• 安装部署
  • 海光物理机在使用kkv3.1.7安装k8s1.27.16的时候pod calico-node无法启动
问题
calico-node 无法启动
calico-kubeconfig 里面server 为啥包含[ ]字符
海光Hygon C86 7380cpu物理机,Ubuntu 22.04.5 LTS,128C/256G
root@localhost:~/kubesphere# kubectl version
WARNING: This version information is deprecated and will be replaced with the output from kubectl version --short.  Use --output=yaml|json to get the full version.
Client Version: version.Info{Major:"1", Minor:"27", GitVersion:"v1.27.16", GitCommit:"cbb86e0d7f4a049666fac0551e8b02ef3d6c3d9a", GitTreeState:"clean", BuildDate:"2024-07-17T01:53:56Z", GoVersion:"go1.22.5", Compiler:"gc", Platform:"linux/amd64"}
Kustomize Version: v5.0.1
Server Version: version.Info{Major:"1", Minor:"27", GitVersion:"v1.27.16", GitCommit:"cbb86e0d7f4a049666fac0551e8b02ef3d6c3d9a", GitTreeState:"clean", BuildDate:"2024-07-17T01:44:26Z", GoVersion:"go1.22.5", Compiler:"gc", Platform:"linux/amd64"}
root@localhost:~/kubesphere# crictl version
Version:  0.1.0
RuntimeName:  containerd
RuntimeVersion:  v1.7.13
RuntimeApiVersion:  v1
Calico-node日志
root@localhost:~/kubesphere# kubectl get pod -n kube-system
NAME                                       READY   STATUS              RESTARTS        AGE
calico-kube-controllers-6d7dfcb56d-tjkj4   0/1     ContainerCreating   0               10m
calico-node-chk57                          0/1     CrashLoopBackOff    6 (4m53s ago)   10m
coredns-5d6688d45b-9tj4m                   0/1     ContainerCreating   0               10m
coredns-5d6688d45b-tzgk8                   0/1     ContainerCreating   0               10m
kube-apiserver-k8s-master                  1/1     Running             0               10m
kube-controller-manager-k8s-master         1/1     Running             0               10m
kube-proxy-hs6b7                           1/1     Running             0               10m
kube-scheduler-k8s-master                  1/1     Running             0               10m
nodelocaldns-k2hz7                         1/1     Running             0               10m
root@localhost:~/kubesphere# kubectl logs calico-node-chk57 -n kube-system
Defaulted container "calico-node" out of: calico-node, upgrade-ipam (init), install-cni (init), mount-bpffs (init)
root@localhost:~/kubesphere# kubectl logs calico-node-chk57 -n kube-system -c upgrade-ipam
2024-11-05 04:16:32.472 [INFO][1] ipam_plugin.go 79: migrating from host-local to calico-ipam...
2024-11-05 04:16:32.481 [INFO][1] migrate.go 66: checking host-local IPAM data dir dir existence...
2024-11-05 04:16:32.481 [INFO][1] migrate.go 68: host-local IPAM data dir dir not found; no migration necessary, successfully exiting...
2024-11-05 04:16:32.481 [INFO][1] ipam_plugin.go 109: migration from host-local to calico-ipam complete node="k8s-master"
root@localhost:~/kubesphere# kubectl logs calico-node-chk57 -n kube-system -c install-cni
2024-11-05 04:16:33.588 [INFO][1] cni-installer/<nil> <nil>: Running as a Kubernetes pod
2024-11-05 04:16:33.620 [INFO][1] cni-installer/<nil> <nil>: Installed /host/opt/cni/bin/bandwidth
2024-11-05 04:16:33.775 [INFO][1] cni-installer/<nil> <nil>: File is already up to date, skipping file="/host/opt/cni/bin/calico"
2024-11-05 04:16:33.885 [INFO][1] cni-installer/<nil> <nil>: Installed /host/opt/cni/bin/calico
2024-11-05 04:16:34.030 [INFO][1] cni-installer/<nil> <nil>: File is already up to date, skipping file="/host/opt/cni/bin/calico-ipam"
2024-11-05 04:16:34.137 [INFO][1] cni-installer/<nil> <nil>: Installed /host/opt/cni/bin/calico-ipam
2024-11-05 04:16:34.146 [INFO][1] cni-installer/<nil> <nil>: File is already up to date, skipping file="/host/opt/cni/bin/flannel"
2024-11-05 04:16:34.151 [INFO][1] cni-installer/<nil> <nil>: Installed /host/opt/cni/bin/flannel
2024-11-05 04:16:34.179 [INFO][1] cni-installer/<nil> <nil>: Installed /host/opt/cni/bin/host-local
2024-11-05 04:16:34.208 [INFO][1] cni-installer/<nil> <nil>: Installed /host/opt/cni/bin/loopback
2024-11-05 04:16:34.238 [INFO][1] cni-installer/<nil> <nil>: Installed /host/opt/cni/bin/portmap
2024-11-05 04:16:34.266 [INFO][1] cni-installer/<nil> <nil>: Installed /host/opt/cni/bin/tuning
2024-11-05 04:16:34.266 [INFO][1] cni-installer/<nil> <nil>: Wrote Calico CNI binaries to /host/opt/cni/bin
2024-11-05 04:16:34.266 [INFO][1] cni-installer/<nil> <nil>: CNI plugin version: v3.27.4
2024-11-05 04:16:34.266 [INFO][1] cni-installer/<nil> <nil>: /host/secondary-bin-dir is not writeable, skipping
2024-11-05 04:16:34.266 [WARNING][1] cni-installer/<nil> <nil>: Neither --kubeconfig nor --master was specified.  Using the inClusterConfig.  This might not work.
