- 已编辑
发帖前请点击 发表主题 右边的 预览() 按钮,确保帖子格式正确。
腾讯云TKE集群v1.26
containerd:1.6.9
v3.4.1在已有K8s安装,采用最小化安装方式
安装时配置文件
apiVersion: installer.kubesphere.io/v1alpha1 kind: ClusterConfiguration metadata: name: ks-installer namespace: kubesphere-system labels: version: v3.4.1 spec: persistence: storageClass: "" # If there is no default StorageClass in your cluster, you need to specify an existing StorageClass here. authentication: adminPassword: "P@88w0rd" # Custom password of the admin user. If the parameter exists but the value is empty, a random password is generated. If the parameter does not exist, P@88w0rd is used. jwtSecret: "" # Keep the jwtSecret consistent with the Host Cluster. Retrieve the jwtSecret by executing "kubectl -n kubesphere-system get cm kubesphere-config -o yaml | grep -v "apiVersion" | grep jwtSecret" on the Host Cluster. local_registry: "" # Add your private registry address if it is needed. # dev_tag: "" # Add your kubesphere image tag you want to install, by default it's same as ks-installer release version. etcd: monitoring: false # Enable or disable etcd monitoring dashboard installation. You have to create a Secret for etcd before you enable it. endpointIps: localhost # etcd cluster EndpointIps. It can be a bunch of IPs here. port: 2379 # etcd port. tlsEnable: true common: core: console: enableMultiLogin: true # Enable or disable simultaneous logins. It allows different users to log in with the same account at the same time. port: 31990 type: NodePort # apiserver: # Enlarge the apiserver and controller manager's resource requests and limits for the large cluster # resources: {} # controllerManager: # resources: {} redis: enabled: false enableHA: false volumeSize: 2Gi # Redis PVC size. openldap: enabled: false volumeSize: 2Gi # openldap PVC size. minio: volumeSize: 20Gi # Minio PVC size. monitoring: type: external # Whether to specify the external prometheus stack, and need to modify the endpoint at the next line. endpoint: http://prometheus-operated.monitoring-system.svc:9090 # Prometheus endpoint to get metrics data. GPUMonitoring: # Enable or disable the GPU-related metrics. If you enable this switch but have no GPU resources, Kubesphere will set it to zero. enabled: false gpu: # Install GPUKinds. The default GPU kind is nvidia.com/gpu. Other GPU kinds can be added here according to your needs. kinds: - resourceName: "nvidia.com/gpu" resourceType: "GPU" default: true es: # Storage backend for logging, events and auditing. # master: # volumeSize: 4Gi # The volume size of Elasticsearch master nodes. # replicas: 1 # The total number of master nodes. Even numbers are not allowed. # resources: {} # data: # volumeSize: 20Gi # The volume size of Elasticsearch data nodes. # replicas: 1 # The total number of data nodes. # resources: {} enabled: false logMaxAge: 7 # Log retention time in built-in Elasticsearch. It is 7 days by default. elkPrefix: logstash # The string making up index names. The index name will be formatted as ks-<elk_prefix>-log. basicAuth: enabled: false username: "" password: "" externalElasticsearchHost: "" externalElasticsearchPort: "" opensearch: # Storage backend for logging, events and auditing. # master: # volumeSize: 4Gi # The volume size of Opensearch master nodes. # replicas: 1 # The total number of master nodes. Even numbers are not allowed. # resources: {} # data: # volumeSize: 20Gi # The volume size of Opensearch data nodes. # replicas: 1 # The total number of data nodes. # resources: {} enabled: true logMaxAge: 7 # Log retention time in built-in Opensearch. It is 7 days by default. opensearchPrefix: whizard # The string making up index names. The index name will be formatted as ks-<opensearchPrefix>-logging. basicAuth: enabled: true username: "admin" password: "admin" externalOpensearchHost: "" externalOpensearchPort: "" dashboard: enabled: false alerting: # (CPU: 0.1 Core, Memory: 100 MiB) It enables users to