• KSV
  • error #0: x509: certificate is valid for 127.0.0.1
The problem:
./kk create cluster -f config-sample.yaml
| |\ \ || | |) | __/ |\ \ __/ |_| |
\| \/\,|./ \\| \/\|\__, |
                                __/ |
                               |___/
14:12:12 UTC [GreetingsModule] Greetings
14:12:12 UTC message: [worker4]
Greetings, KubeKey!
14:12:13 UTC message: [worker1]
Greetings, KubeKey!
14:12:13 UTC message: [worker3]
Greetings, KubeKey!
14:12:14 UTC message: [worker2]
Greetings, KubeKey!
14:12:14 UTC message: [master]
Greetings, KubeKey!
14:12:14 UTC success: [worker4]
14:12:14 UTC success: [worker1]
14:12:14 UTC success: [worker3]
14:12:14 UTC success: [worker2]
14:12:14 UTC success: [master]
14:12:14 UTC [NodePreCheckModule] A pre-check on nodes
14:12:14 UTC [ConfirmModule] Display confirmation form
| name | sudo | curl | openssl | ebtables | socat | ipset | ipvsadm | conntrack | chrony | docker | containerd | nfs client | ceph client | glusterfs client | time |
| master | y | y | y | y | y | y | | y | | 20.10.8 | v1.4.9 | | | | UTC 14:12:14 |
| worker1 | y | y | y | y | y | y | | y | | 20.10.8 | v1.4.9 | | | | UTC 14:12:14 |
| worker2 | y | y | y | y | y | y | | y | | 20.10.8 | v1.4.9 | | | | UTC 14:12:14 |
| worker3 | y | y | y | y | y | y | | y | | 20.10.8 | v1.4.9 | | | | UTC 14:12:14 |
| worker4 | y | y | y | y | y | y | | y | | 20.10.8 | v1.4.9 | | | | UTC 14:12:14 |
Before installation, ensure that your machines meet all requirements specified at
https://github.com/kubesphere/kubekey#requirements-and-recommendations
Continue this installation? [yes/no]: yes
14:12:17 UTC success: [LocalHost]
14:12:17 UTC [NodeBinariesModule] Download installation binaries
14:12:17 UTC message: [localhost]
downloading amd64 kubeadm v1.23.10 …
14:12:19 UTC message: [localhost]
kubeadm is existed
downloading amd64 kubelet v1.23.10 …
14:12:23 UTC message: [localhost]
kubelet is existed
downloading amd64 kubectl v1.23.10 …
14:12:25 UTC message: [localhost]
kubectl is existed
downloading amd64 helm v3.9.0 …
14:12:27 UTC message: [localhost]
helm is existed
downloading amd64 kubecni v1.2.0 …
14:12:28 UTC message: [localhost]
kubecni is existed
downloading amd64 crictl v1.24.0 …
14:12:29 UTC message: [localhost]
crictl is existed
downloading amd64 etcd v3.4.13 …
etcd is existed
downloading amd64 docker 20.10.8 …
14:12:31 UTC message: [localhost]
docker is existed
downloading amd64 calicoctl v3.23.2 …
14:12:33 UTC message: [localhost]
calicoctl is existed
14:12:33 UTC success: [LocalHost]
14:12:33 UTC [ConfigureOSModule] Get OS release
14:12:33 UTC success: [worker4]
14:12:33 UTC success: [worker2]
14:12:33 UTC success: [master]
14:12:33 UTC success: [worker3]
14:12:33 UTC success: [worker1]
14:12:33 UTC [ConfigureOSModule] Prepare to init OS
14:12:34 UTC success: [worker3]
14:12:34 UTC success: [worker1]
14:12:34 UTC success: [master]
14:12:34 UTC success: [worker4]
14:12:34 UTC success: [worker2]
14:12:34 UTC [ConfigureOSModule] Generate init os script
14:12:34 UTC [ConfigureOSModule] Exec init os script
14:12:36 UTC stdout: [worker3]
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
net.ipv4.ip_forward = 1
net.bridge.bridge-nf-call-arptables = 1
net.bridge.bridge-nf-call-ip6tables = 1
net.bridge.bridge-nf-call-iptables = 1
net.ipv4.ip_local_reserved_ports = 30000-32767
net.core.netdev_max_backlog = 65535
net.core.rmem_max = 33554432
net.core.wmem_max = 33554432
net.core.somaxconn = 32768
