• 安装部署
  • arm架构的麒麟v10服务器版本系统如何安装kubesphere
操作系统信息:物理机,Kylin Linux Advanced Server v10 64c/128G
如何安装kubeSphere 3.1的版本单节点
6 天 后
arm架构的可以尝试使用 ClusterConfig 指定节点架构
  1. 创建kk配置文件
    kk create config
  2. 修改节点信息/节点架构
    cat config-sample.yaml
    kind: Cluster
    hosts:
    - {name: node1, address: 172.16.0.2, internalAddress: 172.16.0.2, user: ubuntu, password: "Qcloud@123"}
    - {name: node2, address: 172.16.0.3, internalAddress: 172.16.0.3, user: ubuntu, password: "Qcloud@123"}
    roleGroups:
    - node1
    control-plane:
    - node1
    worker:
    - node1
    - node2
    controlPlaneEndpoint:
    # internalLoadbalancer: haproxy
    domain: lb.kubesphere.local
    address: ""
    port: 6443
    kubernetes:
    version: v1.23.10
    clusterName: cluster.local
    autoRenewCerts: true
    containerManager: docker
    type: kubekey
    network:
    plugin: calico
    kubePodsCIDR: 10.233.64.0/18
    multusCNI:
    enabled: false
    registry:
    privateRegistry: ""
    namespaceOverride: ""
    registryMirrors: []
    insecureRegistries: []
    addons: []
    注意节点架构配置
    For example, {…user: ubuntu, password: Qcloud@123, arch: arm64}.
  3. kk create cluster -f config-sample.yaml –with-kubesphere <版本号>
    参考截图:
    参考链接:https://github.com/kubesphere/kubekey/blob/master/docs/config-example.md
