• DevOps
  • DevOps流水线图形化编辑时遭遇错误no matches for kind "ClusterStepTemplate"
虚拟机,Centos7.9,4C/8G
最新版k3s:
Client Version: v1.29.3+k3s1
Server Version: v1.29.3+k3s1
Version:  0.1.0
RuntimeName:  containerd
RuntimeVersion:  v1.7.11-k3s2
RuntimeApiVersion:  v1
企业版v4.0。在已有K3s上安装。
如题所言,在流水线图形化编辑页面尝试添加一个Checkout时,报错:
no matches for kind “ClusterStepTemplate” in version “devops.kubesphere.io/v1alpha3”
截图如下:
在集群中查询“ClusterStepTemplate”这个CRD:
$ kubectl describe crd clustersteptemplates.devops.kubesphere.io
Namespace:
Labels:       <none>
Annotations:  controller-gen.kubebuilder.io/version: v0.6.2
API Version:  apiextensions.k8s.io/v1
Kind:         CustomResourceDefinition
Metadata:
  Creation Timestamp:  2024-04-15T14:50:24Z
  Generation:          1
  Resource Version:    57507
  UID:                 3ae767be-00c5-464d-9c7a-3655714427bf
Spec:
  Conversion:
    Strategy:  None
  Group:       devops.kubesphere.io
  Names:
    Kind:       ClusterStepTemplate
    List Kind:  ClusterStepTemplateList
    Plural:     clustersteptemplates
    Singular:   clustersteptemplate
  Scope:        Cluster
  Versions:
    Schema:
      openAPIV3Schema:
        Description:  ClusterStepTemplate is the Schema for the steptemplates API
        Properties:
          API Version:
            Description:  APIVersion defines the versioned schema of this representation of an object. Servers should convert recognized schemas to the latest internal value, and may reject unrecognized values. More info: https://git.k8s.io/community/contributors/devel/sig-architecture/api-conventions.md#resources
            Type:         string
          Kind:
            Description:  Kind is a string value representing the REST resource this object represents. Servers may infer this from the endpoint the client submits requests to. Cannot be updated. In CamelCase. More info: https://git.k8s.io/community/contributors/devel/sig-architecture/api-conventions.md#types-kinds
            Type:         string
          Metadata:
            Type:  object
          Spec:
            Description:  StepTemplateSpec defines the desired state of ClusterStepTemplate
            Properties:
              Agent:
                Type:  string
              Container:
                Type:  string
              Parameters:
                Items:
                  Description:  ParameterInStep is the parameter which used in a step
                  Properties:
                    Condition:
                      Description:  Condition is an expression about if this variable is necessary for users
                      Type:         string
                    Default Value:
                      Type:  string
                    Display:
                      Type:  string
                    Name:
                      Type:  string
                    Options:
                      Type:  string
                    Reactions:
                      Description:  represents that the relationship of parameters
                      Type:         string
                    Required:
                      Type:  boolean
                    Type:
                      Description:  ParameterType represents the type of parameter
                      Type:         string
                  Required:
                    name
                  Type:  object
                Type:    array
              Runtime:
                Type:  string
              Secret:
                Description:  SecretInStep is the secret which used in a step
                Properties:
                  Mapping:
                    Additional Properties:
                      Type:  string
                    Type:    object
                  Type:
                    Type:  string
                  Wrap:
                    Type:  boolean
                Type:      object
              Template:
                Type:  string
            Type:      object
          Status:
            Description:  StepTemplateStatus defines the observed state of ClusterStepTemplate
            Properties:
              Phase:
                Description:  StepTemplatePhase represents the phase of the Step template
                Type:         string
            Required:
              phase
            Type:  object
        Type:      object
    Served:        true
    Storage:       true
    Subresources:
      Status:
Status:
  Accepted Names:
  Conditions:
    Last Transition Time:  2024-04-15T14:50:24Z
    Message:               no conflicts found
    Reason:                NoConflicts
    Status:                True
    Type:                  NamesAccepted
    Message:               the initial names have been accepted
    Reason:                InitialNamesAccepted
    Status:                True
    Type:                  Established
  Stored Versions:
    v1alpha3
Events:  <none>
