Centos7.9,12C/64G
Client Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.12”, GitCommit:“b058e1760c79f46a834ba59bd7a3486ecf28237d”, GitTreeState:“clean”, BuildDate:“2022-07-13T14:59:18Z”, GoVersion:“go1.16.15”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.12”, GitCommit:“b058e1760c79f46a834ba59bd7a3486ecf28237d”, GitTreeState:“clean”, BuildDate:“2022-07-13T14:53:39Z”, GoVersion:“go1.16.15”, Compiler:“gc”, Platform:“linux/amd64”}
[root@k8s-node01 tmp]# docker version
Client:
Version: 20.10.8
API version: 1.41
Go version: go1.16.6
Git commit: 3967b7d
Experimental: true
Version: 20.10.8
Git commit: 75249d8
Version: v1.4.9
Version: 1.0.1
GitCommit: v1.0.1-0-g4144b638
Version: 0.19.0
GitCommit: de40ad0
v3.3.2,kk安装。
在kubesphere上安装了Istio,版本是1.11.2,但是测试会话保持基于header,没有生效。
查看dr是有配置的:
Ingress如下:
但是会话保持没生效:
这个是因为没用Istio的ingress-gateway的原因吗?如果用Istio的ingress-gateway的话配置Gateway可以在Kubesphere的控制台可视化吗?
