私有云主机,三台master节点,三台worker节点
将 kubectl version
命令执行结果贴在下方
advanced-2.0.2。离线安装。在已有K8s上安装
离线安装kubesphere,kubectl log 有报错,日志如下
[WARNING]: provided hosts list is empty, only localhost is available. Note
that the implicit localhost does not match ‘all’
TASK [download : include_tasks] ************************************************
skipping: [localhost]
TASK [download : Download items] ***********************************************
TASK [download : Sync container] ***********************************************
TASK [kubesphere-defaults : Configure defaults] ********************************
ok: [localhost] => {
"msg": "Check roles/kubespray-defaults/defaults/main.yml"
TASK [ks-devops/sonarqube : ks-devops | Creating ks-jenkins webhook(external)] ***
TASK [ks-devops/sonarqube : ks-devops | Getting sonarqube installation files] ***
changed: [localhost]
TASK [ks-devops/sonarqube : Sonarqube | Creating manifests] ********************
changed: [localhost] => (item={u’name’: u’custom-values-sonarqube’, u’file’: u’custom-values-sonarqube.yaml’})
TASK [ks-devops/sonarqube : Sonarqube | Deploy Sonarqube] **********************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/helm upgrade –install ks-sonarqube /etc/kubesphere/sonarqube/sonarqube-0.13.5.tgz -f /etc/kubesphere/sonarqube/custom-values-sonarqube.yaml –namespace kubesphere-devops-system\n”, “delta”: “0:00:00.268181”, “end”: “2023-10-19 09:21:28.713191”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2023-10-19 09:21:28.445010”, “stderr”: "Error: UPGRADE FAILED: \“ks-sonarqube\” has no deployed releases", “stderr_lines”: ["Error: UPGRADE FAILED: \“ks-sonarqube\” has no deployed releases"], “stdout”: "", “stdout_lines”: []}
localhost : ok=3 changed=2 unreachable=0 failed=1 skipped=4 rescued=0 ignored=0
有没有大佬帮忙看是什么原因导致的。
