离线安装 kubesphere+k8s 报拉镜像registry.k8s.io/pause:3.8失败 无法启动k8s
8080端口是谁的? 为什么启来?
14:54:35 CST stdout: [master]
E1211 14:54:35.007262 39398 memcache.go:265] couldn’t get current server API group list: Get “http://localhost:8080/api?timeout=32s”: dial tcp 127.0.0.1:8080: connect: connection refused
E1211 14:54:35.009045 39398 memcache.go:265] couldn’t get current server API group list: Get “http://localhost:8080/api?timeout=32s”: dial tcp 127.0.0.1:8080: connect: connection refused
E1211 14:54:35.009898 39398 memcache.go:265] couldn’t get current server API group list: Get “http://localhost:8080/api?timeout=32s”: dial tcp 127.0.0.1:8080: connect: connection refused
E1211 14:54:35.011881 39398 memcache.go:265] couldn’t get current server API group list: Get “http://localhost:8080/api?timeout=32s”: dial tcp 127.0.0.1:8080: connect: connection refused
E1211 14:54:35.012490 39398 memcache.go:265] couldn’t get current server API group list: Get “http://localhost:8080/api?timeout=32s”: dial tcp 127.0.0.1:8080: connect: connection refused
The connection to the server localhost:8080 was refused - did you specify the right host or port?
14:54:35 CST message: [master]
get kubernetes cluster info failed: Failed to exec command: sudo -E /bin/bash -c “/usr/local/bin/kubectl –no-headers=true get nodes -o custom-columns=:metadata.name,:status.nodeInfo.kubeletVersion,:status.addresses”
The connection to the server localhost:8080 was refused - did you specify the right host or port?: Process exited with status 1
14:54:35 CST retry: [master]
14:54:40 CST stdout: [master]
API Server 默认端口
安全端口 (
--secure-port
):- 默认值:
6443
- 这是常用的端口,使用 HTTPS 协议,并需要认证和授权。
- 默认值:
非安全端口 (
--insecure-port
):默认值:
8080
从 Kubernetes 1.20 开始,默认值为 0(禁用)。
不推荐使用,建议仅使用安全端口。
cat /etc/kubernetes/manifests/kube-apiserver.yaml
kind: Pod
annotations:
kubeadm.kubernetes.io/kube-apiserver.advertise-address.endpoint: 172.16.21.35:6443
creationTimestamp: null
component: kube-apiserver
tier: control-plane
namespace: kube-system
containers:
command:
kube-apiserver
–advertise-address=172.16.21.35
–allow-privileged=true
–authorization-mode=Node,RBAC
–bind-address=0.0.0.0
–client-ca-file=/etc/kubernetes/pki/ca.crt
–enable-admission-plugins=NodeRestriction
–enable-bootstrap-token-auth=true
–etcd-cafile=/etc/ssl/etcd/ssl/ca.pem
–etcd-certfile=/etc/ssl/etcd/ssl/node-master.pem
–etcd-keyfile=/etc/ssl/etcd/ssl/node-master-key.pem
–etcd-servers=https://172.16.21.35:2379
–feature-gates=RotateKubeletServerCertificate=true
–kubelet-client-certificate=/etc/kubernetes/pki/apiserver-kubelet-client.crt
–kubelet-client-key=/etc/kubernetes/pki/apiserver-kubelet-client.key
–kubelet-preferred-address-types=InternalIP,ExternalIP,Hostname
–proxy-client-cert-file=/etc/kubernetes/pki/front-proxy-client.crt
–proxy-client-key-file=/etc/kubernetes/pki/front-proxy-client.key
–requestheader-allowed-names=front-proxy-client
–requestheader-client-ca-file=/etc/kubernetes/pki/front-proxy-ca.crt
–requestheader-extra-headers-prefix=X-Remote-Extra-
–requestheader-group-headers=X-Remote-Group
–requestheader-username-headers=X-Remote-User
–secure-port=6443
–service-account-issuer=https://kubernetes.default.svc.cluster.local
–service-account-key-file=/etc/kubernetes/pki/sa.pub
–service-account-signing-key-file=/etc/kubernetes/pki/sa.key
–service-cluster-ip-range=10.233.0.0/18