customize alerting policies to send messages to receivers in time with different time intervals and alerting levels to choose from. enabled: false # Enable or disable the KubeSphere Alerting System. # thanosruler: # replicas: 1 # resources: {} auditing: # Provide a security-relevant chronological set of records,recording the sequence of activities happening on the platform, initiated by different tenants. enabled: false # Enable or disable the KubeSphere Auditing Log System. # operator: # resources: {} # webhook: # resources: {} devops: # (CPU: 0.47 Core, Memory: 8.6 G) Provide an out-of-the-box CI/CD system based on Jenkins, and automated workflow tools including Source-to-Image & Binary-to-Image. enabled: false # Enable or disable the KubeSphere DevOps System. jenkinsCpuReq: 0.5 jenkinsCpuLim: 1 jenkinsMemoryReq: 4Gi jenkinsMemoryLim: 4Gi # Recommend keep same as requests.memory. jenkinsVolumeSize: 16Gi events: # Provide a graphical web console for Kubernetes Events exporting, filtering and alerting in multi-tenant Kubernetes clusters. enabled: false # Enable or disable the KubeSphere Events System. # operator: # resources: {} # exporter: # resources: {} ruler: enabled: true replicas: 2 # resources: {} logging: # (CPU: 57 m, Memory: 2.76 G) Flexible logging functions are provided for log query, collection and management in a unified console. Additional log collectors can be added, such as Elasticsearch, Kafka and Fluentd. enabled: false # Enable or disable the KubeSphere Logging System. logsidecar: enabled: true replicas: 2 # resources: {} metrics_server: # (CPU: 56 m, Memory: 44.35 MiB) It enables HPA (Horizontal Pod Autoscaler). enabled: true # Enable or disable metrics-server. monitoring: storageClass: "" # If there is an independent StorageClass you need for Prometheus, you can specify it here. The default StorageClass is used by default. node_exporter: port: 9100 # resources: {} # kube_rbac_proxy: # resources: {} # kube_state_metrics: # resources: {} # prometheus: # replicas: 1 # Prometheus replicas are responsible for monitoring different segments of data source and providing high availability. # volumeSize: 20Gi # Prometheus PVC size. # resources: {} # operator: # resources: {} # alertmanager: # replicas: 1 # AlertManager Replicas. # resources: {} # notification_manager: # resources: {} # operator: # resources: {} # proxy: # resources: {} gpu: # GPU monitoring-related plug-in installation. nvidia_dcgm_exporter: # Ensure that gpu resources on your hosts can be used normally, otherwise this plug-in will not work properly. enabled: false # Check whether the labels on the GPU hosts contain "nvidia.com/gpu.present=true" to ensure that the DCGM pod is scheduled to these nodes. # resources: {} multicluster: clusterRole: none # host | member | none # You can install a solo cluster, or specify it as the Host or Member Cluster. network: networkpolicy: # Network policies allow network isolation within the same cluster, which means firewalls can be set up between certain instances (Pods). # Make sure that the CNI network plugin used by the cluster supports NetworkPolicy. There are a number of CNI network plugins that support NetworkPolicy, including Calico, Cilium, Kube-router, Romana and Weave Net. enabled: false # Enable or disable network policies. ippool: # Use Pod IP Pools to manage the Pod network address space. Pods to be created can be assigned IP addresses from a Pod IP Pool. type: none # Specify "calico" for this field if Calico is used as your CNI plugin. "none" means that Pod IP Pools are disabled. topology: # Use Service Topology to view Service-to-Service communication based on Weave Scope. type: weave-scope # Specify "weave-scope" for this field to enable Service Topology. "none" means that Service Topology is disabled. openpitrix: # An App Store that is accessible to all platform tenants. You can use it to manage apps across their entire