虚拟机 KylinOS v10 sp3 v2207
v1.29.15
containerd v1.7.13
v3.4.1,离线安装,全套安装
我现在遇到的问题是,在一套干净的虚拟机环境(3个master节点,3个worker节点)使用kk 3.1.7版本部署ks v3.4.1和k8s v1.29.15,第一次部署时很顺利;然后我kk delete cluster之后,并做了简单的清理工作,还是使用同一个config.yaml和artifact离线镜像包再次kk create cluster时,就停在了Please wait for the installation complete…..
之前遇到的问题都是calico-code初始化失败,现在的情况是calica-code显示未持续RUNNING
# kubectl get pods -n kube-system -o wide | grep calico-node
calico-node-449rq        1/1     Running            0          101s   192.168.110.60   master2   <none>           <none>
calico-node-5s45q        1/1     Running            0          101s   192.168.110.42   worker2   <none>           <none>
calico-node-bg9h9       1/1     Running            0          101s   192.168.110.59   master1   <none>           <none>
calico-node-n5lz9        1/1     Running            0          101s   192.168.110.61   master3   <none>           <none>
calico-node-swvzp       1/1     Running            0          101s   192.168.110.41   worker1   <none>           <none>
calico-node-v4bvw       1/1     Running            0          101s   192.168.110.43   worker3   <none>          <none>
查看其中一个calico-pod的describe,显示:
# kubectl describe pod calico-node-449rq  -n kube-system
  Warning  Unhealthy  4m31s  kubelet            Readiness probe failed: calico/node is not ready: BIRD is not ready: Error querying BIRD: unable to connect to BIRDv4 socket: dial unix /var/run/bird/bird.ctl: connect: no such file or directory
  Warning  Unhealthy  4m30s  kubelet            Readiness probe failed: calico/node is not ready: BIRD is not ready: Error querying BIRD: unable to connect to BIRDv4 socket: dial unix /var/run/calico/bird.ctl: connect: connection refused
然后查看这个pod的日志:
#  kubectl logs calico-node-449rq -n kube-system
bird: Unable to open configuration file /etc/calico/confd/config/bird6.cfg: No such file or directory
bird: Unable to open configuration file /etc/calico/confd/config/bird.cfg: No such file or directory
所以,我就不知道是不是kk delete cluster之后,系统还是没有清理干净。
