例如:虚拟机,Centos7.9
Client Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.5”, GitCommit:“5c99e2ac2ff9a3c549d9ca665e7bc05a3e18f07e”, GitTreeState:“clean”, BuildDate:“2021-12-16T08:38:33Z”, GoVersion:“go1.16.12”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.5”, GitCommit:“5c99e2ac2ff9a3c549d9ca665e7bc05a3e18f07e”, GitTreeState:“clean”, BuildDate:“2021-12-16T08:32:32Z”, GoVersion:“go1.16.12”, Compiler:“gc”, Platform:“linux/amd64”}
Version: 23.0.1
API version: 1.41 (downgraded from 1.42)
Go version: go1.19.5
Git commit: a5ee5b1
Built: Thu Feb 9 19:51:00 2023
Version: 20.10.8
Go version: go1.16.6
Git commit: 75249d8
Built: Fri Jul 30 19:54:13 2021
Version: 1.6.18
GitCommit: 2456e983eb9e37e47538f59ea18f2043c9a73640
Version: 1.1.4
GitCommit: v1.1.4-0-g5fd4c4d
Version: 0.19.0
GitCommit: de40ad0
在已有K8s上安装的
在安装后启用 DevOps,ks-controller-manager报错unable to register controllers to the manager: failed to connect to ldap service, please check ldap status, error: factory is not able to fill the pool: LDAP Result Code 200 “Network Error”: dial tcp: lookup openldap.kubesphere-system.svc on 10.96.0.10:53: no such host
