我的master node 在 192.168.1.3 上
我現在想要讓他在這台上用 https://192.168.1.3:30880 訪問
請問該怎麼去做?
請問 v4.1.2 KubeSphere console 如何使用 https 訪問
@calvinyu
我這麼做了
# 添加 Jetstack Helm 仓库
helm repo add jetstack https://charts.jetstack.io
# 更新本地 Helm Chart 仓库缓存
helm repo update
# 安装 cert-manager Helm Chart
helm install cert-manager jetstack/cert-manager -n cert-manager --create-namespace --set prometheus.enabled=false
#使用Let’s Encrypt启用网关 SSL 配置
ets-pst-001@ets-pst-001:~/kubesphere$ helm upgrade --install -n kubesphere-system --create-namespace ks-core https://charts.kubesphere.io/main/ks-core-1.1.3.tgz \
> --set portal.hostname=192.168.1.3 \
> --set ingress.enabled=true \
> --set ingress.tls.source=letsEncrypt \
> --set letsEncrypt.email=tzuyu1109@gmail.com \
> --set portal.https.port=443
Error: UPGRADE FAILED: failed to create resource: Ingress.extensions "ks-console" is invalid: spec.rules[0].host: Invalid value: "192.168.1.3": must be a DNS name, not an IP address
該如何解決?
ets-pst-001@ets-pst-001:~/kubesphere$ helm upgrade --install -n kubesphere-system --create-namespace ks-core https://charts.kubesphere.io/main/ks-core-1.1.3.tgz --set portal.hostname=ks-console.kubesphere-system.svc --set ingress.enabled=true --set ingress.tls.source=letsEncrypt --set letsEncrypt.email=tzuyu1109@gmail.com --set portal.https.port=443
Release "ks-core" has been upgraded. Happy Helming!
LAST DEPLOYED: Fri Feb 14 14:33:00 2025
NAMESPACE: kubesphere-system
STATUS: deployed
REVISION: 3
TEST SUITE: None
NOTES:
Thank you for choosing KubeSphere Helm Chart.
Please be patient and wait for several seconds for the KubeSphere deployment to complete.
1. Wait for Deployment Completion
Confirm that all KubeSphere components are running by executing the following command:
kubectl get pods -n kubesphere-system
2. Access the KubeSphere Console
Once the deployment is complete, you can access the KubeSphere console using the following URL:
http://192.168.1.3:30880
3. Login to KubeSphere Console
Use the following credentials to log in:
Account: admin
Password: P@88w0rd
NOTE: It is highly recommended to change the default password immediately after the first login.
For additional information and details, please visit https://kubesphere.io.
一樣不行用 https://192.168.1.3:30880 訪問
hongmingK零SK壹S
使用 ingress + TLS,你需要通过域名 + ingress controller 的 https 端口访问
有沒有ingress教學? 我cert manager 那些都搞成功了
hongming 做出來了但我的都會導像nginx
ets-pst-001@ets-pst-001:~/kubesphere$ kubectl -n kube-system get svc
coredns ClusterIP 10.233.0.3 <none> 53/UDP,53/TCP,9153/TCP 3d5h
kubelet ClusterIP None <none> 10250/TCP,10255/TCP,4194/TCP 54m
nginx-ingress-ingress-nginx-controller NodePort 10.233.19.212 <none> 80:31652/TCP,443:30443/TCP 35m
nginx-ingress-ingress-nginx-controller-admission ClusterIP 10.233.1.84 <none> 443/TCP 35m
whizard-monitoring-agent-k-coredns ClusterIP None <none> 9153/TCP 54m
whizard-monitoring-agent-k-kube-controller-manager ClusterIP None <none> 10257/TCP 54m
whizard-monitoring-agent-k-kube-scheduler ClusterIP None <none> 10259/TCP 54m
請問您是怎麼做到的
我剛剛是
- helm install ingress
- helm install cert-manager 用 letsEncrypt
接著就開始亂掉了
有人可以協助嗎?卡在這個地方一直沒辦法接續
hongmingK零SK壹S
- 已编辑
@cici 我前面回复中涉及的截图就已经包含所有的步骤了
获取到 ingress controller 的访问地址
把域名解析到 node ip,通过 nginx svc 443 关联的 node port 访问,比如 192.168.1.3.nip.io:30443
ks-core 配置启用 ingress,配置好域名和端口(ingress controller 的访问入口)
--set portal.hostname=192.168.1.3.nip.io \
--set portal.https.port=30443
重点是--set portal.hostname=192.168.1.3.nip.io
和 portal.https.port=30443
这俩配置
最后通过 https://192.168.1.3.nip.io:30443 来访问
- 已编辑
hongming
Hi,
我重新做了一次,現在卡在 ingress 要怎麼加上 tls?
我的作法:
##安装 ingress-nginx controller
helm upgrade --install ingress-nginx ingress-nginx \
--repo https://kubernetes.github.io/ingress-nginx \
--namespace ingress-nginx --create-namespace
##安装 cert-manager
helm repo update
kubectl create namespace cert-manager
helm install cert-manager jetstack/cert-manager -n cert-manager --create-namespace --set prometheus.enabled=false --set crds.enabled=true
##創建 ClusterIssuer
apiVersion: cert-manager.io/v1
kind: ClusterIssuer
acme:
email: abc@gmail.com
server: https://acme-v02.api.letsencrypt.org/directory
privateKeySecretRef:
solvers:
- http01:
ingress:
class: nginx
kubectl apply -f cluster-issuer.yaml
coredns ClusterIP 10.233.0.3 <none> 53/UDP,53/TCP,9153/TCP 111m
ets-pst-001@ets-pst-001:~/kubesphere$ kubectl -n kubesphere-system get svc
extensions-museum ClusterIP 10.233.21.70 <none> 443/TCP 52m
ks-apiserver ClusterIP 10.233.44.157 <none> 80/TCP 52m
ks-console NodePort 10.233.45.63 <none> 80:30880/TCP 52m
ks-controller-manager ClusterIP 10.233.48.223 <none> 443/TCP 52m
ets-pst-001@ets-pst-001:~/kubesphere$ kubectl -n ingress-nginx get svc
ingress-nginx-controller NodePort 10.233.46.50 <none> 80:30301/TCP,443:30441/TCP 96m
ingress-nginx-controller-admission ClusterIP 10.233.27.26 <none> 443/TCP 96m
kind: Ingress
apiVersion: networking.k8s.io/v1
namespace: kubesphere-system
creationTimestamp: '2025-02-17T06:38:52Z'
annotations:
kubectl.kubernetes.io/last-applied-configuration: >
{"apiVersion":"networking.k8s.io/v1","kind":"Ingress","metadata":{"annotations":{"nginx.ingress.kubernetes.io/ssl-redirect":"true"},"name":"ks-console-ingress","namespace":"kubesphere-system"},"spec":{"ingressClassName":"nginx","rules":[{"host":"ks.local","http":{"paths":[{"backend":{"service":{"name":"ks-console","port":{"number":30880}}},"path":"/","pathType":"Prefix"}]}}],"tls":[{"hosts":["ks.local"],"secretName":"kubesphere-tls"}]}}
nginx.ingress.kubernetes.io/ssl-redirect: 'true'
defaultBackend:
service:
port:
number: 80
ingressClassName: nginx
rules:
- host: ks.local
http:
paths:
- backend:
service:
port:
number: 80
path: /
pathType: Prefix
tls:
- hosts:
- ks.local
secretName: kubesphere-tls
status:
loadBalancer:
ingress:
- ip: 10.233.46.50
請問我下一步該怎麼辦
訪問
