整体梳理了下全过程,感谢官网各位老师的支持和帮助。
折腾了好久,最关键的还是harbor官网那边给的方案让我重新检查自己的各个部署环节。
版本情况:
harbor2.0
ks3.0
k8s17.9
centos7.8
docker18.06
CA工具
cfssl
1.harbor使用域名(这是我们这边的需求,用IP也可以,尝试报错过不再测试)
1)配置
hostname: harbor.dockerregistry.com
2)hosts
/etc/hosts
3)要使配置完全更新(我应该是在这个地方翻车的,因为还要搞其它的东西,有机会再复现一下)
./prepare(官网做法)
之前是安装了其他插件所以直接附带参数
./prepare –…
2.harbor使用http
1)配置
# http related config
http:
port: 80
# https related config
#https:
# https port for harbor, default is 443
# port: 443
# The path of cert and key files for nginx
# certificate: /data/harbor/ssl/harbor.dockerregistry.com.pem
# private_key: /data/harbor/ssl/harbor.dockerregistry.com-key.pem
3.docker服务和客户端要都做非http可信:insecure-registries
1)配置
[root@cicd-jgh harbor]# cat /etc/docker/daemon.json
"exec-opts": ["native.cgroupdriver=systemd"],
"registry-mirrors": ["https://pfei7wep.mirror.aliyuncs.com"],
"insecure-registries": ["harbor.dockerregistry.com"],
"log-opts":{ "max-size" :"10m","max-file":"10"},
"log-driver": "json-file"
4.ks面板的harbor密钥使用域名方式
5.corends添加hosts映射,即那个域名和ip的关系映射
有其它的dns服务应该也要加(这里是看其他帖子来的,我这边暂时没有)
注意这个yaml位置的空格
kubectl -n kube-system get cm coredns -o yaml
kubectl -n kube-system edit cm coredns
hosts{
10.0.1.185 harbor.dockerregistry.com
fallthrough
[root@master1 ~]# kubectl delete --force -n kube-system pod coredns-7f9c544f75-vqxxr
warning: --force is ignored because --grace-period is not 0.
pod "coredns-7f9c544f75-vqxxr" deleted
[root@master1 ~]# kubectl delete --force -n kube-system pod coredns-7f9c544f75-h9qhr
pod "coredns-7f9c544f75-h9qhr" deleted
[root@master1 ~]# kubectl get pod -A |grep core
kube-system coredns-7f9c544f75-sf7lh 1/1 Running 0 109s
kube-system coredns-7f9c544f75-vspcs 1/1 Running 0 2m5s
[root@master1 ~]#
[root@master1 ~]#
[root@master1 ~]#
# 10.96.0.10 是上面修改coredns看到的forward时的dns-IP
[root@master1 ~]# nslookup node1 -n 10.96.0.10
*** Invalid option: n
Server: 10.96.0.10
Address: 10.96.0.10#53
Address: 10.0.1.224
** server can't find node1: NXDOMAIN
[root@master1 ~]# nslookup node2 -n 10.96.0.10
Server: 10.96.0.10
Address: 10.0.1.225
** server can't find node2: NXDOMAIN
[root@master1 ~]# nslookup harbor.dockerregistry.com -n 10.96.0.10
Server: 10.96.0.10
Address: 10.0.1.185
** server can't find harbor.dockerregistry.com: NXDOMAIN
6.最后确认下,harbor状态正常,docker客户端登陆正常,docker客户端使用harbor的一键拉取命令正常
服务端
[root@cicd-jgh harbor]# docker-compose ps
Name Command State Ports
harbor-core /harbor/entrypoint.sh Up (healthy)
harbor-db /docker-entrypoint.sh Up (healthy) 5432/tcp
harbor-jobservice /harbor/entrypoint.sh Up (healthy)
harbor-log /bin/sh -c /usr/local/bin/ ... Up (healthy) 127.0.0.1:1514->10514/tcp
harbor-portal nginx -g daemon off; Up (healthy) 8080/tcp
nginx nginx -g daemon off; Up (healthy) 0.0.0.0:80->8080/tcp
redis redis-server /etc/redis.conf Up (healthy) 6379/tcp
registry /home/harbor/entrypoint.sh Up (healthy) 5000/tcp
registryctl /home/harbor/start.sh Up (healthy)
[root@cicd-jgh harbor]# docker login harbor.dockerregistry.com
Username (admin): admin
Password:
Login Succeeded
客户端
[root@master1 ~]# docker login harbor.dockerregistry.com
Authenticating with existing credentials...
WARNING! Your password will be stored unencrypted in /root/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
[root@master1 ~]#
[root@node5 ~]# docker pull harbor.dockerregistry.com/app/mysql@sha256:9e902247f80eca2e0fc4179f48a91afbe3b2a61122dd5e7575b5f0549aab97d0
sha256:9e902247f80eca2e0fc4179f48a91afbe3b2a61122dd5e7575b5f0549aab97d0: Pulling from app/mysql
d121f8d1c412: Pull complete
f3cebc0b4691: Pull complete
1862755a0b37: Pull complete
489b44f3dbb4: Pull complete
690874f836db: Pull complete
baa8be383ffb: Pull complete
55356608b4ac: Pull complete
277d8f888368: Pull complete
21f2da6feb67: Extracting [==============================> ] 66.85MB/108.3MB
2c98f818bcb9: Download complete
031b0a770162: Download complete
7.注意找寻镜像文件应加对应标签
8.最后附上重要的几份文档,不一定完全对,结合着看(可嫩需要科学上网)
1)添加 Harbor 镜像仓库
https://v2-1.docs.kubesphere.io/docs/zh-CN/configuration/image-registry/#%E6%B7%BB%E5%8A%A0-harbor-%E9%95%9C%E5%83%8F%E4%BB%93%E5%BA%93
2)生成证书颁发机构证书
https://goharbor.io/docs/1.10/install-config/configure-https/
3)对HTTPS连接进行故障排除
https://goharbor.io/docs/1.10/install-config/troubleshoot-installation/#https
以上,感谢
PS:
以上是基于域名的,改成实际IP反而会报异常,换回域名就正常
