物理机,Ubuntu18.04,4C/32G
将 kubectl version
命令执行结果贴在下方
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
v3.4.1。在线安装。使用kk安装。
./kk create cluster –with-kubernetes v1.25.10 –with-kubesphere v3.4.1 –container-manager containerd
argocd cluster add 增加集群,当我使用默认安装后的配置文件~/.kube/config,提示 Failed to create service account “argocd-manager” in namespace “kube-system”: Post “https://公网IP:6443/api/v1/namespaces/kube-system/serviceaccounts”: tls: failed to verify certificate: x509: certificate is valid for 10.233.0.1, 10.206.16.29, 127.0.0.1, not 公网IP
命令:argocd cluster add dev11-cluster –insecure –kubeconfig kubeconfig.yaml