–tls-cert-file=/etc/kubernetes/pki/apiserver.crt
–tls-private-key-file=/etc/kubernetes/pki/apiserver.key
image: dockerhub.kubekey.local/kubesphereio/kube-apiserver:v1.26.12
imagePullPolicy: IfNotPresent
livenessProbe:
failureThreshold: 8
httpGet:
host: 172.16.21.35
path: /livez
port: 6443
scheme: HTTPS
initialDelaySeconds: 10
periodSeconds: 10
timeoutSeconds: 15
readinessProbe:
failureThreshold: 3
httpGet:
host: 172.16.21.35
path: /readyz
port: 6443
scheme: HTTPS
periodSeconds: 1
timeoutSeconds: 15
requests:
cpu: 250m
startupProbe:
failureThreshold: 24
httpGet:
host: 172.16.21.35
path: /livez
port: 6443
scheme: HTTPS
periodSeconds: 10
timeoutSeconds: 15
volumeMounts:
mountPath: /etc/ssl/certs
readOnly: true
mountPath: /etc/ca-certificates
readOnly: true
mountPath: /etc/pki
readOnly: true
mountPath: /etc/ssl/etcd/ssl
readOnly: true
mountPath: /etc/kubernetes/pki
readOnly: true
mountPath: /usr/local/share/ca-certificates
readOnly: true
mountPath: /usr/share/ca-certificates
readOnly: true
hostNetwork: true
priority: 2000001000
priorityClassName: system-node-critical
securityContext:
seccompProfile:
type: RuntimeDefault
volumes:
hostPath:
path: /etc/ssl/certs
type: DirectoryOrCreate
hostPath:
path: /etc/ca-certificates
hostPath:
path: /etc/pki
hostPath:
path: /etc/ssl/etcd/ssl
hostPath:
path: /etc/kubernetes/pki
hostPath:
path: /usr/local/share/ca-certificates
hostPath:
path: /usr/share/ca-certificates
status: {}
kube-apiserver 命令不存在 8080端口找不到
Dec 11 16:48:36 master kubelet[43735]: E1211 16:48:36.464582 43735 remote_image.go:171] “PullImage from image service failed” err="rpc error: code = Unknown desc = failed to pull and unpack image \“dockerhub.kubekey.local/kubesphereio/kube-scheduler:v1.26.12\”: failed to resolve reference \“dockerhub.kubekey.local/kubesphereio/kube-scheduler:v1.26.12\”: failed to do request: Head \“https://dockerhub.kubekey.local/v2/kubesphereio/kube-scheduler/manifests/v1.26.12\”: tls: failed to verify certificate: x509: certificate signed by unknown authority" image=“dockerhub.kubekey.local/kubesphereio/kube-scheduler:v1.26.12”
Dec 11 16:48:36 master kubelet[43735]: E1211 16:48:36.464615 43735 kuberuntime_image.go:53] “Failed to pull image” err="rpc error: code = Unknown desc = failed to pull and unpack image \“dockerhub.kubekey.local/kubesphereio/kube-scheduler:v1.26.12\”: failed to resolve reference \“dockerhub.kubekey.local/kubesphereio/kube-scheduler:v1.26.12\”: failed to do request: Head \“https://dockerhub.kubekey.local/v2/kubesphereio/kube-scheduler/manifests/v1.26.12\”: tls: failed to verify certificate: x509: certificate signed by unknown authority" image=“dockerhub.kubekey.local/kubesphereio/kube-scheduler:v1.26.12”
通过手工的方式 pull
docker pull dockerhub.kubekey.local/kubesphereio/kube-apiserver:v1.26.12
docker pull dockerhub.kubekey.local/kubesphereio/kube-scheduler:v1.26.12
然后报错变成
Dec 11 16:55:45 master kubelet[43735]: E1211 16:55:45.453268 43735 pod_workers.go:965] “Error syncing pod, skipping” err="failed to \“StartContainer\” for \“kube-apiserver\” with ImagePullBackOff: \"Back-off pulling image \\\“dockerhub.kubekey.local/kubesphereio/kube-apiserver:v1.26.12\\\”\"" pod=“kube-system/kube-apiserver-master” podUID=9eb830c8cce30bfcab1dc46488c4c23e
放弃离线安装, 换成在线安装
export KKZONE=cn
./kk create cluster –with-kubernetes v1.22.12 –with-kubesphere v3.4.1
果然比离线安装好多了, 至少 docKer镜像都创建了.
