awk eks
Client Version: v1.30.2
Server Version: v1.30.2-eks-db838b0
v3.4.1在线安装。在aws eks上面安装kubesphere失败。
失败原因
Default StorageClass was not found !
TASK [preinstall : KubeSphere | Checking StorageClass] *************************
changed: [localhost]
TASK [preinstall : KubeSphere | Stopping if StorageClass was not found] ********
skipping: [localhost]
TASK [preinstall : KubeSphere | Checking default StorageClass] *****************
TASK [preinstall : KubeSphere | Stopping if default StorageClass was not found] ***
fatal: [localhost]: FAILED! => {
"assertion": "\"(default)\" in default_storage_class_check.stdout",
"changed": false,
"evaluated_to": false,
"msg": "Default StorageClass was not found !"
localhost : ok=4 changed=2 unreachable=0 failed=1 skipped=4 rescued=0 ignored=0
eks 是有默认的存储gp2的
