机器均来自阿里云和腾讯云
NAME             VERSION        INTERNAL-IP   OS-IMAGE                KERNEL-VERSION              CPU(cores)   CPU%   MEMORY(bytes)   MEMORY%
k8s-master       v1.29.5+k3s1   10.8.0.2      Ubuntu 22.04 LTS        5.15.0-107-generic          331m         16%    1537Mi          78%
k8s-master-2     v1.29.5+k3s1   10.8.0.4      Ubuntu 22.04.3 LTS      5.15.0-1032-realtime        196m         9%     1252Mi          73%
k8s-slave-1-bj   v1.29.5+k3s1   10.8.0.3      CentOS Linux 7 (Core)   6.9.6-1.el7.elrepo.x86_64   159m         15%    1138Mi          57%
Client Version: v1.29.5+k3s1
Server Version: v1.29.5+k3s1
NAME             CONTAINER-RUNTIME
k8s-master       containerd://1.7.15-k3s1
k8s-master-2     docker://26.1.3
k8s-slave-1-bj   docker://26.1.4
版本:v3.4.1,k8s在线部署
提示minio安装失败,但未找到相关报错信息
未发现minio相关容器及任务
2024-06-30T19:39:08+08:00 INFO     : shell-operator latest
2024-06-30T19:39:08+08:00 INFO     : Use temporary dir: /tmp/shell-operator
2024-06-30T19:39:08+08:00 INFO     : Initialize hooks manager ...
2024-06-30T19:39:08+08:00 INFO     : Search and load hooks ...
2024-06-30T19:39:08+08:00 INFO     : Load hook config from '/hooks/kubesphere/installRunner.py'
2024-06-30T19:39:08+08:00 INFO     : HTTP SERVER Listening on 0.0.0.0:9115
2024-06-30T19:39:09+08:00 INFO     : Load hook config from '/hooks/kubesphere/schedule.sh'
2024-06-30T19:39:09+08:00 INFO     : Initializing schedule manager ...
2024-06-30T19:39:09+08:00 INFO     : KUBE Init Kubernetes client
2024-06-30T19:39:09+08:00 INFO     : KUBE-INIT Kubernetes client is configured successfully
2024-06-30T19:39:09+08:00 INFO     : MAIN: run main loop
2024-06-30T19:39:09+08:00 INFO     : MAIN: add onStartup tasks
2024-06-30T19:39:09+08:00 INFO     : Running schedule manager ...
2024-06-30T19:39:09+08:00 INFO     : QUEUE add all HookRun@OnStartup
2024-06-30T19:39:09+08:00 INFO     : MSTOR Create new metric shell_operator_live_ticks
2024-06-30T19:39:09+08:00 INFO     : MSTOR Create new metric shell_operator_tasks_queue_length
2024-06-30T19:39:09+08:00 INFO     : GVR for kind 'ClusterConfiguration' is installer.kubesphere.io/v1alpha1, Resource=clusterconfigurations
2024-06-30T19:39:09+08:00 INFO     : EVENT Kube event '222ae00b-44b2-4825-9dc5-5b1f0178ce3a'
2024-06-30T19:39:09+08:00 INFO     : QUEUE add TASK_HOOK_RUN@KUBE_EVENTS kubesphere/installRunner.py
2024-06-30T19:39:12+08:00 INFO     : TASK_RUN HookRun@KUBE_EVENTS kubesphere/installRunner.py
2024-06-30T19:39:12+08:00 INFO     : Running hook 'kubesphere/installRunner.py' binding 'KUBE_EVENTS'
the implicit localhost does not match 'all'
TASK [download : Generating images list] ***************************************
skipping: [localhost]
TASK [download : Synchronizing images] *****************************************
TASK [kubesphere-defaults : KubeSphere | Setting images' namespace override] ***
TASK [kubesphere-defaults : KubeSphere | Configuring defaults] *****************
ok: [localhost] => {
    "msg": "Check roles/kubesphere-defaults/defaults/main.yml"
TASK [preinstall : KubeSphere | Stopping if Kubernetes version is nonsupport] ***
    "changed": false,
    "msg": "All assertions passed"
TASK [preinstall : KubeSphere | Checking StorageClass] *************************
changed: [localhost]
TASK [preinstall : KubeSphere | Stopping if StorageClass was not found] ********
TASK [preinstall : KubeSphere | Checking default StorageClass] *****************
TASK [preinstall : KubeSphere | Stopping if default StorageClass was not found] ***
    "changed": false,
TASK [preinstall : KubeSphere | Stop if bad admin password] ********************
TASK [preinstall : KubeSphere | Checking KubeSphere component] *****************
TASK [preinstall : KubeSphere | Getting KubeSphere component version] **********
skipping: [localhost] => (item=ks-openldap)
skipping: [localhost] => (item=ks-redis)
skipping: [localhost] => (item=ks-minio)
skipping: [localhost] => (item=ks-openpitrix)
skipping: [localhost] => (item=elasticsearch-logging)
skipping: [localhost] => (item=elasticsearch-logging-curator)
skipping: [localhost] => (item=istio)
skipping: [localhost] => (item=istio-init)
skipping: [localhost] => (item=jaeger-operator)
skipping: [localhost] => (item=ks-jenkins)
skipping: [localhost] => (item=ks-sonarqube)
skipping: [localhost] => (item=logging-fluentbit-operator)
skipping: [localhost] => (item=uc)
skipping: [localhost] => (item=metrics-server)
localhost                  : ok=7    changed=4    unreachable=0    failed=0    skipped=6    rescued=0    ignored=0
TASK [Metrics-Server | Getting metrics-server installation files] **************
