export KKZONE=cn
./kk create cluster –with-kubernetes v1.30.1 –container-manager containerd
如果使用kk_v4.0.0-alpha.5_linux_amd64.tar.gz版本,报错:
Execute pre install scripts
[localhost] failed [0s]
E1028 14:12:46.977523 43793 task_executor.go:126] “task run failed” host=“localhost” stdout=<
for file in /etc/kubekey/scripts/pre_install_*.sh; do
如果使用,kk_v4.0.0-alpha.4_linux_amd64.tar.gz 版本,后面也一直卡在
E1028 13:42:27.580421 43524 command_manager.go:85] “executor tasks error” err=<
exec batch hosts error: merge variable error: failed to execute template '{{- if and .image_registry.ha_vip (ne .image_registry.ha_vip "") }}
