The problem
ec2-user# ./kk create cluster -f config-sample.yaml
etcd health check failed: Failed to exec command: sudo -E /bin/bash -c “export ETCDCTL_API=2;export ETCDCTL_CERT_FILE=‘/etc/ssl/etcd/ssl/admin-master.pem’;export ETCDCTL_KEY_FILE=‘/etc/ssl/etcd/ssl/admin-master-key.pem’;export ETCDCTL_CA_FILE=‘/etc/ssl/etcd/ssl/ca.pem’;/usr/local/bin/etcdctl –endpoints=https://172.31.0.129:2379 cluster-health | grep -q ‘cluster is healthy’”
Error: client: etcd cluster is unavailable or misconfigured; error #0: x509: certificate is valid for 127.0.0.1, ::1, 185.32.15.139, 185.32.14.86, 185.32.15.176, 185.32.14.83, 185.32.15.145, not 172.31.0.129
error #0: x509: certificate is valid for 127.0.0.1, ::1, 185.32.15.139, 185.32.14.86, 185.32.15.176, 185.32.14.83, 185.32.15.145, not 172.31.0.129: Process exited with status 1
My config-sample.yaml
kind: Cluster
hosts:
{name: master, address: 185.32.15.139, internalAddress: 172.31.0.129, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
{name: worker1, address: 185.32.14.86, internalAddress: 172.31.0.133, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
{name: worker2, address: 185.32.15.176, internalAddress: 172.31.0.130, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
{name: worker3, address: 185.32.14.83, internalAddress: 172.31.0.131, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
{name: worker4, address: 185.32.15.145, internalAddress: 172.31.0.132, user: ec2-user, privateKeyPath: “/home/ec2-user/ssh1.pem”}
roleGroups:
master
control-plane:
master
worker:
worker1
worker2
worker3
worker4
controlPlaneEndpoint:
internalLoadbalancer: haproxy
domain: lb.kubesphere.local
address: ""
port: 6443
kubernetes:
version: 1.23.10
clusterName: cluster.local
autoRenewCerts: true
containerManager: docker
type: kubekey
network:
plugin: calico
kubePodsCIDR: 10.233.64.0/18
multusCNI:
enabled: false
registry:
privateRegistry: ""
namespaceOverride: ""
registryMirrors: []
insecureRegistries: []
addons: []
kind: ClusterConfiguration
namespace: kubesphere-system
version: v3.3.2
persistence:
storageClass: ""
authentication:
jwtSecret: ""
zone: ""
local_registry: ""
namespace_override: ""
dev_tag: ""
monitoring: false
endpointIps: localhost
port: 2379
tlsEnable: true
common:
core:
console:
enableMultiLogin: true
port: 30880
type: NodePort
# apiserver:
# resources: {}
# controllerManager:
# resources: {}
redis:
enabled: false
volumeSize: 2Gi
openldap:
enabled: false
volumeSize: 2Gi
minio:
volumeSize: 20Gi
monitoring:
# type: external
GPUMonitoring:
enabled: false
gpu:
kinds:
- resourceName: "nvidia.com/gpu"
resourceType: "GPU"
default: true
es:
# master:
# volumeSize: 4Gi
# replicas: 1
# resources: {}
# data:
# volumeSize: 20Gi
# replicas: 1
# resources: {}
logMaxAge: 7
elkPrefix: logstash
basicAuth:
enabled: false
username: ""
password: ""
externalElasticsearchHost: ""
externalElasticsearchPort: ""
alerting:
enabled: false
# thanosruler:
# replicas: 1
# resources: {}
auditing:
enabled: false
# operator:
# resources: {}
# webhook:
# resources: {}
devops:
enabled: false
# resources: {}
jenkinsMemoryLim: 8Gi
jenkinsMemoryReq: 4Gi
jenkinsVolumeSize: 8Gi
events:
enabled: false
# operator:
# resources: {}
# exporter:
# resources: {}
# ruler:
# enabled: true
# replicas: 2
# resources: {}
logging:
enabled: false
logsidecar:
enabled: true
replicas: 2
# resources: {}
metrics_server:
enabled: false
monitoring:
storageClass: ""
node_exporter:
port: 9100
# resources: {}
# kube_rbac_proxy:
# resources: {}
# kube_state_metrics:
# resources: {}
# prometheus:
# replicas: 1
# volumeSize: 20Gi
# resources: {}
# operator:
# resources: {}
# alertmanager:
# replicas: 1
# resources: {}
# notification_manager:
# resources: {}
# operator:
# resources: {}
# proxy:
# resources: {}
gpu:
nvidia_dcgm_exporter:
enabled: false
# resources: {}
multicluster:
clusterRole: none
network:
networkpolicy:
enabled: false
ippool:
type: none
topology:
type: none
openpitrix:
store:
enabled: false
servicemesh:
enabled: false
istio:
components:
ingressGateways:
- name: istio-ingressgateway
enabled: false
cni:
enabled: false
edgeruntime:
enabled: false
kubeedge:
enabled: false
cloudCore:
cloudHub:
advertiseAddress:
service:
cloudhubNodePort: "30000"
cloudhubQuicNodePort: "30001"
cloudstreamNodePort: "30003"
tunnelNodePort: "30004"
# resources: {}
# hostNetWork: false
iptables-manager:
enabled: true
mode: "external"
# resources: {}
# edgeService:
# resources: {}
terminal:
timeout: 600