- 已编辑
Cauchy
Hi, 我做了一樣的動作將 /etc/containerd/config.toml 複製一份到離線環境節點中,delete cluster 後也重新安裝,仍舊是沒有拉到鏡像
h00283@coverity-ms:~/kubesphere$ sudo systemctl status containerd
● containerd.service - containerd container runtime
Loaded: loaded (/lib/systemd/system/containerd.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2025-02-12 09:01:18 CST; 12min ago
Docs: https://containerd.io
Main PID: 57855 (containerd)
Tasks: 20
Memory: 32.1M
CPU: 3.259s
CGroup: /system.slice/containerd.service
└─57855 /usr/bin/containerd
Feb 12 09:10:18 coverity-ms containerd[57855]: time="2025-02-12T09:10:18.030777307+08:00" level=info msg="PullImage \"kubesphere/kube-scheduler:v1.28.0\""
Feb 12 09:10:53 coverity-ms containerd[57855]: time="2025-02-12T09:10:53.048661264+08:00" level=error msg="PullImage \"kubesphere/kube-scheduler:v1.28.0\" failed" error="failed to pull >
Feb 12 09:10:53 coverity-ms containerd[57855]: time="2025-02-12T09:10:53.048737870+08:00" level=info msg="stop pulling image docker.io/kubesphere/kube-scheduler:v1.28.0: active requests>
Feb 12 09:10:53 coverity-ms containerd[57855]: time="2025-02-12T09:10:53.067791408+08:00" level=info msg="PullImage \"kubesphere/kube-scheduler:v1.28.0\""
Feb 12 09:11:47 coverity-ms containerd[57855]: time="2025-02-12T09:11:47.921987128+08:00" level=error msg="PullImage \"kubesphere/kube-scheduler:v1.28.0\" failed" error="failed to pull >
Feb 12 09:11:47 coverity-ms containerd[57855]: time="2025-02-12T09:11:47.922058874+08:00" level=info msg="stop pulling image docker.io/kubesphere/kube-scheduler:v1.28.0: active requests>
Feb 12 09:11:47 coverity-ms containerd[57855]: time="2025-02-12T09:11:47.959575620+08:00" level=info msg="PullImage \"kubesphere/kube-proxy:v1.28.0\""
Feb 12 09:12:42 coverity-ms containerd[57855]: time="2025-02-12T09:12:42.900990255+08:00" level=error msg="PullImage \"kubesphere/kube-proxy:v1.28.0\" failed" error="failed to pull and >
Feb 12 09:12:42 coverity-ms containerd[57855]: time="2025-02-12T09:12:42.901048488+08:00" level=info msg="stop pulling image docker.io/kubesphere/kube-proxy:v1.28.0: active requests=0, >
Feb 12 09:12:42 coverity-ms containerd[57855]: time="2025-02-12T09:12:42.920106926+08:00" level=info msg="PullImage \"kubesphere/kube-proxy:v1.28.0\""
lines 1-21/21 (END)
Active: active (running) since Wed 2025-02-12 09:01:18 CST; 24min ago
Tasks: 20
Memory: 28.1M
CPU: 6.470s
Feb 12 09:25:08 coverity-ms containerd[57855]: time="2025-02-12T09:25:08.007196587+08:00" level=error msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-apiserver-coverity-ms,Uid:9c86>
Feb 12 09:25:08 coverity-ms containerd[57855]: time="2025-02-12T09:25:08.007258612+08:00" level=info msg="stop pulling image registry.k8s.io/pause:3.8: active requests=0, bytes read=0"
Feb 12 09:25:14 coverity-ms containerd[57855]: time="2025-02-12T09:25:14.006521370+08:00" level=info msg="trying next host" error="failed to do request: Head \"https://registry.k8s.io/v>
Feb 12 09:25:14 coverity-ms containerd[57855]: time="2025-02-12T09:25:14.006963140+08:00" level=error msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-controller-manager-coverity-ms>
Feb 12 09:25:14 coverity-ms containerd[57855]: time="2025-02-12T09:25:14.007017828+08:00" level=info msg="stop pulling image registry.k8s.io/pause:3.8: active requests=0, bytes read=0"
Feb 12 09:25:19 coverity-ms containerd[57855]: time="2025-02-12T09:25:19.006177756+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-apiserver-coverity-ms,Uid:9c86a>
Feb 12 09:25:22 coverity-ms containerd[57855]: time="2025-02-12T09:25:22.006859372+08:00" level=info msg="trying next host" error="failed to do request: Head \"https://registry.k8s.io/v>
Feb 12 09:25:22 coverity-ms containerd[57855]: time="2025-02-12T09:25:22.007282985+08:00" level=error msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-scheduler-coverity-ms,Uid:b68b>
Feb 12 09:25:22 coverity-ms containerd[57855]: time="2025-02-12T09:25:22.007336669+08:00" level=info msg="stop pulling image registry.k8s.io/pause:3.8: active requests=0, bytes read=0"
Feb 12 09:25:25 coverity-ms containerd[57855]: time="2025-02-12T09:25:25.006213130+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-controller-manager-coverity-ms,>
