物理机 Ubuntu24.04.4,4C/8G
Client Version: v1.31.2
Kustomize Version: v5.4.2
Server Version: v1.31.2
Version:  0.1.0
RuntimeName:  containerd
RuntimeVersion:  v1.7.13
RuntimeApiVersion:  v1
例如:v4.1.2。在线安装。使用kk安装。
主集群在本地没有公网IP,成员集群在阿里云,API server 可以通过公网访问。通过“直接连接”方式连接,在集群中已指定镜像仓库地址
global:
  imageRegistry: swr.cn-southwest-2.myhuaweicloud.com/ks
ks-controller-manager 容器日志
2025-05-04T21:34:09.706508705+08:00 I0504 21:34:09.706141       1 cluster_controller.go:384] Starting installing KS Core for the cluster 1111
2025-05-04T21:34:10.082536983+08:00 I0504 21:34:10.081982       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:10.312182079+08:00 I0504 21:34:10.311698       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:10.486285837+08:00 I0504 21:34:10.485933       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:10.676050983+08:00 I0504 21:34:10.671800       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:10.841588724+08:00 I0504 21:34:10.841068       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:11.029671504+08:00 I0504 21:34:11.029029       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:11.224358342+08:00 I0504 21:34:11.223916       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:11.417864054+08:00 I0504 21:34:11.417599       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:11.605155825+08:00 I0504 21:34:11.604814       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:11.782142141+08:00 I0504 21:34:11.781783       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:11.982025094+08:00 I0504 21:34:11.981745       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:12.163687506+08:00 I0504 21:34:12.163382       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:12.350625474+08:00 I0504 21:34:12.350225       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:12.533043051+08:00 I0504 21:34:12.532763       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:12.711355889+08:00 I0504 21:34:12.711067       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:12.875685299+08:00 I0504 21:34:12.875276       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:13.035673854+08:00 I0504 21:34:13.035342       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:13.212481222+08:00 I0504 21:34:13.212059       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:13.404668214+08:00 I0504 21:34:13.404239       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:13.591831919+08:00 I0504 21:34:13.591480       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:13.768450259+08:00 I0504 21:34:13.768189       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:13.942540012+08:00 I0504 21:34:13.942138       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:14.133437924+08:00 I0504 21:34:14.133082       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:14.315134775+08:00 I0504 21:34:14.314520       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:14.492842943+08:00 I0504 21:34:14.492528       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:14.667689025+08:00 I0504 21:34:14.667293       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:14.843399066+08:00 I0504 21:34:14.842965       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:15.020593070+08:00 I0504 21:34:15.020170       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:15.220804494+08:00 I0504 21:34:15.220431       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:15.402832541+08:00 I0504 21:34:15.402377       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:15.589851486+08:00 I0504 21:34:15.589479       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:15.783492419+08:00 I0504 21:34:15.782953       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:15.954642095+08:00 I0504 21:34:15.954233       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:16.169550998+08:00 I0504 21:34:16.169139       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:16.353994375+08:00 I0504 21:34:16.353594       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:16.545854502+08:00 I0504 21:34:16.545481       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:16.735949309+08:00 I0504 21:34:16.735652       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:16.925625089+08:00 I0504 21:34:16.925365       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:17.117936497+08:00 I0504 21:34:17.117280       1 client.go:142] creating 1 resource(s)
2025-05-04T21:34:17.165403422+08:00 I0504 21:34:17.165115       1 wait.go:48] beginning wait for 39 resources with timeout of 1m0s
2025-05-04T21:34:19.251521912+08:00 I0504 21:34:19.251086       1 install.go:205] Clearing REST mapper cache
2025-05-04T21:35:01.462985723+08:00 I0504 21:35:01.462663       1 cluster_controller.go:396] Finished installing KS Core for the cluster 1111
2025-05-04T21:35:01.463580973+08:00 E0504 21:35:01.462811       1 controller.go:329] "Reconciler error" err=<
2025-05-04T21:35:01.463639462+08:00 	failed to reconcile cluster 1111: failed to install KS Core in cluster 1111: unable to build kubernetes objects from release manifest: resource mapping not found for name: "restart-extensions-museum" namespace: "kubesphere-system" from "": no matches for kind "CronJob" in version "batch/v1beta1"
2025-05-04T21:35:01.463663426+08:00 	ensure CRDs are installed first
2025-05-04T21:35:01.463686131+08:00  > controller="cluster" controllerGroup="cluster.kubesphere.io" controllerKind="Cluster" Cluster="1111" namespace="" name="1111" reconcileID="78e09f57-9f9e-419c-8cab-a283618a7b78"
