将 kubectl version
命令执行结果贴在下方
Client Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.1”, GitCommit:“632ed300f2c34f6d6d15ca4cef3d3c7073412212”, GitTreeState:“clean”, BuildDate:“2021-08-19T15:38:26Z”, GoVersion:“go1.16.6”, Compiler:“gc”, Platform:“darwin/amd64”}
Server Version: version.Info{Major:“1”, Minor:“30”, GitVersion:“v1.30.5”, GitCommit:“74e84a90c725047b1328ff3d589fedb1cb7a120e”, GitTreeState:“clean”, BuildDate:“2024-09-12T22:29:43Z”, GoVersion:“go1.22.6”, Compiler:“gc”, Platform:“linux/amd64”}
WARNING: version difference between client (1.22) and server (1.30) exceeds the supported minor version skew of +/-1
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
我部署了一个hlem应用,里面简单的配置了几个ns的创建,我新增了一个ns,然后打了一个新helm包,点击更新,没有报错,但是实际上并没有创建出来。
我看了job的运行状态,实际上并没有再次运行,只有首次运行成功了。
k get pods -n eve-base
helm-executor-install-domestic-base-bwcntg-r8njr 0/1 Completed 0 41m
