RolandMa1986 baojunz 你可以尝试一下编辑 node-exporter, 把sys 目录挂载给去掉。 kubectl -n kubesphere-monitoring-system edit daemonsets.apps node-exporter。
cage1016 kubesphere/kubesphere#3277 (comment) Node-Exporter is not designed to run on Mac. So you may disable the monitoring component. /area monitoring /kind support
