在应用商店部署程序的时候显示“Internal Server Error
rpc error: code = PermissionDenied desc = access denied for resource [runtime-JYlvnX001Oox]: rpc error: code = PermissionDenied desc = Runtime [runtime-JYlvnX001Oox] not found: <nil>”
查看pod日志,异常信息如下:
2020-10-20 02:16:28.48506 -INFO- Request received [CreateCluster] [&{UserId:zpf OwnerPath::zpf AccessPath:}] [{“app_id”:“app-RGEJmZQ0mDNn”,“version_id”:“appv-vKy5ywRjgyOj”,“runtime_id”:“runtime-JYlvnX001Oox”,“conf”:“global:\n redis: {}\nimage:\n registry: docker.io\n repository: bitnami/redis\n tag: 5.0.7-debian-10-r0\n pullPolicy: IfNotPresent\ncluster:\n enabled: true\n slaveCount: 2\nsentinel:\n enabled: false\n usePassword: true\n image:\n registry: docker.io\n repository: bitnami/redis-sentinel\n tag: 5.0.7-debian-10-r0\n pullPolicy: IfNotPresent\n masterSet: mymaster\n initialCheckTimeout: 5\n quorum: 2\n downAfterMilliseconds: 60000\n failoverTimeout: 18000\n parallelSyncs: 1\n port: 26379\n configmap: null\n staticID: false\n livenessProbe:\n enabled: true\n initialDelaySeconds: 5\n periodSeconds: 5\n timeoutSeconds: 5\n successThreshold: 1\n failureThreshold: 5\n readinessProbe:\n enabled: true\n initialDelaySeconds: 5\n periodSeconds: 5\n timeoutSeconds: 1\n successThreshold: 1\n failureThreshold: 5\n service:\n type: ClusterIP\n sentinelPort: 26379\n redisPort: 6379\n annotations: {}\n labels: {}\n loadBalancerIP: null\nclusterDomain: cluster.local\nnetworkPolicy:\n enabled: false\n ingressNSMatchLabels: {}\n ingressNSPodMatchLabels: {}\nserviceAccount:\n create: false\n name: null\nrbac:\n create: false\n role:\n rules: []\nsecurityContext:\n enabled: true\n fsGroup: 1001\n runAsUser: 1001\nusePassword: true\npassword: '‘\nusePasswordFile: false\npersistence: {}\nredisPort: 6379\nmaster:\n command: /run.sh\n configmap: null\n extraFlags: []\n disableCommands:\n - FLUSHDB\n - FLUSHALL\n podLabels: {}\n podAnnotations: {}\n livenessProbe:\n enabled: true\n initialDelaySeconds: 5\n periodSeconds: 5\n timeoutSeconds: 5\n successThreshold: 1\n failureThreshold: 5\n readinessProbe:\n enabled: true\n initialDelaySeconds: 5\n periodSeconds: 5\n timeoutSeconds: 1\n successThreshold: 1\n failureThreshold: 5\n affinity: {}\n service:\n type: ClusterIP\n port: 6379\n annotations: {}\n labels: {}\n loadBalancerIP: null\n persistence:\n enabled: true\n path: /data\n subPath: ’‘\n accessModes:\n - ReadWriteOnce\n size: 8Gi\n matchLabels: {}\n matchExpressions: {}\n statefulset:\n updateStrategy: RollingUpdate\nslave:\n service:\n type: ClusterIP\n port: 6379\n annotations: {}\n labels: {}\n loadBalancerIP: null\n port: 6379\n command: /run.sh\n configmap: null\n extraFlags: []\n disableCommands:\n - FLUSHDB\n - FLUSHALL\n affinity: {}\n livenessProbe:\n enabled: true\n initialDelaySeconds: 30\n periodSeconds: 10\n timeoutSeconds: 5\n successThreshold: 1\n failureThreshold: 5\n readinessProbe:\n enabled: true\n initialDelaySeconds: 5\n periodSeconds: 10\n timeoutSeconds: 10\n