skipping: [localhost] => (item={'file': 'metrics-server.yaml'})
TASK [metrics-server : Metrics-Server | Checking Metrics-Server] ***************
TASK [Metrics-Server | Uninstalling old metrics-server] ************************
TASK [Metrics-Server | Installing new metrics-server] **************************
TASK [metrics-server : Metrics-Server | Waitting for metrics.k8s.io ready] *****
TASK [Metrics-Server | Importing metrics-server status] ************************
localhost                  : ok=1    changed=0    unreachable=0    failed=0    skipped=10   rescued=0    ignored=0
TASK [common : KubeSphere | Checking kube-node-lease namespace] ****************
TASK [common : KubeSphere | Getting system namespaces] *************************
ok: [localhost]
TASK [common : set_fact] *******************************************************
ok: [localhost]
TASK [common : debug] **********************************************************
    "msg": [
        "kubesphere-system",
        "kubesphere-controls-system",
        "kubesphere-monitoring-system",
        "kubesphere-monitoring-federated",
        "kube-node-lease"
TASK [common : KubeSphere | Creating KubeSphere namespace] *********************
changed: [localhost] => (item=kubesphere-system)
changed: [localhost] => (item=kubesphere-controls-system)
changed: [localhost] => (item=kubesphere-monitoring-system)
changed: [localhost] => (item=kubesphere-monitoring-federated)
changed: [localhost] => (item=kube-node-lease)
TASK [common : KubeSphere | Labeling system-workspace] *************************
changed: [localhost] => (item=default)
changed: [localhost] => (item=kube-public)
changed: [localhost] => (item=kube-system)
TASK [common : KubeSphere | Labeling namespace for network policy] *************
TASK [common : KubeSphere | Getting Kubernetes master num] *********************
TASK [common : KubeSphere | Setting master num] ********************************
ok: [localhost]
TASK [KubeSphere | Getting common component installation files] ****************
changed: [localhost] => (item=common)
TASK [common : KubeSphere | Checking Kubernetes version] ***********************
changed: [localhost] => (item=snapshot-controller)
TASK [common : KubeSphere | Creating snapshot controller values] ***************
changed: [localhost] => (item={'name': 'custom-values-snapshot-controller', 'file': 'custom-values-snapshot-controller.yaml'})
TASK [common : KubeSphere | Updating snapshot crd] *****************************
TASK [common : KubeSphere | Deploying snapshot controller] *********************
TASK [KubeSphere | Checking openpitrix common component] ***********************
TASK [common : include_tasks] **************************************************
skipping: [localhost] => (item={'op': 'openpitrix-db', 'ks': 'mysql-pvc'})
skipping: [localhost] => (item={'op': 'openpitrix-etcd', 'ks': 'etcd-pvc'})
TASK [common : Getting PersistentVolumeName (mysql)] ***************************
TASK [common : Getting PersistentVolumeSize (mysql)] ***************************
TASK [common : Setting PersistentVolumeName (mysql)] ***************************
TASK [common : Setting PersistentVolumeSize (mysql)] ***************************
TASK [common : Getting PersistentVolumeName (etcd)] ****************************
TASK [common : Getting PersistentVolumeSize (etcd)] ****************************
TASK [common : Setting PersistentVolumeName (etcd)] ****************************
TASK [common : Setting PersistentVolumeSize (etcd)] ****************************
TASK [common : KubeSphere | Checking mysql PersistentVolumeClaim] **************
TASK [common : KubeSphere | Setting mysql db pv size] **************************
TASK [common : KubeSphere | Checking redis PersistentVolumeClaim] **************
TASK [common : KubeSphere | Setting redis db pv size] **************************
ok: [localhost]
TASK [common : KubeSphere | Checking minio PersistentVolumeClaim] **************
TASK [common : KubeSphere | Setting minio pv size] *****************************
TASK [common : KubeSphere | Checking openldap PersistentVolumeClaim] ***********
TASK [common : KubeSphere | Setting openldap pv size] **************************
TASK [common : KubeSphere | Checking etcd db PersistentVolumeClaim] ************
TASK [common : KubeSphere | Setting etcd pv size] ******************************
TASK [common : KubeSphere | Checking redis ha PersistentVolumeClaim] ***********
TASK [common : KubeSphere | Setting redis ha pv size] **************************
TASK [common : KubeSphere | Checking es-master PersistentVolumeClaim] **********
