例如:虚拟机 Ubuntu22.04,16C/64G
Client Version: version.Info{Major:“1”, Minor:“23”, GitVersion:“v1.23.17”, GitCommit:“953be8927218ec8067e1af2641e540238ffd7576”, GitTreeState:“clean”, BuildDate:“2023-02-22T13:34:27Z”, GoVersion:“go1.19.6”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“23”, GitVersion:“v1.23.17”, GitCommit:“953be8927218ec8067e1af2641e540238ffd7576”, GitTreeState:“clean”, BuildDate:“2023-02-22T13:27:46Z”, GoVersion:“go1.19.6”, Compiler:“gc”, Platform:“linux/amd64”}
v3.4.1
Running on rent-projectfcxdv-rent-admin-6-fw0ts-01f0t-s3272 in /home/jenkins/agent/workspace/rent-projectfcxdv/rent-admin
[Pipeline] {
[Pipeline] container
[Pipeline] {
[Pipeline] withEnv
[Pipeline] {
[Pipeline] stage
[Pipeline] { (代码拉取)
[Pipeline] script
[Pipeline] {
[Pipeline] echo
Build with environment :
Git : http://****:12306/frontend/rent-front
Branch : develop
Command : npm run build:test
[Pipeline] }
[Pipeline] // script
[Pipeline] git
The recommended git tool is: NONE
using credential gitlab-id
Warning: JENKINS-30600: special launcher org.csanchez.jenkins.plugins.kubernetes.pipeline.ContainerExecDecorator$1@33a3fd59; decorates RemoteLauncher[hudson.remoting.Channel@3b8746dd:JNLP4-connect connection from 10.233.117.170/10.233.117.170:40324] will be ignored (a typical symptom is the Git executable not being run inside a designated container)
Cloning the remote Git repository
Cloning repository http://****:12306/frontend/rent-front
git init /home/jenkins/agent/workspace/rent-projectfcxdv/rent-admin # timeout=10
Fetching upstream changes from http://****:12306/frontend/rent-front
git –version # timeout=10
git –version # ‘git version 2.30.2’
using GIT_ASKPASS to set credentials
git fetch –tags –force –progress – http://****:12306/frontend/rent-front +refs/heads/*:refs/remotes/origin/* # timeout=10
Avoid second fetch
Checking out Revision 91c2aa7006a303dfbe1819b47e75a5975d87739d (refs/remotes/origin/develop)
git config remote.origin.url http://****:12306/frontend/rent-front # timeout=10
git config –add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
git rev-parse refs/remotes/origin/develop^{commit} # timeout=10
git config core.sparsecheckout # timeout=10
git checkout -f 91c2aa7006a303dfbe1819b47e75a5975d87739d # timeout=10
git branch -a -v –no-abbrev # timeout=10
git checkout -b develop 91c2aa7006a303dfbe1819b47e75a5975d87739d # timeout=10
Commit message: “添加test”
git rev-list –no-walk 91c2aa7006a303dfbe1819b47e75a5975d87739d # timeout=10
[Pipeline] sh
[Pipeline] }
[Pipeline] // stage
[Pipeline] stage
[Pipeline] { (代码编译)
Stage “代码编译” skipped due to earlier failure(s)
[Pipeline] }
[Pipeline] // stage
[Pipeline] stage
[Pipeline] { (构建镜像)
Stage “构建镜像” skipped due to earlier failure(s)
[Pipeline] }
[Pipeline] // stage
[Pipeline] stage
[Pipeline] { (部署)
Stage “部署” skipped due to earlier failure(s)
[Pipeline] }
[Pipeline] // stage
[Pipeline] }
[Pipeline] // withEnv
[Pipeline] }
[Pipeline] // container
[Pipeline] }
[Pipeline] // node
[Pipeline] }
[Pipeline] // podTemplate
[Pipeline] End of Pipeline
io.fabric8.kubernetes.client.KubernetesClientException: not ready after 5000 MILLISECONDS
at io.fabric8.kubernetes.client.utils.Utils.waitUntilReadyOrFail(Utils.java:176)
at io.fabric8.kubernetes.client.dsl.internal.core.v1.PodOperationsImpl.exec(PodOperationsImpl.java:322)
at io.fabric8.kubernetes.client.dsl.internal.core.v1.PodOperationsImpl.exec(PodOperationsImpl.java:84)
at org.csanchez.jenkins.plugins.kubernetes.pipeline.ContainerExecDecorator$1.doLaunch(ContainerExecDecorator.java:427)
at org.csanchez.jenkins.plugins.kubernetes.pipeline.ContainerExecDecorator$1.launch(ContainerExecDecorator.java:344)
at hudson.Launcher$ProcStarter.start(Launcher.java:507)
at org.jenkinsci.plugins.durabletask.BourneShellScript.launchWithCookie(BourneShellScript.java:176)
at org.jenkinsci.plugins.durabletask.FileMonitoringTask.launch(FileMonitoringTask.java:132)
at org.jenkinsci.plugins.workflow.steps.durable_task.DurableTaskStep$Execution.start(DurableTaskStep.java:320)
at org.jenkinsci.plugins.workflow.cps.DSL.invokeStep(DSL.java:319)
at org.jenkinsci.plugins.workflow.cps.DSL.invokeMethod(DSL.java:193)
at org.jenkinsci.plugins.workflow.cps.CpsScript.invokeMethod(CpsScript.java:122)
at jdk.internal.reflect.GeneratedMethodAccessor7651.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:93)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:325)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1213)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1022)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:42)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:48)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:113)
at org.kohsuke.groovy.sandbox.impl.Checker$1.call(Checker.java:163)
at org.kohsuke.groovy.sandbox.GroovyInterceptor.onMethodCall(GroovyInterceptor.java:23)
at org.jenkinsci.plugins.scriptsecurity.sandbox.groovy.SandboxInterceptor.onMethodCall(SandboxInterceptor.java:158)