net.ipv4.tcp_max_syn_backlog = 1048576
net.ipv4.neigh.default.gc_thresh1 = 512
net.ipv4.neigh.default.gc_thresh2 = 2048
net.ipv4.neigh.default.gc_thresh3 = 4096
net.ipv4.tcp_retries2 = 15
net.ipv4.tcp_max_tw_buckets = 1048576
net.ipv4.tcp_max_orphans = 65535
net.ipv4.udp_rmem_min = 131072
net.ipv4.udp_wmem_min = 131072
net.ipv4.conf.all.arp_accept = 1
net.ipv4.conf.default.arp_accept = 1
net.ipv4.conf.all.arp_ignore = 1
net.ipv4.conf.default.arp_ignore = 1
vm.max_map_count = 262144
vm.swappiness = 0
vm.overcommit_memory = 0
fs.inotify.max_user_instances = 524288
fs.inotify.max_user_watches = 524288
fs.pipe-max-size = 4194304
fs.aio-max-nr = 262144
kernel.pid_max = 65535
kernel.watchdog_thresh = 5
kernel.hung_task_timeout_secs = 5
14:12:36 UTC stdout: [worker4]
vm.swappiness = 0
14:12:37 UTC stdout: [worker1]
vm.swappiness = 0
14:12:37 UTC stdout: [worker2]
vm.swappiness = 0
14:12:37 UTC stdout: [master]
vm.swappiness = 0
14:12:37 UTC success: [worker3]
14:12:37 UTC success: [worker4]
14:12:37 UTC success: [worker1]
14:12:37 UTC success: [worker2]
14:12:37 UTC success: [master]
14:12:37 UTC [ConfigureOSModule] configure the ntp server for each node
14:12:37 UTC skipped: [worker4]
14:12:37 UTC skipped: [master]
14:12:37 UTC skipped: [worker1]
14:12:37 UTC skipped: [worker2]
14:12:37 UTC skipped: [worker3]
14:12:37 UTC [KubernetesStatusModule] Get kubernetes cluster status
14:12:37 UTC [InstallContainerModule] Sync docker binaries
14:12:38 UTC skipped: [master]
14:12:38 UTC skipped: [worker4]
14:12:38 UTC skipped: [worker3]
14:12:38 UTC skipped: [worker2]
14:12:38 UTC skipped: [worker1]
14:12:38 UTC [InstallContainerModule] Generate docker service
14:12:38 UTC [InstallContainerModule] Generate docker config
14:12:38 UTC [InstallContainerModule] Enable docker
14:12:38 UTC [InstallContainerModule] Add auths to container runtime
14:12:38 UTC [PullModule] Start to pull images on all nodes
14:12:38 UTC message: [worker1]
downloading image: kubesphere/pause:3.6
14:12:38 UTC message: [worker4]
14:12:38 UTC message: [worker2]
14:12:38 UTC message: [worker3]
14:12:38 UTC message: [master]
14:12:42 UTC message: [worker3]
downloading image: kubesphere/kube-proxy:v1.23.10
14:12:42 UTC message: [worker2]
14:12:42 UTC message: [master]
downloading image: kubesphere/kube-apiserver:v1.23.10
14:12:42 UTC message: [worker4]
14:12:42 UTC message: [worker1]
14:12:43 UTC message: [worker3]
downloading image: coredns/coredns:1.8.6
14:12:43 UTC message: [worker2]
14:12:43 UTC message: [master]
downloading image: kubesphere/kube-controller-manager:v1.23.10
14:12:43 UTC message: [worker1]
14:12:43 UTC message: [worker4]
14:12:45 UTC message: [master]
downloading image: kubesphere/kube-scheduler:v1.23.10
14:12:46 UTC message: [worker3]
downloading image: kubesphere/k8s-dns-node-cache:1.15.12
14:12:46 UTC message: [worker2]
14:12:46 UTC message: [worker1]
14:12:46 UTC message: [worker4]
14:12:46 UTC message: [master]
14:12:47 UTC message: [master]
14:12:48 UTC message: [worker3]
downloading image: calico/kube-controllers:v3.23.2
14:12:48 UTC message: [worker2]
14:12:48 UTC message: [worker4]
14:12:48 UTC message: [worker1]
14:12:50 UTC message: [master]
14:12:50 UTC message: [worker3]
downloading image: calico/cni:v3.23.2
14:12:50 UTC message: [worker4]
14:12:50 UTC message: [worker1]
14:12:50 UTC message: [worker2]
14:12:52 UTC message: [master]
14:12:52 UTC message: [worker3]
downloading image: calico/node:v3.23.2