TASK [common : KubeSphere | Setting es master pv size] *************************
TASK [common : KubeSphere | Checking es data PersistentVolumeClaim] ************
TASK [common : KubeSphere | Setting es data pv size] ***************************
TASK [common : KubeSphere | Checking opensearch-master PersistentVolumeClaim] ***
TASK [common : KubeSphere | Setting opensearch master pv size] *****************
TASK [common : KubeSphere | Checking opensearch data PersistentVolumeClaim] ****
TASK [common : KubeSphere | Setting opensearch data pv size] *******************
TASK [KubeSphere | Creating common component manifests] ************************
changed: [localhost] => (item={'path': 'redis', 'file': 'redis.yaml'})
TASK [common : KubeSphere | Deploying etcd and mysql] **************************
skipping: [localhost] => (item=etcd.yaml)
skipping: [localhost] => (item=mysql.yaml)
TASK [common : KubeSphere | Getting minio installation files] ******************
skipping: [localhost] => (item=minio-ha)
TASK [common : KubeSphere | Creating manifests] ********************************
skipping: [localhost] => (item={'name': 'custom-values-minio', 'file': 'custom-values-minio.yaml'})
TASK [common : KubeSphere | Checking minio] ************************************
TASK [common : KubeSphere | Deploying minio] ***********************************
TASK [common : fail] ***********************************************************
TASK [common : KubeSphere | Importing minio status] ****************************
TASK [common : KubeSphere | Generet Random password] ***************************
TASK [common : KubeSphere | Creating Redis Password Secret] ********************
TASK [common : KubeSphere | Getting redis installation files] ******************
skipping: [localhost] => (item=redis-ha)
skipping: [localhost] => (item={'name': 'custom-values-redis', 'file': 'custom-values-redis.yaml'})
TASK [common : KubeSphere | Checking old redis status] *************************
TASK [common : KubeSphere | Deleting and backup old redis svc] *****************
TASK [common : KubeSphere | Deploying redis] ***********************************
skipping: [localhost] => (item=redis.yaml)
TASK [common : KubeSphere | Importing redis status] ****************************
TASK [common : KubeSphere | Getting openldap installation files] ***************
skipping: [localhost] => (item=openldap-ha)
skipping: [localhost] => (item={'name': 'custom-values-openldap', 'file': 'custom-values-openldap.yaml'})
TASK [common : KubeSphere | Checking old openldap status] **********************
TASK [common : KubeSphere | Shutdown ks-account] *******************************
TASK [common : KubeSphere | Deleting and backup old openldap svc] **************
TASK [common : KubeSphere | Checking openldap] *********************************
TASK [common : KubeSphere | Deploying openldap] ********************************
TASK [common : KubeSphere | Loading old openldap data] *************************
TASK [common : KubeSphere | Checking openldap-ha status] ***********************
TASK [common : KubeSphere | Getting openldap-ha pod list] **********************
TASK [common : KubeSphere | Getting old openldap data] *************************
TASK [common : KubeSphere | Migrating openldap data] ***************************
TASK [common : KubeSphere | Disabling old openldap] ****************************
TASK [common : KubeSphere | Restarting openldap] *******************************
TASK [common : KubeSphere | Restarting ks-account] *****************************
TASK [common : KubeSphere | Importing openldap status] *************************
TASK [common : KubeSphere | Checking KubeSphere Config is Exists] **************
changed: [localhost] => (item=minio-ha)
changed: [localhost] => (item={'name': 'custom-values-minio', 'file': 'custom-values-minio.yaml'})
    "msg": [
        "1. check the storage configuration and storage server",
        "2. make sure the DNS address in /etc/resolv.conf is available",
        "3. execute 'kubectl logs -n kubesphere-system -l job-name=minio-make-bucket-job' to watch logs",
        "4. execute 'helm -n kubesphere-system uninstall ks-minio && kubectl -n kubesphere-system delete job minio-make-bucket-job'",
        "5. Restart the installer pod in kubesphere-system namespace"
fatal: [localhost]: FAILED! => {"changed": false, "msg": "It is suggested to refer to the above methods for troubleshooting problems ."}
localhost                  : ok=35   changed=28   unreachable=0    failed=1    skipped=79   rescued=0    ignored=0
