虚拟机 CentOS 7.6
kubectl version
Client Version: version.Info{Major:"1", Minor:"18", GitVersion:"v1.18.4", GitCommit:"c96aede7b5205121079932896c4ad89bb93260af", GitTreeState:"clean", BuildDate:"2020-06-17T11:41:22Z", GoVersion:"go1.13.9", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"18", GitVersion:"v1.18.4", GitCommit:"c96aede7b5205121079932896c4ad89bb93260af", GitTreeState:"clean", BuildDate:"2020-06-17T11:33:59Z", GoVersion:"go1.13.9", Compiler:"gc", Platform:"linux/amd64"}
集群版本为1.18,只有docker,并没有使用containerd
docker version
Client:
 Version:           18.06.1-ce
 API version:       1.38
 Go version:        go1.10.3
 Git commit:        e68fc7a
 Built:             Tue Aug 21 17:23:03 2018
 OS/Arch:           linux/amd64
 Experimental:      false
Server:
  Version:          18.06.1-ce
  API version:      1.38 (minimum version 1.12)
  Git commit:       e68fc7a
  Built:            Tue Aug 21 17:25:29 2018
  Experimental:     false
v3.1.1
在线安装
在已有K8s上安装
ks-console频繁重启,导致web页面无法访问
1、查看pod日志,无异常信息,最近一次pod日志如下
> kubesphere-console@3.0.0 serve /opt/kubesphere/console
> NODE_ENV=production node server/server.js
Dashboard app running at port 8000
  <-- GET /kapis/monitoring.kubesphere.io/v1alpha3/namespaces/monolith/pods?cluster=default&ownerKind=ReplicaSet&labelSelector=app%3Dmonolith-web&resources_filter=monolith-web-7fb9f67cfc-xqrv7%24&metrics_filter=pod_cpu_usage%7Cpod_memory_usage_wo_cache%24 2024/03/20T13:55:01.864
2、使用kubectl命令describe ks-console 的pod,可以发现 存活探针探测8000端口超时
                 node-role.kubernetes.io/master:NoSchedule
                 node.kubernetes.io/not-ready:NoExecute for 60s
                 node.kubernetes.io/unreachable:NoExecute for 60s
Events:
  Type     Reason     Age                     From                Message
  Normal   Pulled     16m (x75 over 9d)       kubelet, k8s-prod1  Container image "harbor.ele-cloud.com:1080/kubesphereio/kubesphere/ks-console:v3.1.1" already present on machine
  Warning  Unhealthy  6m44s (x629 over 2d2h)  kubelet, k8s-prod1  Liveness probe failed: dial tcp 172.19.0.157:8000: connect: connection timed out
  Warning  BackOff    98s (x892 over 5h7m)    kubelet, k8s-prod1  Back-off restarting failed container
在节点上用 docker ps -a |grep ks-console ,检查下ks-console异常退出容器日志
    smartcat999
    docker ps -a |grep ks-console 这个命令,只能看容器状态和启动命令 吧?
    运行结果如下:
    13efde11ad4f202567d2f2bf56226210c0b7dbbd6db2427581dcaa05ad10e95a   sha256:0d4a1e7d9fef04999b2b4afd4a475db9089d76645c6007abc75f3a7cd64436db   "docker-entrypoint.sh npm run serve"        24 seconds ago      Up 23 seconds                                   k8s_ks-console_ks-console-646dd6dcb4-j4ts4_kubesphere-system_5f0a8701-fbbd-4930-9d6e-22b0b9ba3b2c_166
    cbb2527d5dc062c809b5d70a2ef025ff83555a94e9e26b2ee776fa2299906d8b   sha256:0d4a1e7d9fef04999b2b4afd4a475db9089d76645c6007abc75f3a7cd64436db   "docker-entrypoint.sh npm run serve"        2 minutes ago       Exited (0) 23 seconds ago                       k8s_ks-console_ks-console-646dd6dcb4-j4ts4_kubesphere-system_5f0a8701-fbbd-4930-9d6e-22b0b9ba3b2c_165
    0ff2dee952c1568f6b869e9599b478b57e9d8ad5353bf70142f03a2d792263f4   k8s.gcr.io/pause:3.2                                                      "/pause"        11 days ago         Up 11 days                                      k8s_POD_ks-console-646dd6dcb4-j4ts4_kubesphere-system_5f0a8701-fbbd-4930-9d6e-22b0b9ba3b2c_0
      3 个月 后
