freemankevinK零S
使用gitlab不是直接配置用户密码即可吗?白天还可用,晚上不管怎样都不能用了
freemankevin 贴一下你的pipeline报什么错
Started by user project-regular
[Wed Nov 25 05:02:20 UTC 2020] Starting branch indexing...
> git --version # timeout=10
using GIT_ASKPASS to set credentials
> git ls-remote --symref git@10.0.1.185:ssss/BladeX.git # timeout=10
ERROR: [Wed Nov 25 05:02:20 UTC 2020] Could not update folder level actions from source
hudson.plugins.git.GitException: Command "git ls-remote --symref git@10.0.1.185:ssss/BladeX.git" returned status code 128:
stdout:
stderr: Permission denied, please try again.
Permission denied (publickey,gssapi-keyex,gssapi-with-mic,password).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1761)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1666)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1657)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.getRemoteSymbolicReferences(CliGitAPIImpl.java:2919)
at jenkins.plugins.git.AbstractGitSCMSource.retrieveActions(AbstractGitSCMSource.java:1093)
at jenkins.scm.api.SCMSource.fetchActions(SCMSource.java:848)
at jenkins.branch.MultiBranchProject.computeChildren(MultiBranchProject.java:591)
at com.cloudbees.hudson.plugins.folder.computed.ComputedFolder.updateChildren(ComputedFolder.java:277)
at com.cloudbees.hudson.plugins.folder.computed.FolderComputation.run(FolderComputation.java:164)
at jenkins.branch.MultiBranchProject$BranchIndexing.run(MultiBranchProject.java:1025)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
[Wed Nov 25 05:02:20 UTC 2020] Finished branch indexing. Indexing took 0.21 sec
FATAL: Failed to recompute children of devpfckn » auth
stdout:
Finished: FAILURE
看起来你的代码仓库地址使用的是git
协议,但你给的凭据是用户名/密码,因此是无法使用的。
给你一个参考链接:
https://github.com/jenkins-zh/jenkins-zh/issues/394
Rick 可以了,感谢
在自己的办公本子上做个公钥和私钥,公钥放到自己的gitlab账号里,私钥给配给ks凭证好给jenkins拿着用。应该是这个意思吧
Rick
原因有好几种:
一开始测试的时候,看到jenkins的流水线异常就顺手删除了,发现ks面板这边没法即使更新同步,会有报错,应该是不能再jenkins那边删流水线。暂时ks也没对jenkins做这块的权限控制。
第二是和gitlab一样,要做密钥,使用ssh方式拉取git代码的话
解决办法:
1)暂时还未完全清楚这里的逻辑就暂时在ks面板那边删流水线
2)git问题要做密钥才能让jenkins拿着用
