Centos7,8C/32G
将 kubectl version
命令执行结果贴在下方
Client Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.0”, GitCommit:“cb303e613a121a29364f75cc67d3d580833a7479”, GitTreeState:“clean”, BuildDate:“2021-04-08T16:31:21Z”, GoVersion:“go1.16.1”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.0”, GitCommit:“cb303e613a121a29364f75cc67d3d580833a7479”, GitTreeState:“clean”, BuildDate:“2021-04-08T16:25:06Z”, GoVersion:“go1.16.1”, Compiler:“gc”, Platform:“linux/amd64”}
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
Version: 25.0.0
API version: 1.44
Go version: go1.21.6
Git commit: e758fe5
Built: Thu Jan 18 17:13:17 2024
Version: 25.0.0
API version: 1.44 (minimum version 1.24)
Git commit: 615dfdf
Built: Thu Jan 18 17:12:10 2024
Version: 1.6.27
GitCommit: a1496014c916f9e62104b33d1bb5bd03b0858e59
Version: 1.1.11
GitCommit: v1.1.11-0-g4bccb38
Version: 0.19.0
GitCommit: de40ad0
v3.4.1。在线安装。在已有K8s(v1.21.0)上最小化安装
https://kubesphere.io/zh/docs/v3.4/quick-start/minimal-kubesphere-on-k8s/
QoS Class: Burstable
Node-Selectors: kubernetes.io/os=linux
Tolerations: dedicated=monitoring:NoSchedule
node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
Type Reason Age From Message
Warning FailedScheduling 5m2s (x6 over 60m) default-scheduler running PreBind plugin “VolumeBinding”: binding volumes: timed out waiting for the condition
