将 kubectl version
命令执行结果贴在下方
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
例如:v1.23.15/v3.0.0。在线安装。使用kk安装。
error: No SHA256 found for v1.23.15. v1.23.15 is not supported.
Error: Failed to download kube binaries: No SHA256 found for v1.23.15. v1.23.15 is not supported.
Usage:
kk create cluster [flags]
Flags:
--container-manager string Container runtime: docker, crio, containerd and isula. (default "docker")
--download-cmd string The user defined command to download the necessary binary files. The first param '%s' is output path, the second param '%s', is the URL (default "curl -L -o %s %s")
-f, –filename string Path to a configuration file
-h, –help help for cluster
--skip-pull-images Skip pre pull images
--with-kubernetes string Specify a supported version of kubernetes (default "v1.21.5")
--with-kubesphere Deploy a specific version of kubesphere (default v3.2.0)
--with-local-storage Deploy a local PV provisioner
-y, –yes Skip pre-check of the installation
Global Flags:
--debug Print detailed information (default true)
--in-cluster Running inside the cluster
