• 安装部署
  • 离线安装受限,当前制作离线manifest制品时,无法成功
openeuler 22.03LTS
v1.25.3
containerd
v3.4.1
[root@master install]# ./kk artifact export -m manifest-sample.yaml -o kubernetes.tar.gz
| |\ \ || | |) | __/ |\ \ __/ |_| |
\| \/\,|./ \\| \/\|\__, |
                                __/ |
                               |___/
10:57:55 CST [CheckFileExist] Check output file if existed
10:57:55 CST success: [LocalHost]
10:57:55 CST [CopyImagesToLocalModule] Copy images to a local OCI path from registries
10:57:55 CST Source: docker://docker.io/calico/cni:v3.26.1
10:57:55 CST Destination: oci:/opt/install/kubekey/artifact/images:calico:cni:v3.26.1-amd64
11:03:00 CST message: [LocalHost]
initializing source docker://calico/cni:v3.26.1: Get “https://registry-1.docker.io/v2/calico/cni/manifests/v3.26.1”: read tcp 10.30.10.13:54170->3.219.239.5:443: read: connection reset by peer
11:03:00 CST failed: [LocalHost]
error: Pipeline[ArtifactExportPipeline] execute failed: Module[CopyImagesToLocalModule] exec failed:
failed: [LocalHost] [SaveImages] exec failed after 1 retries: initializing source docker://calico/cni:v3.26.1: Get “https://registry-1.docker.io/v2/calico/cni/manifests/v3.26.1”: read tcp 10.30.10.13:54170->3.219.239.5:443: read: connection reset by peer
更换containerd的endpoint地址配置暂时也无法解决该问题
13 天 后
请教下manifest-sample.yaml 文件中依赖的iso文件是如何获取的?
kind: Manifest
arches:
  • amd64
    operatingSystems:
  • arch: amd64
    type: linux
    version: “Can’t get the os version. Please edit it manually.”
    osImage: openEuler 22.03 (LTS-SP2)
    repository:
    iso:
    localPath:
    url:
