers
I1009 12:37:11.872406 1 clusterrolebinding_controller.go:98] Setting up event handlers
I1009 12:37:11.872746 1 globalrole_controller.go:99] Setting up event handlers
I1009 12:37:11.873056 1 globalrolebinding_controller.go:107] Setting up event handlers
I1009 12:37:11.873284 1 groupbinding_controller.go:95] Setting up event handlers
I1009 12:37:11.873540 1 group_controller.go:103] Setting up event handlers
I1009 12:37:11.873935 1 notification_controller.go:88] Setting up event handlers
W1009 12:37:11.876500 1 reflector.go:424] /workspace/cmd/controller-manager/app/controllers.go:440: failed to list types.kubefed.io/v1beta1, Kind=FederatedGlobalRoleBinding: the server could not find the requested resource
E1009 12:37:11.876561 1 reflector.go:140] /workspace/cmd/controller-manager/app/controllers.go:440: Failed to watch types.kubefed.io/v1beta1, Kind=FederatedGlobalRoleBinding: failed to list types.kubefed.io/v1beta1, Kind=FederatedGlobalRoleBinding: the server could not find the requested resource
W1009 12:37:11.876591 1 reflector.go:424] /workspace/cmd/controller-manager/app/controllers.go:415: failed to list types.kubefed.io/v1beta1, Kind=FederatedGlobalRole: the server could not find the requested resource
E1009 12:37:11.876643 1 reflector.go:140] /workspace/cmd/controller-manager/app/controllers.go:415: Failed to watch types.kubefed.io/v1beta1, Kind=FederatedGlobalRole: failed to list types.kubefed.io/v1beta1, Kind=FederatedGlobalRole: the server could not find the requested resource
E1009 12:37:12.064878 1 notification_controller.go:116] get /, Kind= informer error, no matches for kind "NotificationManager" in version "notification.kubesphere.io/v2beta2"
F1009 12:37:12.064986 1 controllers.go:523] Unable to create Notification controller: no matches for kind "NotificationManager" in version "notification.kubesphere.io/v2beta2"