14:12:52 UTC message: [worker1]
14:12:52 UTC message: [worker4]
14:12:52 UTC message: [worker2]
14:12:54 UTC message: [master]
14:12:54 UTC message: [worker3]
downloading image: calico/pod2daemon-flexvol:v3.23.2
14:12:54 UTC message: [worker4]
14:12:55 UTC message: [worker1]
14:12:55 UTC message: [worker2]
14:12:56 UTC message: [master]
14:12:57 UTC message: [worker3]
downloading image: library/haproxy:2.3
14:12:57 UTC message: [worker1]
14:12:57 UTC message: [worker4]
14:12:57 UTC message: [worker2]
14:12:58 UTC message: [master]
14:13:01 UTC success: [worker3]
14:13:01 UTC success: [worker1]
14:13:01 UTC success: [worker4]
14:13:01 UTC success: [worker2]
14:13:01 UTC success: [master]
14:13:01 UTC [ETCDPreCheckModule] Get etcd status
14:13:01 UTC [CertsModule] Fetch etcd certs
14:13:01 UTC [CertsModule] Generate etcd Certs
[certs] Using existing ca certificate authority
[certs] Using existing admin-master certificate and key on disk
[certs] Using existing member-master certificate and key on disk
[certs] Using existing node-master certificate and key on disk
14:13:01 UTC success: [LocalHost]
14:13:01 UTC [CertsModule] Synchronize certs file
14:13:01 UTC [CertsModule] Synchronize certs file to master
14:13:01 UTC skipped: [master]
14:13:01 UTC [InstallETCDBinaryModule] Install etcd using binary
14:13:03 UTC success: [master]
14:13:03 UTC [InstallETCDBinaryModule] Generate etcd service
14:13:03 UTC [InstallETCDBinaryModule] Generate access address
14:13:03 UTC [ETCDConfigureModule] Health check on exist etcd
14:13:03 UTC skipped: [master]
14:13:03 UTC [ETCDConfigureModule] Generate etcd.env config on new etcd
14:13:03 UTC [ETCDConfigureModule] Refresh etcd.env config on all etcd
14:13:03 UTC [ETCDConfigureModule] Restart etcd
14:13:07 UTC success: [master]
14:13:07 UTC [ETCDConfigureModule] Health check on all etcd
14:13:07 UTC message: [master]
etcd health check failed: Failed to exec command: sudo -E /bin/bash -c “export ETCDCTL_API=2;export ETCDCTL_CERT_FILE=‘/etc/ssl/etcd/ssl/admin-master.pem’;export ETCDCTL_KEY_FILE=‘/etc/ssl/etcd/ssl/admin-master-key.pem’;export ETCDCTL_CA_FILE=‘/etc/ssl/etcd/ssl/ca.pem’;/usr/local/bin/etcdctl –endpoints=https://172.31.0.129:2379 cluster-health | grep -q ‘cluster is healthy’”
Error: client: etcd cluster is unavailable or misconfigured; error #0: x509: certificate is valid for 127.0.0.1, ::1, 185.32.15.139, 185.32.14.86, 185.32.15.176, 185.32.14.83, 185.32.15.145, not 172.31.0.129
error #0: x509: certificate is valid for 127.0.0.1, ::1, 185.32.15.139, 185.32.14.86, 185.32.15.176, 185.32.14.83, 185.32.15.145, not 172.31.0.129: Process exited with status 1
My config-sample.yaml :
kind: Cluster
hosts:
  • {name: master, address: 185.32.15.139, internalAddress: 172.31.0.129, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
  • {name: worker1, address: 185.32.14.86, internalAddress: 172.31.0.133, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
  • {name: worker2, address: 185.32.15.176, internalAddress: 172.31.0.130, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
  • {name: worker3, address: 185.32.14.83, internalAddress: 172.31.0.131, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
  • {name: worker4, address: 185.32.15.145, internalAddress: 172.31.0.132, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
    roleGroups:
    • master
      control-plane:
    • master
      worker:
    • worker1
    • worker2
    • worker3