2024-11-05 04:16:34.280 [INFO][1] cni-installer/<nil> <nil>: Using CNI config template from CNI_NETWORK_CONFIG environment variable.
2024-11-05 04:16:34.281 [INFO][1] cni-installer/<nil> <nil>: Created /host/etc/cni/net.d/10-calico.conflist
2024-11-05 04:16:34.281 [INFO][1] cni-installer/<nil> <nil>: Done configuring CNI.  Sleep= false
  "name": "k8s-pod-network",
  "cniVersion": "0.3.1",
  "plugins": [
      "type": "calico",
      "log_level": "info",
      "log_file_path": "/var/log/calico/cni/cni.log",
      "datastore_type": "kubernetes",
      "nodename": "k8s-master",
      "mtu": 0,
      "ipam": {
          "type": "calico-ipam"
      "policy": {
          "type": "k8s"
      "kubernetes": {
          "kubeconfig": "/etc/cni/net.d/calico-kubeconfig"
      "type": "portmap",
      "snat": true,
      "capabilities": {"portMappings": true}
      "type": "bandwidth",
      "capabilities": {"bandwidth": true}
root@localhost:~/kubesphere# kubectl logs calico-node-chk57 -n kube-system -c mount-bpffs
2024-11-05 04:16:34.690 [INFO][1] init-best-effort/startup.go 445: Early log level set to info
2024-11-05 04:16:34.691 [INFO][1] init-best-effort/calico-init_linux.go 57: Checking if BPF filesystem is mounted.
2024-11-05 04:16:34.691 [INFO][1] init-best-effort/calico-init_linux.go 69: BPF filesystem is mounted.
2024-11-05 04:16:34.691 [INFO][1] init-best-effort/calico-init_linux.go 92: Checking if cgroup2 filesystem is mounted.
2024-11-05 04:16:34.692 [INFO][1] init-best-effort/calico-init_linux.go 111: Cgroup2 filesystem is mounted.
Calico-kubeconfig
# Kubeconfig file for Calico CNI plugin.
kind: Config
clusters:
- name: local
  cluster:
    server: https://[10.233.0.1]:443
    certificate-authority-data: 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
users:
- name: calico
  user:
基础镜像有点不兼容、手动重新打包启动成功
[96240.971611] bash[6362]: segfault at 55a19e100320 ip 00007fc120650ead sp 00007ffdebc3f608 error 4 in libc-2.28.so[7fc12062c000+1cd000]
root@k8s-master:~/kubesphere# kubectl get pod -n kube-system
calico-kube-controllers-6f996c8485-8nq2v       1/1     Running   0          6m7s
calico-node-mx724                              1/1     Running   0          6m8s
coredns-78445484fd-9j8gq                       1/1     Running   0          6m7s
coredns-78445484fd-wkfkg                       1/1     Running   0          6m7s
kube-apiserver-k8s-master                      1/1     Running   0          6m15s
kube-controller-manager-k8s-master             1/1     Running   0          6m22s
kube-proxy-v8vks                               1/1     Running   0          6m8s
kube-scheduler-k8s-master                      1/1     Running   0          6m15s
nodelocaldns-2bfwz                             1/1     Running   0          6m8s
openebs-localpv-provisioner-7bbcf865cd-56dwd   1/1     Running   0          6m7s
2 个月 后
您好,请问下 基础镜像有点不兼容具体指的是哪个,具体怎么操作解决的?
    2 个月 后
    请问具体是怎么“手动重新打包”。
