rockylinux9
v1.31.8+rke2r1
v2.0.5-k3s1
使用 1.1.5 的 helm chart 安装的 kubesphere 。根据 chart 中的信息, ks 镜像 tag 为 v4.1.3
无法在流水线中下载制品
devops-apiserver 错误日志如下:
│ I0624 09:58:19.225648 1 apiserver.go:318] 192.168.xx.xx - "GET /kapis/devops.kubesphere.io/v1alpha3/namespaces/uat-tradex5mx5f/pipelineruns/tendata-tradec-jlknf/artifacts/download?filename=tendata-tradec-resource-server%2Fbuild%2Flibs%2Ftendata-tradec-resource-server-3.0.0-SNAPSHOT.jar HTTP/1.1" 500 52 15ms
│ E0624 09:58:37.201484 1 utils.go:110] /workspace/pkg/kapis/devops/v1alpha3/pipelinerun/handler.go:267 failed to get artifact. the HTTP status code is 404
│ I0624 09:58:37.201518 1 apiserver.go:318] 192.168.xx.xx - "GET /kapis/devops.kubesphere.io/v1alpha3/namespaces/uat-tradex5mx5f/pipelineruns/tendata-tradec-jlknf/artifacts/download?filename=config.tar.gz HTTP/1.1" 500 52 35ms
│ E0624 09:58:37.793577 1 utils.go:110] /workspace/pkg/kapis/devops/v1alpha3/pipelinerun/handler.go:267 failed to get artifact. the HTTP status code is 404
│ I0624 09:58:37.793614 1 apiserver.go:318] 192.168.xx.xx - "GET /kapis/devops.kubesphere.io/v1alpha3/namespaces/uat-tradex5mx5f/pipelineruns/tendata-tradec-jlknf/artifacts/download?filename=config.tar.gz HTTP/1.1" 500 52 7ms
我直接从 jenkins 中是可以下载的。
