例如:虚拟机/ openeuler 22.03.
将 kubectl version
命令执行结果贴在下方
kubeect 1.23.115
将 docker 24.
/ crictl version
/ nerdctl version
结果贴在下方
例如:离线安装 k8s1.23.15+kubesphere3.4.1。
/tmp/kubekey/iso/* 文件无法删除
17:50:19 CST retry: [node148]
17:50:24 CST message: [node148]
reset tmp dir failed: reset tmp dir failed: Failed to exec command: sudo -E /bin/bash -c “if [ -d /tmp/kubekey ]; then rm -rf /tmp/kubekey ;fi && mkdir -m 777 -p /tmp/kubekey”
rm: 无法删除 ‘/tmp/kubekey/iso/acl-2.2.51-15.el7.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/attr-2.4.46-13.el7.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/at-3.1.13-25.el7_9.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/audit-libs-2.8.5-4.el7.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/audit-libs-2.8.5-4.el7.i686.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/audit-libs-python-2.8.5-4.el7.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/avahi-libs-0.6.31-20.el7.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/basesystem-10.0-7.el7.centos.noarch.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/bash-4.2.46-35.el7_9.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/bash-completion-2.1-8.el7.noarch.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/bc-1.06.95-13.el7.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/bind-libs-9.11.4-26.P2.el7_9.10.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/bind-libs-lite-9.11.4-26.P2.el7_9.10.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/bind-license-9.11.4-26.P2.el7_9.10.noarch.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/bind-utils-9.11.4-26.P2.el7_9.10.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/binutils-2.27-44.base.el7_9.1.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/boost-random-1.53.0-28.el7.x86_64.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/boost-system-1.53.0-28.el7.i686.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/boost-iostreams-1.53.0-28.el7.i686.rpm’: Read-only file system
rm: 无法删除 ‘/tmp/kubekey/iso/boost-thread-1.53.0-28.el7.x86_64.rpm’: Read-only file system
请求大佬帮助 谢谢
