v1.23.10
docker version
24.0.6
v3.4.1。使用kk离线安装。
问题是什么?
使用命令:./kk add nodes -f ksp-v3013-v12310-offline.yaml
目的是添加一个worker9节点。
但是运行过程中出现错误:
15:40:34 CST [KubernetesStatusModule] Get kubernetes cluster status
15:40:34 CST stdout: [master1]
v1.23.10
The connection to the server lb.kubesphere.local:6443 was refused - did you specify the right host or port?
15:40:34 CST message: [master1]
get kubernetes cluster info failed: Failed to exec command: sudo -E /bin/bash -c “/usr/local/bin/kubectl –no-headers=true get nodes -o custom-columns=:metadata.name,:status.nodeInfo.kubeletVersion,:status.addresses”
The connection to the server lb.kubesphere.local:6443 was refused - did you specify the right host or port?: Process exited with status 1
15:40:34 CST retry: [master1]
如下图:
检查了dns也没问题啊,手动执行“/usr/local/bin/kubectl –no-headers=true get nodes -o custom-columns=:metadata.name,:status.nodeInfo.kubeletVersion,:status.addresses”也能出结果。求解决