successThreshold: 1\n failureThreshold: 5\n podLabels: {}\n podAnnotations: {}\n persistence:\n enabled: true\n path: /data\n subPath: ’'\n accessModes:\n - ReadWriteOnce\n size: 8Gi\n matchLabels: {}\n matchExpressions: {}\n statefulset:\n updateStrategy: RollingUpdate\nmetrics:\n enabled: false\n image:\n registry: docker.io\n repository: bitnami/redis-exporter\n tag: 1.3.5-debian-10-r0\n pullPolicy: IfNotPresent\n podAnnotations:\n prometheus.io/scrape: ‘true’\n prometheus.io/port: ‘9121’\n serviceMonitor:\n enabled: false\n selector:\n prometheus: kube-prometheus\n prometheusRule:\n enabled: false\n additionalLabels: {}\n namespace: '‘\n rules: []\n service:\n type: ClusterIP\n annotations: {}\n labels: {}\nvolumePermissions:\n enabled: false\n image:\n registry: docker.io\n repository: bitnami/minideb\n tag: buster\n pullPolicy: Always\n resources: {}\nconfigmap: |-\n # Enable AOF https://redis.io/topics/persistence#append-only-file\n appendonly yes\n # Disable RDB persistence, AOF persistence already enabled.\n save \”\“\nsysctlImage:\n enabled: false\n command: []\n registry: docker.io\n repository: bitnami/minideb\n tag: buster\n pullPolicy: Always\n mountHostSys: false\n resources: {}\npodSecurityPolicy:\n create: false\nName: redis-55pca0\nDescription: ’'\n”}] (grpc_server.go:180)
2020-10-20 02:16:28.4854 -INFO- Request received [DescribeRuntimeDetails] [&{UserId:zpf OwnerPath::zpf AccessPath:}] [{“runtime_id”:[“runtime-JYlvnX001Oox”]}] (grpc_server.go:180)
2020-10-20 02:16:28.48899 -DEBUG- dbr.select spend 3.47ms: map[sql:SELECT runtime_id, name, description, provider, zone, runtime_credential_id, owner, owner_path, status, debug, create_time, status_time FROM runtime WHERE ((owner_path
LIKE ‘%’) OR (owner
= ‘zpf’)) AND ((runtime_id
IN (‘runtime-JYlvnX001Oox’))) ORDER BY create_time DESC LIMIT 20 OFFSET 0] (event.go:48)
2020-10-20 02:16:28.48934 -DEBUG- dbr.select spend 0.29ms: map[sql:SELECT COUNT(*) FROM runtime WHERE ((owner_path
LIKE ‘%’) OR (owner
IN (‘runtime-JYlvnX001Oox’)))] (event.go:48)
2020-10-20 02:16:28.48937 -INFO- Handled request [DescribeRuntimeDetails] [&{UserId:zpf OwnerPath::zpf AccessPath:}] exec_time is [3.93803ms] (grpc_server.go:188)
2020-10-20 02:16:28.4895 -ERROR- Runtime [runtime-JYlvnX001Oox] not found (runtime.go:52)
2020-10-20 02:16:28.48956 -ERROR- err: rpc error: code = PermissionDenied desc = Runtime [runtime-JYlvnX001Oox] not found: , errMsg: access denied for resource [runtime-JYlvnX001Oox]: rpc error: code = PermissionDenied desc = Runtime [runtime-JYlvnX001Oox] not found: (handler.go:656)
2020-10-20 02:16:28.48961 -INFO- Handled request [CreateCluster] [&{UserId:zpf OwnerPath::zpf AccessPath:}] exec_time is [4.50443ms] (grpc_server.go:188)
2020-10-20 02:16:28.48962 -DEBUG- Response is error: PermissionDenied, access denied for resource [runtime-JYlvnX001Oox]: rpc error: code = PermissionDenied desc = Runtime [runtime-JYlvnX001Oox] not found: (grpc_server.go:191)
这个应该如何解决?