    • worker4
    controlPlaneEndpoint:
    internalLoadbalancer: haproxy
    domain: lb.kubesphere.local
    address: ""
    port: 6443
    kubernetes:
    version: 1.23.10
    clusterName: cluster.local
    autoRenewCerts: true
    containerManager: docker
    type: kubekey
    network:
    plugin: calico
    kubePodsCIDR: 10.233.64.0/18
    multus support. https://github.com/k8snetworkplumbingwg/multus-cni
    multusCNI:
    enabled: false
    registry:
    privateRegistry: ""
    namespaceOverride: ""
    registryMirrors: []
    insecureRegistries: []
    addons: []
kind: ClusterConfiguration
namespace: kubesphere-system
version: v3.3.2
persistence:
storageClass: ""
authentication:
jwtSecret: ""
zone: ""
local_registry: ""
namespace_override: ""
dev_tag: ""
monitoring: false
endpointIps: localhost
port: 2379
tlsEnable: true
common:
core:
  console:
    enableMultiLogin: true
    port: 30880
    type: NodePort
# apiserver:
#  resources: {}
# controllerManager:
#  resources: {}
redis:
  enabled: false
  volumeSize: 2Gi
openldap:
  enabled: false
  volumeSize: 2Gi
minio:
  volumeSize: 20Gi
monitoring:
  # type: external
  GPUMonitoring:
    enabled: false
gpu:
  kinds:
  - resourceName: "nvidia.com/gpu"
    resourceType: "GPU"
    default: true
es:
  # master:
  #   volumeSize: 4Gi
  #   replicas: 1
  #   resources: {}
  # data:
  #   volumeSize: 20Gi
  #   replicas: 1
  #   resources: {}
  logMaxAge: 7
  elkPrefix: logstash
  basicAuth:
    enabled: false
    username: ""
    password: ""
  externalElasticsearchHost: ""
  externalElasticsearchPort: ""
alerting:
enabled: false
# thanosruler:
#   replicas: 1
#   resources: {}
auditing:
enabled: false
# operator:
#   resources: {}
# webhook:
#   resources: {}
devops:
enabled: false
# resources: {}
jenkinsMemoryLim: 8Gi
jenkinsMemoryReq: 4Gi
jenkinsVolumeSize: 8Gi
events:
enabled: false
# operator:
#   resources: {}
# exporter:
#   resources: {}
# ruler:
#   enabled: true
#   replicas: 2
#   resources: {}
logging:
enabled: false
logsidecar:
  enabled: true
  replicas: 2
  # resources: {}
metrics_server:
enabled: false
monitoring:
storageClass: ""
node_exporter:
  port: 9100
  # resources: {}
# kube_rbac_proxy:
#   resources: {}
# kube_state_metrics:
#   resources: {}
# prometheus:
#   replicas: 1
#   volumeSize: 20Gi
#   resources: {}
#   operator:
#     resources: {}
# alertmanager:
#   replicas: 1
#   resources: {}
# notification_manager:
#   resources: {}
#   operator:
#     resources: {}
#   proxy:
#     resources: {}
gpu:
  nvidia_dcgm_exporter:
    enabled: false
    # resources: {}
multicluster:
clusterRole: none
network:
networkpolicy:
  enabled: false
ippool:
  type: none
topology:
  type: none
openpitrix:
store:
  enabled: false
servicemesh:
enabled: false
istio:
  components:
    ingressGateways:
    - name: istio-ingressgateway
      enabled: false
    cni:
      enabled: false
edgeruntime:
enabled: false
kubeedge:
  enabled: false
  cloudCore:
    cloudHub:
      advertiseAddress:
    service:
      cloudhubNodePort: "30000"
      cloudhubQuicNodePort: "30001"
      cloudstreamNodePort: "30003"
      tunnelNodePort: "30004"
    # resources: {}
    # hostNetWork: false
  iptables-manager:
    enabled: true
    mode: "external"
    # resources: {}
  # edgeService:
  #   resources: {}
terminal:
timeout: 600
What should ı do?
1 年 后
我重装了一遍 kubekey,就能正常创建集群了,应该是 kubekey 中会保留旧集群的证书,最好只进行一次性安装。这边推荐以后每次创建集群前都重装一次 kubekey,以免出现问题。