h00283@coverity-ms:~/kubesphere$ sudo journalctl -xeu containerd
Feb 12 09:23:50 coverity-ms containerd[57855]: time="2025-02-12T09:23:50.007470945+08:00" level=error msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-scheduler-coverity-ms,Uid:b68b>
Feb 12 09:23:50 coverity-ms containerd[57855]: time="2025-02-12T09:23:50.007543865+08:00" level=info msg="stop pulling image registry.k8s.io/pause:3.8: active requests=0, bytes read=0"
Feb 12 09:23:57 coverity-ms containerd[57855]: time="2025-02-12T09:23:57.005215126+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-apiserver-coverity-ms,Uid:9c86a>
Feb 12 09:24:02 coverity-ms containerd[57855]: time="2025-02-12T09:24:02.005641258+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-controller-manager-coverity-ms,>
Feb 12 09:24:05 coverity-ms containerd[57855]: time="2025-02-12T09:24:05.005768903+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-scheduler-coverity-ms,Uid:b68b9>
Feb 12 09:24:15 coverity-ms containerd[57855]: time="2025-02-12T09:24:15.014632688+08:00" level=info msg="trying next host" error="failed to do request: Head \"https://registry.k8s.io/v>
Feb 12 09:24:15 coverity-ms containerd[57855]: time="2025-02-12T09:24:15.015099837+08:00" level=error msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-scheduler-coverity-ms,Uid:b68b>
Feb 12 09:24:15 coverity-ms containerd[57855]: time="2025-02-12T09:24:15.015168391+08:00" level=info msg="stop pulling image registry.k8s.io/pause:3.8: active requests=0, bytes read=0"
Feb 12 09:24:27 coverity-ms containerd[57855]: time="2025-02-12T09:24:27.005963308+08:00" level=info msg="trying next host" error="failed to do request: Head \"https://registry.k8s.io/v>
Feb 12 09:24:27 coverity-ms containerd[57855]: time="2025-02-12T09:24:27.006362809+08:00" level=error msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-apiserver-coverity-ms,Uid:9c86>
Feb 12 09:24:27 coverity-ms containerd[57855]: time="2025-02-12T09:24:27.006405634+08:00" level=info msg="stop pulling image registry.k8s.io/pause:3.8: active requests=0, bytes read=0"
Feb 12 09:24:28 coverity-ms containerd[57855]: time="2025-02-12T09:24:28.005946694+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-scheduler-coverity-ms,Uid:b68b9>
Feb 12 09:24:32 coverity-ms containerd[57855]: time="2025-02-12T09:24:32.007109598+08:00" level=info msg="trying next host" error="failed to do request: Head \"https://registry.k8s.io/v>
Feb 12 09:24:32 coverity-ms containerd[57855]: time="2025-02-12T09:24:32.007513724+08:00" level=error msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-controller-manager-coverity-ms>
Feb 12 09:24:32 coverity-ms containerd[57855]: time="2025-02-12T09:24:32.007574457+08:00" level=info msg="stop pulling image registry.k8s.io/pause:3.8: active requests=0, bytes read=0"
Feb 12 09:24:38 coverity-ms containerd[57855]: time="2025-02-12T09:24:38.006011082+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-apiserver-coverity-ms,Uid:9c86a>
Feb 12 09:24:38 coverity-ms containerd[57855]: time="2025-02-12T09:24:38.011167166+08:00" level=info msg="trying next host" error="failed to do request: Head \"https://registry.k8s.io/v>
Feb 12 09:24:38 coverity-ms containerd[57855]: time="2025-02-12T09:24:38.011456251+08:00" level=error msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-scheduler-coverity-ms,Uid:b68b>
Feb 12 09:24:38 coverity-ms containerd[57855]: time="2025-02-12T09:24:38.011516448+08:00" level=info msg="stop pulling image registry.k8s.io/pause:3.8: active requests=0, bytes read=0"
Feb 12 09:24:44 coverity-ms containerd[57855]: time="2025-02-12T09:24:44.005319589+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-controller-manager-coverity-ms,>
Feb 12 09:24:52 coverity-ms containerd[57855]: time="2025-02-12T09:24:52.005626755+08:00" level=info msg="RunPodSandbox for &PodSandboxMetadata{Name:kube-scheduler-coverity-ms,Uid:b68b9>
Feb 12 09:25:08 coverity-ms containerd[57855]: time="2025-02-12T09:25:08.006747234+08:00" level=info msg="trying next host" error="failed to do request: Head \"https://registry.k8s.io/v>