lifecycle. store: enabled: false # Enable or disable the KubeSphere App Store. servicemesh: # (0.3 Core, 300 MiB) Provide fine-grained traffic management, observability and tracing, and visualized traffic topology. enabled: false # Base component (pilot). Enable or disable KubeSphere Service Mesh (Istio-based). istio: # Customizing the istio installation configuration, refer to https://istio.io/latest/docs/setup/additional-setup/customize-installation/ components: ingressGateways: - name: istio-ingressgateway enabled: false cni: enabled: false edgeruntime: # Add edge nodes to your cluster and deploy workloads on edge nodes. enabled: false kubeedge: # kubeedge configurations enabled: false cloudCore: cloudHub: advertiseAddress: # At least a public IP address or an IP address which can be accessed by edge nodes must be provided. - "" # Note that once KubeEdge is enabled, CloudCore will malfunction if the address is not provided. service: cloudhubNodePort: "30000" cloudhubQuicNodePort: "30001" cloudhubHttpsNodePort: "30002" cloudstreamNodePort: "30003" tunnelNodePort: "30004" # resources: {} # hostNetWork: false iptables-manager: enabled: true mode: "external" # resources: {} # edgeService: # resources: {} gatekeeper: # Provide admission policy and rule management, A validating (mutating TBA) webhook that enforces CRD-based policies executed by Open Policy Agent. enabled: false # Enable or disable Gatekeeper. # controller_manager: # resources: {} # audit: # resources: {} terminal: # image: 'alpine:3.15' # There must be an nsenter program in the image timeout: 600 # Container timeout, if set to 0, no timeout will be used. The unit is seconds
开启多集群管理,如果集群正常则默认会有主节点集群,但是现在集群管理为空
启用多集群之后集群管理界面为空,后续发现ks-controller-manager在不断重启
pod事件
ks-controller-manager日志
W1220 17:52:46.561468 1 client_config.go:618] Neither –kubeconfig nor –master was specified. Using the inClusterConfig. This might not work.
I1220 17:52:46.562828 1 server.go:197] setting up manager
I1220 17:52:46.615181 1 listener.go:44] “controller-runtime/metrics: Metrics server is starting to listen” addr=“:8080”
W1220 17:52:46.617069 1 controllers.go:162] ks-controller-manager starts without ldap provided, it will not sync user into ldap
I1220 17:52:46.623088 1 reconciler.go:149] “controllers/Helm: Watching resource” group=“gateway.kubesphere.io” version=“v1alpha1” kind=“Nginx”
I1220 17:52:46.623112 1 helm_controller.go:76] configured watch gvk gateway.kubesphere.io/v1alpha1, Kind=Nginx chartPath /var/helm-charts/ingress-nginx maxConcurrentReconciles 8 reconcilePeriod 1m0s
I1220 17:52:46.623393 1 reconciler.go:149] “controllers/Helm: Watching resource” group=“gateway.kubesphere.io” version=“v1alpha1” kind=“Gateway”
I1220 17:52:46.623412 1 helm_controller.go:76] configured watch gvk gateway.kubesphere.io/v1alpha1, Kind=Gateway chartPath /var/helm-charts/gateway maxConcurrentReconciles 8 reconcilePeriod 1m0s
I1220 17:52:46.624079 1 loginrecord_controller.go:94] Setting up event handlers
I1220 17:52:46.624205 1 certificatesigningrequest_controller.go:93] Setting up event handlers
I1220 17:52:46.624366 1 clusterrolebinding_controller.go:98] Setting up event handlers
I1220 17:52:46.624560 1 globalrole_controller.go:99] Setting up event handlers
I1220 17:52:46.625146 1 globalrolebinding_controller.go:107] Setting up event handlers
I1220 17:52:46.625803 1 groupbinding_controller.go:95] Setting up event handlers
I1220 17:52:46.626117 1 group_controller.go:103] Setting up event handlers
I1220 17:52:46.626469 1 notification_controller.go:88] Setting up event handlers
E1220 17:52:46.648789 1 notification_controller.go:116] get /, Kind= informer error, no matches for kind “NotificationManager” in version “notification.kubesphere.io/v2beta2”
F1220 17:52:46.648829 1 controllers.go:523] Unable to create Notification controller: no matches for kind “NotificationManager” in version “notification.kubesphere.io/v2beta2”
