- 已编辑
环境:centos7.5
高可用版本安装,前端负载均衡已经使用haproxy做好,下面是详细日志:
TASK [Restart docker] **************************************************************************************
Tuesday 13 October 2020 11:15:40 +0800 (0:00:00.220) 0:00:01.683 *******
fatal: [k8s-master03]: FAILED! => {
"changed": true,
"cmd": "systemctl daemon-reload && service docker restart",
"delta": "0:00:00.094993",
"end": "2020-10-13 11:15:41.389433",
"rc": 1,
"start": "2020-10-13 11:15:41.294440"
STDERR:
Redirecting to /bin/systemctl restart docker.service
Job for docker.service failed because the control process exited with error code. See "systemctl status docker.service" and "journalctl -xe" for details.
MSG:
non-zero return code
PLAY RECAP *************************************************************************************************
k8s-master01 : ok=2 changed=2 unreachable=0 failed=0
k8s-master02 : ok=2 changed=2 unreachable=0 failed=0
k8s-master03 : ok=4 changed=2 unreachable=0 failed=1
k8s-node01 : ok=2 changed=2 unreachable=0 failed=0
k8s-node02 : ok=2 changed=2 unreachable=0 failed=0
k8s-node03 : ok=2 changed=2 unreachable=0 failed=0
Tuesday 13 October 2020 11:15:40 +0800 (0:00:00.409) 0:00:02.092 *******
config docker-ce ------------------------------------------------------------------------------------ 0.69s
Restart docker -------------------------------------------------------------------------------------- 0.41s
Swap off -------------------------------------------------------------------------------------------- 0.28s
Disable swap ---------------------------------------------------------------------------------------- 0.25s
check docker-options -------------------------------------------------------------------------------- 0.22s
loadbalancer_apiserver is not set ------------------------------------------------------------------- 0.03s
failed!