at org.kohsuke.groovy.sandbox.impl.Checker$1.call(Checker.java:161)
at org.kohsuke.groovy.sandbox.impl.Checker.checkedCall(Checker.java:165)
at org.kohsuke.groovy.sandbox.impl.Checker.checkedCall(Checker.java:135)
at com.cloudbees.groovy.cps.sandbox.SandboxInvoker.methodCall(SandboxInvoker.java:17)
at WorkflowScript.run(WorkflowScript:61)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.delegateAndExecute(ModelInterpreter.groovy:137)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.executeSingleStage(ModelInterpreter.groovy:666)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.catchRequiredContextForNode(ModelInterpreter.groovy:395)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.catchRequiredContextForNode(ModelInterpreter.groovy:393)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.executeSingleStage(ModelInterpreter.groovy:665)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.evaluateStage(ModelInterpreter.groovy:288)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.toolsBlock(ModelInterpreter.groovy:544)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.toolsBlock(ModelInterpreter.groovy:543)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.evaluateStage(ModelInterpreter.groovy:276)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.withEnvBlock(ModelInterpreter.groovy:443)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.withEnvBlock(ModelInterpreter.groovy:442)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.evaluateStage(ModelInterpreter.groovy:275)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.withCredentialsBlock(ModelInterpreter.groovy:481)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.withCredentialsBlock(ModelInterpreter.groovy:480)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.evaluateStage(ModelInterpreter.groovy:274)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.inDeclarativeAgent(ModelInterpreter.groovy:595)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.inDeclarativeAgent(ModelInterpreter.groovy:594)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.evaluateStage(ModelInterpreter.groovy:272)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.stageInput(ModelInterpreter.groovy:356)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.stageInput(ModelInterpreter.groovy:355)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.evaluateStage(ModelInterpreter.groovy:261)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.inWrappers(ModelInterpreter.groovy:618)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.inWrappers(ModelInterpreter.groovy:617)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.evaluateStage(ModelInterpreter.groovy:259)
at org.jenkinsci.plugins.pipeline.modeldefinition.ModelInterpreter.evaluateStage(ModelInterpreter.groovy:254)
at cps.transform(Native Method)
at com.cloudbees.groovy.cps.impl.ContinuationGroup.methodCall(ContinuationGroup.java:86)
at com.cloudbees.groovy.cps.impl.FunctionCallBlock$ContinuationImpl.dispatchOrArg(FunctionCallBlock.java:113)
at com.cloudbees.groovy.cps.impl.FunctionCallBlock$ContinuationImpl.fixArg(FunctionCallBlock.java:83)
at jdk.internal.reflect.GeneratedMethodAccessor368.invoke(Unknown Source)
at com.cloudbees.groovy.cps.impl.ContinuationPtr$ContinuationImpl.receive(ContinuationPtr.java:72)
at com.cloudbees.groovy.cps.impl.ConstantBlock.eval(ConstantBlock.java:21)
at com.cloudbees.groovy.cps.Next.step(Next.java:83)
at com.cloudbees.groovy.cps.Continuable$1.call(Continuable.java:174)
at com.cloudbees.groovy.cps.Continuable$1.call(Continuable.java:163)
at org.codehaus.groovy.runtime.GroovyCategorySupport$ThreadCategoryInfo.use(GroovyCategorySupport.java:129)
at org.codehaus.groovy.runtime.GroovyCategorySupport.use(GroovyCategorySupport.java:268)
at com.cloudbees.groovy.cps.Continuable.run0(Continuable.java:163)
at org.jenkinsci.plugins.workflow.cps.SandboxContinuable.access$001(SandboxContinuable.java:18)
at org.jenkinsci.plugins.workflow.cps.SandboxContinuable.run0(SandboxContinuable.java:51)
at org.jenkinsci.plugins.workflow.cps.CpsThread.runNextChunk(CpsThread.java:185)
at org.jenkinsci.plugins.workflow.cps.CpsThreadGroup.run(CpsThreadGroup.java:402)
at org.jenkinsci.plugins.workflow.cps.CpsThreadGroup.access$400(CpsThreadGroup.java:96)
at org.jenkinsci.plugins.workflow.cps.CpsThreadGroup$2.call(CpsThreadGroup.java:314)
at org.jenkinsci.plugins.workflow.cps.CpsThreadGroup$2.call(CpsThreadGroup.java:278)
at org.jenkinsci.plugins.workflow.cps.CpsVmExecutorService$2.call(CpsVmExecutorService.java:67)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at hudson.remoting.SingleLaneExecutorService$1.run(SingleLaneExecutorService.java:139)
at jenkins.util.ContextResettingExecutorService$1.run(ContextResettingExecutorService.java:28)
at jenkins.security.ImpersonatingExecutorService$1.run(ImpersonatingExecutorService.java:68)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Finished: FAILURE
有一个master 和 3个woker , 调度到worker03 的时候就会出这个问题。
